Home » Language IDEs » Java Development Tools (JDT) » Debug problems with the system.out.println statement
Debug problems with the system.out.println statement [message #145633] Thu, 26 February 2004 00:58 Go to next message
Hi all...
i have been running eclipse on a windows 2000 box with no issues. Recently
i was debugging..the proble that i am facing is when i am stepping into
the code, if the debugger runs into a 'System.out.println("debug the
debugger");'i get a source not found error..and an option to change the
source.
What do i need to attach so that it works properly.
Re: Debug problems with the system.out.println statement [message #145650 is a reply to message #145633] Thu, 26 February 2004 03:20 Go to previous messageGo to next message
Further to my first post...the problem is with loading
java.lang.ClassLoader.loadclass...how do i make the debugger load this
class, so that it can use the System.out.println statement without
reporting an error
exquisitus wrote:
> Hi all...
> source.
Re: Debug problems with the system.out.println statement [message #145694 is a reply to message #145650] Thu, 26 February 2004 09:19 Go to previous messageGo to next message
Do you have source attached to your JRE's class libraries? Source should be
found for the ClassLoader class in this case.
The first time you step into a "println", it may cause some class loading -
which it sounds like you are seeing. By pressing "step return" when this
happens, and then "step into" again, you should be able to get around the
class loading.
Darin
"Exquisitus" <foo@bar.com> wrote in message news:c1ka81$35r$1@eclipse.org...
> reporting an error
> exquisitus wrote:
> > Hi all...
Recently
> > source.
Re: Debug problems with the system.out.println statement [message #145881 is a reply to message #145694] Thu, 26 February 2004 17:38 Go to previous messageGo to next message
Thanks for that Darin....arent the surces in a jar file?? Where do i get
the sources from? Pressing "step return" is a like a half fix. Imagine if
that that println is ina for loop ...il be "step return"...ing all the
time. Anyways lemme knwo yer views.
Thanks once again.
> class loading.
> Darin
> > reporting an error
> > exquisitus wrote:
> > > Hi all...
> Recently
> > > source.
Re: Debug problems with the system.out.println statement [message #146006 is a reply to message #145881] Fri, 27 February 2004 09:22 Go to previous messageGo to next message
Sources are not usually in the jar file - they are usually in a seperate
"src.zip" that comes with a JDK. As well, source is not provided for all the
classes in the system libraries. Class loading should not happen on every
iteration through the loop - it should only happen the first time a class is
loaded (unless you are in a class loading loop :-)
Darin
"exquisitus" <foo@bar.com> wrote in message news:c1lsgm$bq2$1@eclipse.org...
> Thanks once again.
be
loading -
the
> > class loading.
> > Darin
> > > reporting an error
> > > exquisitus wrote:
> > > > Hi all...
> > Recently
into
the
> > > > source.
Re: Debug problems with the system.out.println statement [message #146027 is a reply to message #146006] Fri, 27 February 2004 10:12 Go to previous messageGo to next message
yep..i figured out the src bit. I inflated the src.zip just to see if
somethig happens. I just installed eclipse in a linux platform(the attach
source problem upon hitting a System.out.println isnt
happening)....however, it still runs to the java.lang classes and goes
through instantiating every bit of code..
heres an example
int zz=0;
for(int i=0;i<3;i++)
System.out.println(" All the class loading drama goes on and on for a
while here, till i use ctrl+return a number of times to go to the next
line");
zz=1;
Is this the expected behaviour?
> Darin
> > Thanks once again.
> be
> loading -
> the
> > > class loading.
> > > Darin
> > > > reporting an error
> > > > exquisitus wrote:
> > > > > Hi all...
> > > Recently
> into
> the
> > > > > source.
Re: Debug problems with the system.out.println statement [message #146524 is a reply to message #146027] Mon, 01 March 2004 09:24 Go to previous messageGo to next message
Have you tried adding a "Step Filter" from the Java > Debug > Step Filters
pref page?
Darin
"exquisitus" <foo@bar.com> wrote in message news:c1nmpf$go6$1@eclipse.org...
> heres an example
> int zz=0;
> line");
> zz=1;
the
every
class is
> > Darin
get
if
the
> > > Thanks once again.
should
> > be
> > loading -
this
around
> > the
> > > > class loading.
> > > > Darin
this
> > > > > reporting an error
> > > > > exquisitus wrote:
> > > > > > Hi all...
issues.
> > > > Recently
stepping
> > into
the
change
> > the
> > > > > > source.
Re: Debug problems with the system.out.println statement [message #147372 is a reply to message #146524] Thu, 04 March 2004 18:35 Go to previous messageGo to next message
Originally posted by: foo.dog.com
yeah...i did try the step filter...same result.
> pref page?
> Darin
> > heres an example
> > int zz=0;
> > line");
> > zz=1;
> the
> every
> class is
> > > Darin
> get
> if
> the
> > > > Thanks once again.
> should
> > > be
> > > loading -
> this
> around
> > > the
> > > > > class loading.
> > > > > Darin
> this
> > > > > > reporting an error
> > > > > > exquisitus wrote:
> > > > > > > Hi all...
> issues.
> > > > > Recently
> stepping
> > > into
> the
> change
> > > the
> > > > > > > source.
Re: Debug problems with the system.out.println statement [message #147486 is a reply to message #147372] Fri, 05 March 2004 10:54 Go to previous message
I suggest filing a bug report with a simple test case to demonstrate the
problem. I'm developing on XP, so I may not be able to reproduce the problem
(and I'm having a hard time understanding what the problem is, from the
description provided).
Darin
"exquisitus" <foo@dog.com> wrote in message news:c28eg1$vat$1@eclipse.org...
Filters
> > pref page?
> > Darin
attach
> > > heres an example
> > > int zz=0;
> > > line");
> > > zz=1;
seperate
all
> > the
> > every
> > class is
> > > > Darin
i
> > get
Imagine
> > if
all
> > the
> > > > > Thanks once again.
Source
> > should
> > > > be
class
> > > > loading -
when
> > this
> > around
> > > > the
> > > > > > class loading.
> > > > > > Darin
load
> > this
without
> > > > > > > reporting an error
> > > > > > > exquisitus wrote:
> > > > > > > > Hi all...
> > issues.
> > > > > > Recently
> > stepping
> > > > into
> > the
> > change
> > > > the
> > > > > > > > source.
Previous Topic:Import question
Next Topic:Question about Cyclic buildpath...
Current Time: Wed May 07 17:15:05 EDT 2025
Powered by FUDForum. Page generated in 0.05663 seconds
