Load Resources at start up [message #145091] |
Wed, 01 August 2007 13:31  |
Originally posted by: prodanov.tk.informatik.tu-darmstadt.de
Hello everyone,
I'm on a problem with loading resources at the start up. actually I need
to create extra dynamic palette entries,which I want to load from another
model file. So for this purpose I need to load the File in the
PaletteFactory to create the entries. The "Load Resource..." functionality
from the right (mouse)button menu when on canvas of the diagram. But I
want it so, that when I open the diagram the resource would be there. I
need the code lines where actually the loading is done.
If anybody can help me, it will be great.
Cheers!
Martin
Re: Load Resources at start up [message #145097 is a reply to message #145091] |
Wed, 01 August 2007 13:37  |
Martin,
Probably this is using
org.eclipse.emf.edit.ui.action.LoadResourceAction. All it does in the
end is
editingDomain.getResourceSet().getResource(uri, true);
Probably you should look at how your editor is using its IEditorInput to
load a resource during initialization and use the same technique to load
your additional resource as well...
Martin Prodanov wrote:
> Hello everyone,
> need to create extra dynamic palette entries,which I want to load from
> another model file. So for this purpose I need to load the File in the
> functionality from the right (mouse)button menu when on canvas of the
> diagram. But I want it so, that when I open the diagram the resource
> would be there. I need the code lines where actually the loading is
> done. If anybody can help me, it will be great.
> Cheers!
> Martin
FUDForum. Page generated in 0.06903 seconds
