Home » Eclipse Projects » Eclipse Platform » First use impossible
First use impossible [message #145780] Fri, 17 October 2003 10:24 Go to next message
Originally posted by: pascal_lessard.hotmail.com
I've downloaded the last release of eclipse and installed the java
platform on my computer. When I click on the exe icon after unzipping the
downloaded file, a message box appear and say that there's been na problem
at the startup and that there is a new log file. By the way, I'm not
connected to internet.
The error log that is provided when I click on
> the exe icon is :
> !SESSION
> !ENTRY org.eclipse.core.launcher 4 0 oct. 12, 2003 22:04:27.281
> !MESSAGE Exception launching the Eclipse Platform:
> !STACK
> java.lang.RuntimeException: Could not find bootstrap code. Check location
> of boot plug-in or specify -boot.
> at org.eclipse.core.launcher.Main.searchForBoot(Main.java:468)
> at org.eclipse.core.launcher.Main.getBootPath(Main.java:438)
> at org.eclipse.core.launcher.Main.basicRun(Main.java:281)
> at org.eclipse.core.launcher.Main.run(Main.java:747)
> at org.eclipse.core.launcher.Main.main(Main.java:583)
> !SESSION
> !ENTRY org.eclipse.core.launcher 4 0 oct. 16, 2003 13:44:29.656
> !STACK
> Thank you very much
> Pascal
Re: First use impossible [message #145975 is a reply to message #145780] Fri, 17 October 2003 15:16 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
This has been reported in the past, and it was a case of unzipping using
WinZip and not selecting "User folder names". This caused it to unzip
into a flat directory, and as a result Main couldn't find the plugins
directory (because there were no directories). Make sure you extract
from the zip preserving folder names. We are aware the error message is
not good in this case, and we have a bug report for improving it.
>>the exe icon is :
>>!SESSION
>>!STACK
>>!SESSION
>>!STACK
>>Thank you very much
>>Pascal
Re: First use impossible [message #146623 is a reply to message #145975] Mon, 20 October 2003 11:56 Go to previous message
Thank you very much.
> >>the exe icon is :
> >>!SESSION
> >>!STACK
> >>!SESSION
> >>!STACK
> >>Thank you very much
> >>Pascal
Previous Topic:How to add a run-time lib to plug-in
Next Topic:Ant / javac task keeps handle on jars in classpath, can't delete
Current Time: Tue Jul 22 02:26:26 EDT 2025
Powered by FUDForum. Page generated in 0.04107 seconds
