Debug problems with the system.out.println statement [message #145633] |
Thu, 26 February 2004 00:58  |
Hi all...
i have been running eclipse on a windows 2000 box with no issues. Recently
i was debugging..the proble that i am facing is when i am stepping into
the code, if the debugger runs into a 'System.out.println("debug the
debugger");'i get a source not found error..and an option to change the
source.
What do i need to attach so that it works properly.
Re: Debug problems with the system.out.println statement [message #147486 is a reply to message #147372] |
Fri, 05 March 2004 10:54  |
I suggest filing a bug report with a simple test case to demonstrate the
problem. I'm developing on XP, so I may not be able to reproduce the problem
(and I'm having a hard time understanding what the problem is, from the
description provided).
Darin
"exquisitus" <foo@dog.com> wrote in message news:c28eg1$vat$1@eclipse.org...
> yeah...i did try the step filter...same result.
> Darin Wright wrote:
> > Have you tried adding a "Step Filter" from the Java > Debug > Step
Filters
> > pref page?
> > Darin
> > "exquisitus" <foo@bar.com> wrote in message
news:c1nmpf$go6$1@eclipse.org...
> > > yep..i figured out the src bit. I inflated the src.zip just to see if
> > > somethig happens. I just installed eclipse in a linux platform(the
attach
> > > source problem upon hitting a System.out.println isnt
> > > happening)....however, it still runs to the java.lang classes and goes
> > > through instantiating every bit of code..
> > > heres an example
> > > int zz=0;
> > > for(int i=0;i<3;i++)
> > > System.out.println(" All the class loading drama goes on and on for a
> > > while here, till i use ctrl+return a number of times to go to the next
> > > line");
> > > zz=1;
> > > Is this the expected behaviour?
> > > Darin Wright wrote:
> > > > Sources are not usually in the jar file - they are usually in a
seperate
> > > > "src.zip" that comes with a JDK. As well, source is not provided for
all
> > the
> > > > classes in the system libraries. Class loading should not happen on
> > every
> > > > iteration through the loop - it should only happen the first time a
> > class is
> > > > loaded (unless you are in a class loading loop :-)
> > > > Darin
> > news:c1lsgm$bq2$1@eclipse.org...
> > > > > Thanks for that Darin....arent the surces in a jar file?? Where do
i
> > get
> > > > > the sources from? Pressing "step return" is a like a half fix.
Imagine
> > if
> > > > > that that println is ina for loop ...il be "step return"...ing
all
> > the
> > > > > time. Anyways lemme knwo yer views.
> > > > > Thanks once again.
> > > > > Darin Wright wrote:
> > > > > > Do you have source attached to your JRE's class libraries?
Source
> > should
> > > > be
> > > > > > found for the ClassLoader class in this case.
> > > > > > The first time you step into a "println", it may cause some
class
> > > > loading -
> > > > > > which it sounds like you are seeing. By pressing "step return"
when
> > this
> > > > > > happens, and then "step into" again, you should be able to get
> > around
> > > > the
> > > > > > class loading.
> > > > > > Darin
> > > > > > "Exquisitus" <foo@bar.com> wrote in message
> > > > news:c1ka81$35r$1@eclipse.org...
> > > > > > > Further to my first post...the problem is with loading
> > > > > > > java.lang.ClassLoader.loadclass...how do i make the debugger
load
> > this
> > > > > > > class, so that it can use the System.out.println statement
without
> > > > > > > reporting an error
> > > > > > > exquisitus wrote:
> > > > > > > > Hi all...
> > issues.
> > > > > > Recently
> > stepping
> > > > into
> > the
> > change
> > > > the
> > > > > > > > source.
FUDForum. Page generated in 0.10363 seconds
