Home » Language IDEs » ServerTools (WTP) » Geronimo failed to start
Geronimo failed to start [message #145524] Fri, 28 October 2005 10:57
I start geronimo with following command it works fine.
$ /usr/local/geronimo/bin/startup.sh
If I try to start geronimo in WTP servers view, it fails.
Can you help me.
Thanks.
Eclipse SDK Version: 3.1.1 Build id: M20050929-0840
Wtp 0.7.1
Geronimo 1.0-M5
Here is /usr/local/geronimo/var/log/geronimo.log
16:31:52,963 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/System,J2EEServer=geronimo,j2eeType=SystemLog,name=L ogger
State changed from starting to running
16:31:52,966 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/System,J2EEServer=geronimo,j2eeType=ConfigurationMan ager,name=ConfigurationManager
State changed from stopped to starting
16:31:53,012 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:53,014 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/System,J2EEServer=geronimo,j2eeType=ConfigurationSto re,name=Local
16:31:53,018 DEBUG [GBeanSingleReference] Waiting to start
because no targets are running for reference AttributeStore matching the
patternspatterns
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/System,J2EEServer=geronimo,j2eeType=AttributeStore,n ame=AttributeManager
16:31:53,018 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/System,J2EEServer=geronimo,j2eeType=PersistentConfig urationList,name=Default
16:31:53,177 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:53,178 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:54,622 INFO [LocalAttributeManager] Started LocalAttributeManager
with data on 11 configurations
16:31:54,622 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:54,737 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:54,995 INFO [LocalConfigStore:config-store] Loaded Configuration
geronimo.config:name="org/apache/geronimo/RMINaming"
16:31:55,001 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.config:name="org/apache/geronimo/RMINaming" State changed from
stopped to starting
16:31:55,060 DEBUG [Configuration] ClassPath for
org/apache/geronimo/RMINaming resolved to
[file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ge ronimo-management-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-j2ee-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-webservices-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-activation-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo-spec/jar s/geronimo-spec-j2ee-1.4-rc4.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-transaction-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/howl/jars/howl-lo gger-0.1.8.jar,
file:/usr/local/geronimo-1.0-M5/repository/tranql/jars/tranq l-1.1.jar,
file:/usr/local/geronimo-1.0-M5/repository/antlr/jars/antlr- 2.7.2.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-security-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/concurrent/jars/c oncurrent-1.3.4.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-core-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/activeio/jars/act iveio-2.0-r118.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-naming-1.0-M5.jar]
16:31:55,163 DEBUG [LocalAttributeManager] Setting value for
org/apache/geronimo/RMINaming/geronimo.server:J2EEApplicatio n=null,J2EEModule=org/apache/geronimo/RMINaming,J2EEServer=g eronimo,j2eeType=GBean,name=NamingProperties/namingProviderU rl
to value rmi://0.0.0.0:1099
16:31:55,223 DEBUG [LocalAttributeManager] Setting value for
org/apache/geronimo/RMINaming/geronimo.server:J2EEApplicatio n=null,J2EEModule=org/apache/geronimo/RMINaming,J2EEServer=g eronimo,j2eeType=GBean,name=RMIRegistry/port
to value 1099
16:31:55,311 INFO [Configuration] Started configuration
16:31:55,312 DEBUG [GBeanInstanceState] GBeanInstanceState for:
starting to running
16:31:55,313 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/RMINaming,J2EEServer=geronimo,j2eeType=GBean,name=Na mingProperties
16:31:55,315 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:55,316 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/RMINaming,J2EEServer=geronimo,j2eeType=GBean,name=RM IRegistry
16:31:55,443 INFO [RMIRegistryService] Started RMI Registry on port 1099
16:31:55,444 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:55,573 INFO [LocalConfigStore:config-store] Loaded Configuration
geronimo.config:name="org/apache/geronimo/Server"
16:31:55,577 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.config:name="org/apache/geronimo/Server" State changed from
stopped to starting
16:31:55,606 DEBUG [Configuration] ClassPath for
org/apache/geronimo/Server resolved to
[file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ge ronimo-core-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-connector-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-timer-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/openejb/jars/open ejb-core-2.0-G1M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo-spec/jar s/geronimo-spec-corba-2.3-rc4.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-util-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-jmxremoting-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/regexp/jars/regex p-1.3.jar,
