Home » Language IDEs » Java Development Tools (JDT) » Can't run test in 3.0M7, WinXP due to java.io.IOException while creating process
Can't run test in 3.0M7, WinXP due to java.io.IOException while creating process [message #145408] Wed, 25 February 2004 12:26 Go to next message
Originally posted by: seank.nulogy.com
I have a junit test that i cannot run or debug under Eclipse 3.0M7 that
previously worked under M6. When i try to run it, the following exception
shows up in the error log:
java.io.IOException: CreateProcess:
F:\java\j2sdk1.4.1_05\bin\javaw.exe -ea -Dcom.nulogy.interceptor.eventhandle
r=com.nulogy.ultimock.UltiMock "-Dcom.nulogy.interceptor.excludes=*Test,
*Suite, junit.*, org.eclipse.jdt.internal.junit.runner,
com.nulogy.ultimock.*, de.abstrakt.*,
Mock*" -Xbootclasspath/p:F:\temp\com.nulogy.ultimock_0.9.0\intercep tor.jar -
Xbootclasspath/a:F:\temp\com.nulogy.ultimock_0.9.0\asm.jar;F :\temp\com.nulog
y.ultimock_0.9.0\cglib-2.0-RC2.jar -classpath "/f:/eclipse
nulogy/plugins/org.eclipse.jdt.junit_3.0.0/junitsupport.jar; /f:/eclipse
nulogy/plugins/org.eclipse.jdt.junit.runtime_3.0.0/junitrunt ime.jar;F:\src\n
ulogy\clearbill\ui\test\bin;F:\src\nulogy\clearbill\ui\impl\ bin;F:\src\nulog
y\clearbill\core\impl\bin;F:\src\nulogy\util\impl\bin;F:\nul ogy
eclipse\plugins\org.dom4j_1.3.1\dom4j.jar;F:\nulogy
eclipse\plugins\org.eclipse.swt.win32_2.1.2\ws\win32\swt.jar ;F:\nulogy
eclipse\plugins\org.eclipse.ui_2.1.1\ui.jar;F:\nulogy
eclipse\plugins\org.eclipse.text_2.1.0\text.jar;F:\nulogy
eclipse\plugins\org.eclipse.jfac
Re: Can't run test in 3.0M7, WinXP due to java.io.IOException while creating process [message #145660 is a reply to message #145408] Thu, 26 February 2004 04:00 Go to previous messageGo to next message
Looks like you're mixing 3.0 and 2.1 plug-ins.
>eclipse\plugins\org.eclipse.jfac”
>at java.lang.Win32Process.create(Native Method)
>at java.lang.Win32Process.<init>(Win32Process.java:67)
>at java.lang.Runtime.execInternal(Native Method)
>at java.lang.Runtime.exec(Runtime.java:566)
>at org.eclipse.debug.core.DebugPlugin.exec(DebugPlugin.java:571 )
>at org.eclipse.jdt.launching.AbstractVMRunner.exec(AbstractVMRu nner.java:70)
>at
> org.eclipse.jdt.internal.launching.StandardVMRunner.run(Stan dardVMRunner.jav
>a:241)
>at
> org.eclipse.jdt.internal.junit.launcher.JUnitBaseLaunchConfi guration.launch(
>JUnitBaseLaunchConfiguration.java:77)
>at
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfigurati
>on.java:157)
>at
> org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.jav
>a:778)
>at org.eclipse.debug.ui.DebugUITools.buildAndLaunch(DebugUITool s.java:628)
>at org.eclipse.debug.ui.DebugUITools$3.run(DebugUITools.java:58 4)
>at org.eclipse.core.internal.jobs.Worker.run(Worker.java:62)
>One observation that i have made is that the first line of the exception
>trace is always the same length (1045 characters not including the "”"). I
>don't know if this is because of a limitation in the exception trace or if
>it is the actual problem.
>Any ideas? Thanks in advance,
>Sean Kirby
Re: Can't run test in 3.0M7, WinXP due to java.io.IOException while creating process [message #145918 is a reply to message #145660] Thu, 26 February 2004 21:56 Go to previous messageGo to next message
Yeah, i'm using M7 to launch plugins that run on Eclipse 2.1. Is that a
problem? I used to be able to do exactly what i'm doing in M7 on M6. I
think that this is a bug, but perhaps launching run-time workbenches based
on pre-3.0 versions of Eclipse isn't being supported anymore. Is this true?
Thanks for the response,
Sean
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:c1kcdh$5o0$1@eclipse.org...
exception
e
g
n
g
Re: Can't run test in 3.0M7, WinXP due to java.io.IOException while creating process [message #149999 is a reply to message #145918] Sat, 20 March 2004 14:13 Go to previous messageGo to next message
The problem happens when you don't have all needed plug-ins in your
workspace and when your launch config uses the external plug-ins. This
results in a mix which causes the error.
Dani
>Sean
>exception
>e
>g
>n
>g
>>>at
>>>at
>v
>>>a:241)
>>>at
>>>at
>i
>>>on.java:157)
>>>at
>v
>>>a:778)
>>>at
>I
>if
>>>Sean Kirby
Re: Can't run test in 3.0M7, WinXP due to java.io.IOException while creating process [message #150214 is a reply to message #149999] Tue, 23 March 2004 05:15 Go to previous message
Sean,
Having a similar problem, I investigated and found out that there is a big
difference between M6 and M7 for generated command line which can be the
origin of your problem. I introduced a bug for it see Bug 55638.
Greetings
Jacques
> Dani
> >Sean
> >exception
> >>F:javaj2sdk1.4.1_05binjavaw.exe -ea -Dcom.nulogy.interceptor.eventhandl
> >e
> >>Mock*" -Xbootclasspath/p:F:tempcom.nulogy.ultimock_0.9.0interceptor .jar
> >> Xbootclasspath/a:F:tempcom.nulogy.ultimock_0.9.0asm.jar;F:te mpcom.nulo
> >g
> >>>y.ultimock_0.9.0cglib-2.0-RC2.jar -classpath "/f:/eclipse
> >> nulogy/plugins/org.eclipse.jdt.junit.runtime_3.0.0/junitrunt ime.jar;F:src
> >n
> >> ulogyclearbilluitestbin;F:srcnulogyclearbilluiimplbin;F:srcn ulo
> >g
> >>>yclearbillcoreimplbin;F:srcnulogyutilimplbin;F:nulogy
> >>>eclipsepluginsorg.dom4j_1.3.1dom4j.jar;F:nulogy
> >>> eclipsepluginsorg.eclipse.swt.win32_2.1.2wswin32swt.jar;F:nu logy
> >>>eclipsepluginsorg.eclipse.ui_2.1.1ui.jar;F:nulogy
> >>>eclipsepluginsorg.eclipse.text_2.1.0text.jar;F:nulogy
> >>>eclipsepluginsorg.eclipse.jfac”
> >>>at
> >>>at
> >v
> >>>a:241)
> >>>at
> >>>at
> >i
> >>>on.java:157)
> >>>at
> >v
> >>>a:778)
> >>>at
> >I
> >if
> >>>Sean Kirby
Previous Topic:Source code statistics plugin?
Next Topic:<filter> thats shows action for raw JavaProject
Current Time: Fri Jul 18 23:30:42 EDT 2025
Powered by FUDForum. Page generated in 0.04002 seconds
