Home » Archived » COSMOS » How to creating a Data Manager
Re: How to creating a Data Manager [message #13610 is a reply to message #13589] |
Tue, 26 May 2009 23:26   |
Hi Saurabh Dravid,
I've solved the problem. My Eclipse have all the features you list,but the
Feature Details in Eclipse did not show the information .So I installed all
the plugins again,now this time,it works.
I want to know wheater I need to config Tomcat with any steps to run the
COSMOS Demo? I've followed the COSMOS Install Guide which says" The
configDemo program accepts four parameters",but I got the information
"Invalid Tomcat directory...".I've checked the install directory ,there is
on problem.Why does it shows the four parameters are all invalid?
Jennifer
"Saurabh Dravid" <sadravid@in.ibm.com> ????
news:7f7240256b5df632d96fb1da2e3b35c5$1@www.eclipse.org...
> Hi Jennifer
> Can you please give details about your eclipse setup.
> I am using eclipse having following features.
> Eclipse Platform : 3.4.0.v20080610-9I96EhtEm-T_5LxIsybz-3MdGZmOA3uwv7Ka_M
> EMF - Eclipse Modeling Framework : 2.4.0.v200806091234
> Graphical Editing Framework GEF : 3.4.0.v20080115-677-8082A5696H274A
> XSD - XML Schema Definition Model : 2.4.0.v200806091234
> Web Standard Tools (WST) :
> 3.0.1.v200807220139-7A-8c8QqT3lv4VSXAI28OHWz-I88
> J2EE Standard Tools (JST) :
> 3.0.1.v200807220139-7U-8k9LJ7Lo2oV080cQz-eAPH2D_
> You can find this information for your eclipse setup in
> Help -> About Eclipse SDK -> Feature Details
> After that I downloaded Tomcat 5.5.27 zip file from
> http://tomcat.apache.org/download-55.cgi
> and Axis2-1.3 zip file from
> http://ws.apache.org/axis2/download/1_3/download.cgi(Selected Standard
> Binary Distribution)
> Then I unzipped cosmos-sdk-COSMOS-1.1.0-200905140505.zip into my eclipse
> setup.
> Started eclipse and go to Preferences -> Web Services -> Axis 2
> Preferences (Specify Axis 2 runtime location).
> As soon as you specify Axis 2 runtime location, you should get this
> message.
> "Axis2 runtime loaded successfully". (are you getting this message ?)
> Then I created New Dynamic Web Project by specifying "Apache Tomcat v5.5"
> as Target Runtime and selecting "Axis 2 Web services" and "System
> Management" Project Facets.
> Once new project created, I ran it on server in eclipse. I am not getting
> any errors.
> Let us know which steps have been working for you.
> thanks
> Saurabh Dravid
Re: How to creating a Data Manager [message #13631 is a reply to message #13610] |
Wed, 27 May 2009 07:30   |
Originally posted by: david_whiteman.us.ibm.com
Jennifer wrote:
> Hi Saurabh Dravid,
> Jennifer
Jennifer,
Can you please post the exact command line you are using to run the
config demo program?
David
Re: How to creating a Data Manager [message #13650 is a reply to message #13631] |
Sat, 30 May 2009 23:15   |
Hi David,
The command line I use is
D:\cosmos-demo\bin>configDemo c:\Program Files\Apache Software
Foundation\Tomcat 5.5 d:\cosmos-demo d:\birt-runtime-2_3_0.zip
Jennifer
"David Whiteman" <david_whiteman@us.ibm.com> ????
news:gvj88q$92r$1@build.eclipse.org...
> Jennifer wrote:
>> Hi Saurabh Dravid,
>> the Feature Details in Eclipse did not show the information .So I
>> installed all the plugins again,now this time,it works.
>> is on problem.Why does it shows the four parameters are all invalid?
>> Thanks,
>> Jennifer
> Jennifer,
> Can you please post the exact command line you are using to run the config
> demo program?
> David
Re: How to creating a Data Manager [message #13732 is a reply to message #13711] |
Tue, 02 June 2009 22:57   |
David,
I tried,the result is as follows,
D:\zengjinfile\cosmos-demo\bin>configDemo c:\Program Files\Apache Software
Foundation\Tomcat 5.5 d:\zengjinfile\cosmos-demo
d:\zengjinfile\birt-runtime-2_3_0.zip d:\zengjinfile
Invalid Tomcat directory: c:\Program
Invalid COSMOS demo install directory: Files\Apache
Invalid path to BIRT zip file: Software
Invalid path to axis2.war: Foundation\Tomcat
I found the point is the space.So I installed the Tomcat again.This time the
console is
D:\zengjinfile\cosmos-demo\bin>configDemo c:\Tomcat5.5
d:\zengjinfile\cosmos-demo d:\zengjinfile\birt-runtime-2_3_0.zip
d:\zengjinfile\axis2.war
This program will install the COSMOS web applications into the Tomcat web
server
.. If you are using any other web server, you will need to modify this
program o
r install the demo manually.
