Home » Archived » Visual Editor (VE) » Broken GUI Editor after adding field to frame.
Broken GUI Editor after adding field to frame. [message #145777] Wed, 18 March 2009 18:21 Go to next message
I used VE to create a new JFrame. I then added a custom private member
field (just after serialVersionUID), and added a parameter to the
constructor to initialize it (initialized between super() and initialize()
call in constructor).
When I did that, the frame in the editor shrunk to 0 size. Figuring I
broke something I undid my changes, restoring the file to it's state
before I added the custom field.
Now, the frame is blank in the visual editor; none of my components are on
it. The title is set to "(no title set for window in visual editor)". The
tool tip that displays when I hover over the frame is "Round Tripping is
stopped". The only item in the JavaBeans view is labeled "this"; there are
no other components in the tree. However, the code for all the components
is still in the file, and when I run the application the actual form with
all the components displays correctly.
The editor seems to no longer be aware of what's on the frame. Closing and
reopening the editor did not fix the problem. Restarting Eclipse did not
fix the problem. I can now no longer edit the GUI in visual editor, and am
dead in the water and have to stop working early today. How do I fix this?
Also, in the future, how do I add custom fields to the frame class?
MB
Re: Broken GUI Editor after adding field to frame. [message #145786 is a reply to message #145777] Wed, 18 March 2009 18:49 Go to previous messageGo to next message
I was able to fix the problem by closing the editor, cleaning the project,
then reopening the editor.
MB
Re: Broken GUI Editor after adding field to frame. [message #145823 is a reply to message #145786] Thu, 19 March 2009 09:59 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
You should be able to add custom fields with no problem. The problem was
probably due to the change to the constructor from the default to one
that takes a parameter. Typically to be able to be used in the VE there
should be at least a default ctor that doesn't take any parameters.
> project, then reopening the editor.
> MB
Rich Kulp
Re: Broken GUI Editor after adding field to frame. [message #617336 is a reply to message #145777] Wed, 18 March 2009 18:49 Go to previous message
MB
Re: Broken GUI Editor after adding field to frame. [message #617340 is a reply to message #145786] Thu, 19 March 2009 09:59 Go to previous message
> MB
Rich Kulp
Previous Topic:Editing Layouts
Next Topic:Re: Visual Editor for Eclipse Version 3.4
Current Time: Wed Jul 02 23:54:09 EDT 2025
Powered by FUDForum. Page generated in 0.03461 seconds
