Home » Language IDEs » ServerTools (WTP) » Trying to Install Eclipse with WTP
Trying to Install Eclipse with WTP [message #145466] Thu, 27 October 2005 18:23 Go to next message
Originally posted by: shyamp_07.yahoo.com
I am a newbie in the eclipse world trying to install Eclipse properly with WTP. Looks like I am doing something wrong as when I try to create a new project - I don't see J2EE, Web project and many others which I saw in another eclipse(with WTP) on some other machine.
Is there any compatibility issue with the Eclipse 3.2 and WTP 0.7.1 versions. Could someone write the steps in installing WTP
Thanks so much.
SP
Re: Trying to Install Eclipse with WTP [message #145479 is a reply to message #145466] Thu, 27 October 2005 19:16 Go to previous messageGo to next message
Hello Shyam,
Yes there are some dependency requirements:
# The Eclipse driver used in this build is eclipse-SDK-3.1.1-linux-gtk.tar.gz. You can find a suitable driver for your platform at here
# The EMF driver used in this build is emf-sdo-xsd-SDK-2.1.1.zip
# The GEF driver used in this build is GEF-SDK-3.1.1.zip
# Java EMF Model Runtime driver used in this build is JEM-SDK-1.1.0.1.zip
While you should be able to use WTP0.7.1 in Eclipse 3.2 you need to download theother sdks listed and install them..
Have you installed EMF, GEF, and JEM?
Re: Trying to Install Eclipse with WTP [message #145498 is a reply to message #145479] Thu, 27 October 2005 23:36 Go to previous message
Thank you Very Much Fred!! Now I installed EMF, JEF and JEM. Now I see many options in the Project creation wizard.
Thanks again,
Shyam
Previous Topic:Build output folder and .jar output mysteries
Next Topic:Geronimo failed to start
Current Time: Sat Jul 26 18:00:18 EDT 2025
Powered by FUDForum. Page generated in 0.02986 seconds
