Home » Archived » BIRT » Supplying column name to the report item
Supplying column name to the report item [message #145471] Fri, 17 March 2006 12:16 Go to next message
Originally posted by: anton.maslovsky.gmail.com
I have a report, which needs to include 24 hour coumns. Each data item is
displayed differently using various conditions. For exmaple, I need to round
a float value when certain global flag is set (ex. row["HE1"] != null ?
(unitStatuses ? Math.round(row["HE1"].qty) : row["HE1"].qty) : null) or
highlight a cell based on some criteria (ex. (row["HE1"] != null &&
row["HE1"].attribute == "H") then set background to RED).
This can all be done easily using BIRT features, but I'd really like to
avoid doing the same same for each 24 column. What would help me is being
able to specify coumn name ("HE1" in my examples) in one place and then use
it in all the places, such as:
- Value Expression
- Visibility
- Highlights
- Scripts
Is there a way to assign some kind of a property to the report item and then
use it consystently? Or even better - calculate such value based on data
item position in the table row?
Anton
Re: Supplying column name to the report item [message #145499 is a reply to message #145471] Fri, 17 March 2006 12:47 Go to previous messageGo to next message
> round a float value when certain global flag is set (ex. row["HE1"] !=
> null ? (unitStatuses ? Math.round(row["HE1"].qty) : row["HE1"].qty) :
> null) or highlight a cell based on some criteria (ex. (row["HE1"] != null
> && row["HE1"].attribute == "H") then set background to RED).
> use it in all the places, such as:
> - Value Expression
> - Visibility
> - Highlights
> - Scripts
> then use it consystently? Or even better - calculate such value based on
> data item position in the table row?
You could use global javascript variable.
Place to declare such variable is initialize method of Report item.
To get there just click on the margin of report and switch to script tab.
Regarding second question I don't know exactly how to do it but I suggest
that you take look on this:
http://www.eclipse.org/birt/phoenix/deploy/reportScripting.p hp
and aprobably it will be useful to know that row[0] define number of row so
probably row[1] define something else.
I didn't make much expreiments in this area so can't help you more.
In case you will know how to calculate data item position let me know.
Vladimir
Re: Supplying column name to the report item [message #145661 is a reply to message #145499] Fri, 17 March 2006 15:05 Go to previous messageGo to next message
Global variable does't work for me because it gets overwritten by other data
cells (remember I have 24 columns)
In my particular case I'd need to srore the variabe inside the report item
and use din all the places (highlights, expression, script, etc).
> so probably row[1] define something else.
row[1] defines the value of the first clumn in the data row. What I need is
the position of the report item in in the table.
Maybe there is a way to get the vaue of the label item in the header above?
That would help in my particular case...
Anton
Re: Supplying column name to the report item [message #145704 is a reply to message #145661] Fri, 17 March 2006 16:20 Go to previous message
If I understand correctly you need just global function with some
parameters.
And use the function for example inside onCreate method.
Again I don't know exactly the answer but you could take a look on this
link:
http://www.eclipse.org/birt/phoenix/ref/ROM_Scripting_SPEC.p df
section from that link:
6.4.1 Accessing Other Report Items
One can navigate from one ElementState object to another at run time. For
example,
if in a table, the header row has a data item named “A”, and the detail
row has two
columns named “B” and “C”, when we are on “B”, the following scripts are
valid:
me.fontName  returns the font name property for this item
me.container  returns the parent (a table row) object
me.container.C  returns report item instance created with the same data
row but based on item C
me.container.container  returns the detail slot
me.container.container.container  returns the table object
me.container.container.container.header  returns the header slot
me.container.container.container.header.C  returns the item C
Navigations lead to further complications because a report item can access
and modify
not only its own properties, but also properties defined for other report
items. One such
example if for the font color of one report item (“C”) to depend on the
value in another
report item (“B”). Another example is for background color of a table to
change based on
an aggregate value displayed in the table footer (i.e., if the total sales
is less than a
threshold, change the table’s background color to red). The first example
should in fact
be handled using computed columns. The second example is what leads to the
concept
of execution blocks.
But keep in mind that information outdated on this link.
For example instead of "me" you have to use "this" and instead of
"container" it seems better to use "parent". Nothing more I know. Again
keep the close look on link:
Let me know in case you got solution.
Previous Topic:Passing a variable from Scripted DataSource into DataSet
Next Topic:Sybase Stored Proc Issue
Current Time: Mon Jul 14 06:57:09 EDT 2025
Powered by FUDForum. Page generated in 0.08406 seconds