file:/usr/local/geronimo-1.0-M5/repository/xstream/jars/xstr eam-1.0.2.jar,
file:/usr/local/geronimo-1.0-M5/repository/xpp3/jars/xpp3-1. 1.3.3.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-common-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-client-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/asm/jars/asm-1.4. 3.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-axis-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/axis/jars/axis-1. 3-svn293059-geronimo.jar,
file:/usr/local/geronimo-1.0-M5/repository/wsdl4j/jars/wsdl4 j-PATCH-1193602.jar,
file:/usr/local/geronimo-1.0-M5/repository/commons-discovery /jars/commons-discovery-0.2.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-servicemix-1.0-M5.jar,
file:/usr/local/geronimo-1.0-M5/repository/activemq/jars/act ivemq-gbean-management-3.2-M1.jar,
file:/usr/local/geronimo-1.0-M5/repository/scout/jars/jaxr-a pi-0.5.jar,
file:/usr/local/geronimo-1.0-M5/repository/scout/jars/scout- 0.5.jar,
file:/usr/local/geronimo-1.0-M5/repository/juddi/jars/juddi- 0.9rc4.jar,
file:/usr/local/geronimo-1.0-M5/repository/jdom/jars/jdom-1. 0.jar,
file:/usr/local/geronimo-1.0-M5/repository/org.apache.derby/ jars/derby-10.1.1.0.jar,
file:/usr/local/geronimo-1.0-M5/repository/org.apache.derby/ jars/derbynet-10.1.1.0.jar,
file:/usr/local/geronimo-1.0-M5/repository/geronimo/jars/ger onimo-derby-1.0-M5.jar]
16:31:59,198 INFO [Configuration] Started configuration
16:31:59,198 DEBUG [GBeanInstanceState] GBeanInstanceState for:
starting to running
16:31:59,199 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/Server,J2EEServer=geronimo,j2eeType=JCAConnectionTra cker,name=ConnectionTracker
16:31:59,201 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:59,202 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:j2eeType=JVM,J2EEServer=geronimo,name=JVM State changed
16:31:59,213 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:59,214 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:j2eeType=J2EEDomain,name=geronimo.server State changed
16:31:59,217 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:59,218 DEBUG [GBeanInstanceState] GBeanInstanceState for:
openejb:type=ContainerIndex State changed from stopped to starting
16:31:59,271 DEBUG [GBeanInstanceState] GBeanInstanceState for:
openejb:type=ContainerIndex State changed from starting to running
16:31:59,272 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/Server,J2EEServer=geronimo,j2eeType=TransactionManag er,name=TransactionManager
16:31:59,273 DEBUG [GBeanSingleReference] Waiting to start
because no targets are running for reference TransactionLog matching the
patternspatterns
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/Server,J2EEServer=geronimo,j2eeType=TransactionLog,n ame=HOWLTransactionLog
16:31:59,465 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:31:59,717 INFO [HOWLLog] Initiating transaction manager recovery
16:31:59,931 INFO [HOWLLog] In doubt transactions recovered from log
16:31:59,932 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:32:00,637 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:32:00,639 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/Server,J2EEServer=geronimo,j2eeType=JAXRConnectionFa ctory,name=eis/JAXR
16:32:00,756 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:32:00,757 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:j2eeType=J2EEServer,name=geronimo State changed from
stopped to starting
16:32:00,771 DEBUG [GBeanInstanceState] GBeanInstanceState for:
starting to running
16:32:00,772 DEBUG [GBeanInstanceState] GBeanInstanceState for:
openejb:type=Server,name=EJB State changed from stopped to starting
16:32:01,710 DEBUG [GBeanInstanceState] GBeanInstanceState for:
openejb:type=Server,name=EJB State changed from starting to running
16:32:02,021 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,EJBModule=org/apache/ge ronimo/Server,J2EEServer=geronimo,j2eeType=StatelessSessionB ean,name=ejb/mgmt/MEJB
16:32:02,497 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:32:02,621 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/Server,J2EEServer=geronimo,j2eeType=GBean,name=Defau ltThreadPool
16:32:02,748 DEBUG [GBeanInstanceState] GBeanInstanceState for:
16:32:02,749 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo:type=NetworkService,name=EJB State changed from stopped to
starting
16:32:03,078 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo:type=NetworkService,name=EJB State changed from starting to
running
16:32:03,079 DEBUG [GBeanInstanceState] GBeanInstanceState for:
geronimo.server:J2EEApplication=null,J2EEModule=org/apache/g eronimo/Server,J2EEServer=geronimo,j2eeType=GBean,name=AxisC LWorkaround
16:32:04,200 INFO [Daemon] Server shutdown begun
16:32:04,202 INFO [BasicKernel] Starting kernel shutdown
Previous Topic:Trying to Install Eclipse with WTP
Next Topic:can I help?
Current Time: Mon Jul 21 21:46:10 EDT 2025
Powered by FUDForum. Page generated in 0.11541 seconds
