Home » Language IDEs » Java Development Tools (JDT) » packages vs directory structor
packages vs directory structor [message #145732] Thu, 26 February 2004 10:43 Go to next message
Originally posted by: cdouglass.mtbj.com
I am trying to use eclipse to do development on an existing project but
I'm running into issues with packages vs directory structure. The original
projects is layed out as
abc/def/XYZ/src/fred.java
where fred.java implements a class in package XYZ. I can create a package
XYZ and set it's directory to be under abc/def but then building fred.java
complains that the package should be XYZ.src not XYZ. If instead I set the
directory for package XYZ to abc/def/XYZ eclipse creates a new XYZ
directory as abc/def/XYZ/XYZ ...
Because the existing ANT scripts rely on existing directory layout I would
really prefer not to have to move the source files.
Setting the source directory property for the project effectively
decouples the leading directory structure from the package name. Is there
a mechanism for decoupling the trailing directory structure from the
package name so I can leave the source in the src subdirectories?
Clay
Re: packages vs directory structor [message #145890 is a reply to message #145732] Thu, 26 February 2004 17:48 Go to previous message
Originally posted by: rtayek.no.spam.freightgate.com
"Clay Douglass" <cdouglass@mtbj.com> wrote in message
news:c1l46i$95h$1@eclipse.org...
i solved a similar problem (using 3.0m07 i think) by fooling around in the
project|properties|java build path|source tab. specify abc/def/XYZ/src as a
source folder (i use projectname/src and projectname/tst). then check the
"allow output folders for source folders". then supply an output foder that
agrees with your ant script (i use projectname/build/srcobj and
projectname/build/tstobj). (see my ant script below)
i would thing you could point the obj to wherever you like/
hth
<project basedir="." default="all" name="mappingtools">
<property environment="env"/>
<property file="${user.home}/build.properties"/>
<property file="build.properties"/>
<!-- may want to set out own build compiler -->
<target name="checkforeclipse" if="eclipse.running">
<property name="build.compiler"
value="org.eclipse.jdt.core.JDTCompilerAdapter"/>
<echo message="junit.home=${junit.home}"/>
<echo message="env.JUNIT_HOME=${env.JUNIT.HOME}"/>
<echo message="JUNIT_HOME=${JUNIT.HOME}"/>
<property name="junit.jar"
value="${eclipse.home}\plugins\org.junit_3.8.1\junit.jar"/ >
</target>
<target name="init" depends="checkforeclipse">
<echo message="env.JAVA_HOME=${env.JAVA_HOME}"/>
<echo message="env.ANT_HOME=${env.ANT_HOME}"/>
<echo message="user.home=${user.home}"/>
<echo message="java.home=${java.home}"/>
<echo message="ant.home=${ant.home}"/>
<property name="junit.jar" value="${ant.home}/lib/junit.jar"/><!-- usually
one hangs out here -->
<echo message="junit.jar=${junit.jar}"/><!-- this has /'s and \'s on windoze
xp! -->
<fail unless="junit.jar">no ant.home!</fail>
<mkdir dir="build"/>
</target>
<target name="clean" depends="init" description="clean">
<delete dir="dist"/>
<delete dir="build"/>
<delete dir="doc/apidoc"/>
<delete dir="deleted"/>
</target>
<target name="compile" depends="init" description="compile">
<mkdir dir="build/classes"/>
<mkdir dir="build/classes/srcobj"/>
<javac debug="true" deprecation="true" destdir="build/classes/srcobj"
srcdir="src">
<classpath>
<pathelement location="lib/ostermillerutils_1_02_21.jar"/>
</classpath>
</javac>
</target>
<target name="compiletst" depends="init,compile" description="compile
tests">
<mkdir dir="build/classes/tstobj"/>
<javac debug="true" deprecation="true" destdir="build/classes/tstobj"
srcdir="tst">
<classpath>
<pathelement location="${junit.jar}"/>
<pathelement location="build/classes/srcobj"/>
</classpath>
</javac>
<mkdir dir="build/classes/tstobj/com/ediidea/mappingtools/testfiles "/>
<copy todir="build/classes/tstobj/com/ediidea/mappingtools/testfiles ">
<fileset dir="tst/com/ediidea/mappingtools/testfiles" includes="*.*"
excludes="*.nbattrs"/>
</copy>
</target>
<target name="jar" depends="init,compile" description="jar">
<mkdir dir="build/lib"/>
<jar basedir="build/classes/srcobj" compress="true"
jarfile="build/lib/mappingtools.jar">
<exclude name="**/deleted/**"/>
<exclude name="**/RCS/**"/>
<exclude name="*.class"/><!-- exclude default package classes-->
</jar>
</target>
<target name="all" depends="init,junit">
</target>
<!-- figure out how (where) to deliver stuff -->
<target name="deliver" depends="init,jar" description="deliver">
<property name="delivery.dir" value="${user.home}/java/tmp/rel"/>
<mkdir dir="${delivery.dir}"/>
<mkdir dir="${delivery.dir}/lib"/>
<copy todir="${delivery.dir}/lib">
<fileset dir="build/lib" includes="*.jar"/>
</copy>
<mkdir dir="${delivery.dir}/bin"/>
<copy todir="${delivery.dir}/bin">
<fileset dir="sh" includes="checkcsv,csvtocsv,fast,fuv,splitcsv,"/>
</copy>
</target>
<target name="test" depends="init,compiletst" description="test">
<java classname="com.ediidea.mappingtools.MappingToolsTestCase"
failonerror="true" fork="true">
<classpath>
<pathelement location="${ant.home}/lib/xercesImpl.jar"/>
<pathelement location="lib/xalan.jar"/>
<pathelement location="build/classes/tstobj"/>
</classpath>
</java>
</target>
<target name="testjar" depends="init,jar,compiletst" description="test jar">
<classpath>
<pathelement location="build/lib/mappingtools.jar"/>
</classpath>
</java>
</target>
<target name="junit" depends="init,jar,compiletst" description="test jar
using junit">
<junit printsummary="true" haltonfailure="true">
<formatter type="plain" usefile="false"/>
<test name="com.ediidea.mappingtools.MappingToolsTestCase"/>
<classpath>
</classpath>
</junit>
</target>
<target name="javadoc" depends="init" description="javadoc">
<mkdir dir="doc/apidoc"/>
<javadoc destdir="doc/apidoc" packagenames="com.ediidea.mappingtools.*">
<sourcepath>
<pathelement location="src"/>
</sourcepath>
<classpath>
</classpath>
</javadoc>
</target>
</project>
Previous Topic:Newbie stuck at HelloWorld
Next Topic:Strip out unneeded plugins
Current Time: Wed Jul 16 02:28:49 EDT 2025
Powered by FUDForum. Page generated in 0.06055 seconds
