Home » Archived » Visual Editor (VE) » Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for RCP
Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for RCP [message #145323] Fri, 12 September 2008 10:30 Go to next message
Originally posted by: sjachym.navista.fr
Hi, i try Eclipse 3.4 Ganymede (J2EE) + VE (non official
http://wiki.eclipse.org/VE/Update )
But it work only half,
-> new Visual Class
--> RCP : not work
--> SWT : work
With RCP i have the same result, Eclipse
1/ Create new File
2/ Split the screen for code and preview
3/ The rendering fail, with a java.lang.NullPointerException
Finaly, i did not use the graphical option of this (great and old) plugin.
I also try this zip : http://www.ehecht.com/eclipse_ve/ve.html
(ve_eclipse_34_200807092330_win.zip) for the same result.
Other person are in the same case?
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for RCP [message #145329 is a reply to message #145323] Wed, 17 September 2008 02:14 Go to previous messageGo to next message
I have a similar problem, I am unable to create/modify any class extending
ViewPart.
I'd really like to know if this is a known problem or whether it may be
down to a setup issue?
TIA
Dave
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #145377 is a reply to message #145323] Tue, 14 October 2008 00:22 Go to previous messageGo to next message
I'm having the same problem as described below. I can view and edit Swing
and SWT classes, but when I try to edit or create an RCP view/editor I get
an error popup that says:
Error trying to set new file into editor.
Reason: java.lang.NullPointerException
I am using Eclipse 3.4, and I've tried to install using the "non-official"
update site, the "www.ehecht.com" method, as well as the old "Visual
Editor patched as in bug 202562" method, and the error seems to occur in
all cases.
Is anyone else having this trouble and/or aware of it?
> -> new Visual Class
> --> RCP : not work
> --> SWT : work
> 1/ Create new File
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #145385 is a reply to message #145377] Tue, 14 October 2008 02:35 Go to previous messageGo to next message
Originally posted by: gemaspecial.yahoo.com.hk
Me 2. Same error.
org.eclipse.ve.internal.swt.ControlManager.refreshImage(Cont rolManager.java:934)
org.eclipse.ve.internal.rcp.WorkbenchPartProxyAdapter.refres hImage(WorkbenchPartProxyAdapter.java:493)
org.eclipse.ve.internal.cde.core.ImageFigureController.setIm ageNotifier(ImageFigureController.java:174)
org.eclipse.ve.internal.rcp.WorkbenchPartGraphicalEditPart.a ctivate(WorkbenchPartGraphicalEditPart.java:170)
org.eclipse.gef.editparts.AbstractEditPart.activate(Abstract EditPart.java:152)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.activate (AbstractGraphicalEditPart.java:193)
org.eclipse.ve.internal.java.core.CompositionComponentsGraph icalEditPart.activate(CompositionComponentsGraphicalEditPart .java:88)
org.eclipse.ve.internal.java.vce.SubclassCompositionComponen tsGraphicalEditPart.activate(SubclassCompositionComponentsGr aphicalEditPart.java:70)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.setRootModel(JavaVisualEditorPart.java:505)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.initializeViewers(JavaVisualEditorPart.java:1121)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup$2.run(JavaVisualEditorPart.java:2098)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
> Swing and SWT classes, but when I try to edit or create an RCP
> view/editor I get an error popup that says:
> "non-official" update site, the "www.ehecht.com" method, as well as the
> old "Visual Editor patched as in bug 202562" method, and the error seems
> to occur in all cases.
>> -> new Visual Class
>> --> RCP : not work
>> --> SWT : work
>> 1/ Create new File
>> plugin.
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #145406 is a reply to message #145385] Wed, 29 October 2008 05:07 Go to previous message
Leung Wang Hei wrote:
> Me 2. Same error.
> at
Please see https://bugs.eclipse.org/bugs/show_bug.cgi?id=239736
Rem
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for RCP [message #617278 is a reply to message #145323] Wed, 17 September 2008 02:14 Go to previous message
ViewPart.
TIA
Dave
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #617292 is a reply to message #145323] Tue, 14 October 2008 00:22 Go to previous message
all cases.
> -> new Visual Class
> --> RCP : not work
> --> SWT : work
> 1/ Create new File
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #617293 is a reply to message #145377] Tue, 14 October 2008 02:35 Go to previous message
Me 2. Same error.
>> -> new Visual Class
>> --> RCP : not work
>> --> SWT : work
>> 1/ Create new File
>> plugin.
Re: Eclipse 3.4 Ganymede (J2EE) + non official VE = can't use visual plugin for [message #617295 is a reply to message #145385] Wed, 29 October 2008 05:07 Go to previous message
> Me 2. Same error.
> at
Rem
Previous Topic:IVEContributor1 pallete erasing problem
Next Topic:Eclipse view plugin: swing problem
Current Time: Sun Jul 13 09:55:30 EDT 2025
Powered by FUDForum. Page generated in 0.12104 seconds
