Home » Archived » EPF » EPF Composer compilation errors
EPF Composer compilation errors [message #13508] Thu, 08 June 2006 03:07 Go to next message
Originally posted by: razvan.gliga.gmail.com
Hi all,
I try to build myself EPF Composer from CVS HEAD, following steps from EPF
Composer Development Guide
(http://www.eclipse.org/epf/composer_dev_guide/).
But, I have following error at compile:
“The import org.eclipse.ui.views.properties.tabbed.internal cannot be
resolved” on AbstractSection, BreakdownElementGeneralSection and
TNGPropertySheetPage classes, from org.eclipse.epf.authoring.ui plugin.
I find that:
must be:
import org.eclipse.ui.internal.views.properties.tabbed
I use Eclipse Platform 3.2RC7 (I20060602-1317) with some features
installed from Calisto Discovery site.
Am I do something wrong? I must use some branch from CVS?
Or, I must fill a bug and maybe a patch for these errors?
Thank you for this great tool and project.
Razvan
Re: EPF Composer compilation errors [message #13552 is a reply to message #13508] Thu, 08 June 2006 13:14 Go to previous message
Originally posted by: bxu_1999.yahoo.com
Razvan Gliga wrote:
> Hi all,
> EPF Composer Development Guide
> (http://www.eclipse.org/epf/composer_dev_guide/). But, I have following
> error at compile:
> �The import org.eclipse.ui.views.properties.tabbed.internal cannot be
> resolved� on AbstractSection, BreakdownElementGeneralSection and
> I find that:
> must be:
> Am I do something wrong? I must use some branch from CVS? Or, I must
> Razvan
What you are doing is correct. The current development environment is
based Eclipse 3.2 RC1 which has changed the related API since RC2.
That's the reason you were seeing the compiling error. We are moving the
development environment to the new Eclipse soon.
Thanks.
Bing.
Re: EPF Composer compilation errors [message #563850 is a reply to message #13508] Thu, 08 June 2006 13:14 Go to previous message
Razvan Gliga wrote:
> Hi all,
> error at compile:
> I find that:
> must be:
> Razvan
Thanks.
Bing.
Previous Topic:EPF Composer compilation errors
Next Topic:Use of EPF for new published method - MBT
Current Time: Mon Dec 01 06:11:51 EST 2025
Powered by FUDForum. Page generated in 0.04181 seconds