Invalid path to BIRT zip file: d:\zengjinfile\birt-runtime-2_3_0.zip
Does it means the other three parameters are all valid?
Jennifer
news:h0497o$fv0$1@build.eclipse.org...
> Jennifer wrote:
>> David,
>> I've tried.It didn't work.
>> I just want to run the cosmos-demo to become familiar with setting up my
>> development environment for building Management Data Repositories.
>> I've studied this for a period of time.Now I feel helpless.
>> Thanks,
>> Jennifer
> Jennifer,
> I have modified the config.jar to print out the value for the failing
> argument to the console. Please replace your copy of bin/config.jar
> with the attached copy and try again, and post the results here. Also
> you might want to check that there is a "webapps" folder in your Tomcat
> home folder.
> Hope this helps,
> David
Re: How to creating a Data Manager [message #13752 is a reply to message #13732] |
Wed, 03 June 2009 20:59  |
--------------050701010304040306000204
Jennifer wrote:
> David,
> console is
> server
> program o
> Jennifer
Yes, I believe that's what it means, because it does validate all 4
arguments before exiting if any one is incorrect.
I would have also expected the following to work:
D:\zengjinfile\cosmos-demo\bin>configDemo "c:\Program Files\Apache
Software Foundation\Tomcat 5.5" d:\zengjinfile\cosmos-demo
After looking at the source code, I realized that I had introduced a bug
while adding in the extra diagnostic code. Please accept my apologies,
and use the new version of config.jar attached to this message.
David
Content-Type: application/octet-stream;
name="config.jar"
Content-Disposition: attachment;
filename="config.jar"
UEsDBBQACAAIAECnwzoAAAAAAAAAAAAAAAAUAAQATUVUQS1JTkYvTUFOSUZF U1QuTUb+ygAA
803My0xLLS7RDUstKs7Mz7NSMNQz4OXi5QIAUEsHCLJ/Au4bAAAAGQAAAFBL AwQUAAgACAAS
p8M6AAAAAAAAAAAAAAAARgAAAG9yZy9lY2xpcHNlL2Nvc21vcy9kZW1vL2lu dGVybmFsL2Nv
bmZpZy9EZW1vQ29uZmlnJEphckZpbGVGaWx0ZXIuY2xhc3OlU81u00AQ/tZJ 49SYxA2l/P+1
odgJxAVV4hCEEEFIIKscioLU28ZZko2cdWS7SLwAEogX4B164UArceABeCjE rBuRRnBpkLW7
M7PffPvtzPrnr+8/ANzHlgmD4UmcDHwRRnKSCj+M03Gc+n0xjn2pMpEoHlFQ vZUD/xkFO7lZ
f8mT5zISNAhiosjgjPg77kdcDfxXvZEIMxMlhloelbE/QzOUsqFM61sM28Hp j25T/iOpZPaY
4aG7CIHXZSh24r5YBsNZGybKFgqo2liGw1BwNaAaSCV29sc9kbzmvUjQVYI4 5FGXJ1L702BR
X4Xh6QI65muor8XDUEwyhhU3OFm2trdn4SIum7jEYJ/csXEFVxnMgch2+Jjk rLpeMOvDbpZI
NWiXcZ2EtkY8sXAT6yZuzXXrGGVjA3WGslD99I3Mhgzn3b+pvD2CTHg2VPlx lXmdDO8Xasj/
F8/rWtRLT3fQYrB24/0k1HuksTpLamm1VMIXSomkE/E0FamJFsOD0wuglzMn gSpLT4fGEpjj
6DdFf1gBhlZE0TPkbZNn0Go1mt9gN45Q+UqegRWaS4SB8QE1sm1tU9Y5rNJK jcDalCGYMjjN
Q1yoXTvEjS9YKh4UDv7wVOhMGB9hG59QMT7nfGvHOVM+bd3GJqkEabszZd4k TEHraDSP4P5b
l5GPRj43cTfXyOi7Bx/Gb1BLBwi9xL/JCQIAAFQEAABQSwMEFAAIAAgAEqfD OgAAAAAAAAAA
AAAAADgAAABvcmcvZWNsaXBzZS9jb3Ntb3MvZGVtby9pbnRlcm5hbC9jb25m aWcvRGVtb0Nv
bmZpZy5jbGFzc51bCXxU1dU/5857My+TF5YkExgWHRA0ZBVU1AFBEoJEwyKr gBYnyQCDk5kw
M2GrVq10s9bu/RS3ulS01S4uCYrV2lZs7eLaulRq61Lr595Pq9Uq3//c995k Jovayo959917
7j3b/557zn34wId33k1E09W6ACmmGenMxsZ4RzLRnY03dqSzXelsY2e8K92Y SOXimVQsic7U
hsTGxvnobNbNABlMozbHtsYak7HUxsYl7ZvjHTmmEQta21rWzzutdfmM9avn LWMqb+snWp7L
JFIbZzGVYZFsLpbKrYole+IWlTCVxLYnsjMatsUyTGOXLmtZ0Hraer1WU+uy FeuXrVy8onVR
i0U2k92eyOTqMz2pXKIrjonzW5c5DC0ayWTqdUAl3ctblq1qbW5ZblE5k5WN Z7YmOuJZplIZ
XN3SNG/pUoyFmALb4u2x7m4MjS4Y8pYdC4ldgkZ3+ZJcuqsjlpufgLgBsZVu lYpoaxPdS2O5
TWCoabVG/tmJVCI3h8lXPW0Vk9Gc7owHyUeTbJpIhzCNbEuk4ot7utrjmRWx 9mRc7JbuiCVX
xTIJeXc7jdymBGQ8uu0/dxisbsLkGfioqnrdYKdMW1VCTNNsCpNfWrU2jXNa 9TaNd1qNNk0g
fxCt6TbNoKNgra2xZKIzlouv6DcHVFxbQsfQsQGaWYSR5TuyuXiXTcfR8aBK 90CUkCNIIt24
FFLkIEs81jUrQJB2zEARm3oSyc54xqITmMa1pjTniMM30pnIAH7pzI5oJEhR mitmPRHLVw+l
qFA02dRM8+EYODWe6oSWQ5EO6nJlmCVLLLDpJFoIN+fSziBTZfXgKaA9mdoC dApTxRDK2rRI
JA10S1cyJcZdYtNSMe5Iz7jzHXxZhP10hKd585Lli5Ysj4jbIwnZTclksRmY Vti0Uhaq9BZq
AjwFV7lEOmXRaqZDvdW6gdhILh2R3RbZmeiObEgk484qa2xaK6uM9VaZJ7Be Hcv0r3Q60/iB
K+X3s7PKp2xaL0g34tsTOemI2dQuy45KZPWCrY4O8U6L4I45ui+SyEZS6Zyn X7wzEksNwcEj
686ktyY6450NEYs2wNzukjIca09nchgJ0ibaHKBEMTC1o2w6i5LwxFaJSUsw //BCSDgBbghI
zLIoBRA0ugFCVOu2aQthJ5T1pGBKz1zw3RAYGwJ1ay3C1jh2QSwhGuf63asV jqRTESf4NEQi
Q2ho0Vam6tZ+i3mT5nXHOjbFvR0jwTCeaQjQdsRKD5cLwDFI22in7J9Pf2KB V8mcc2z6DJ2L
yJhMZHOykATT6mnr2goXnyWU59v0Wdk4gY3x3OJYl+a4Szh+jumw6mL64bh9 waYvCnr8gFM2
l7XoQnh0dbw9Ah8kEw4ugYKLmBYPBlF7vCPWk41HYpFtA2ZsSwi0YKUs5Iqk 5CeWxDbt3BFx
GDWIfy+26av0NWC5I929A5toSJm9t2mrLPqG3h8e+wFMo5DzW9jtA6S36DvY c5GOdE+yU8vf
Hu9XoUEC0CT5uVQC2e4B8WtYsHrxy6LLsT8anRiyLN4N6KxKxLfFM6LelTZd Jd43NXwtuhpu
WSnNbgivAwQwOXiqRdcynTC4v7HgUPSO7foZ649af2QjVHZoWrbHurqTyAS+ h5NvaKn22HQD
3QjUdKW3xjvloPkYu2Mb/QBnZXO6O+HJLZbfqleEOzXH4VS5men4lkwmnYmk Ozp6Mhlx26Z4
KqJN0g1LfoQhsAV/xDTTDQj9QVl7cUO6ByEMfyHDECEcc3/CdEhRttGIdKS+ dfGCRi+BsehW
bFrBi9sDBN3OdPLHId2j/niUW9SHE7gYsu5sgesdSHUK2Fu0D/HKk+4/Vvin TOGhFU4m2i26
h2mCN+wssLK1kCJA9zKd+J9nRFNOjmUEKfibE4j9jH4hQeiXTDuq/5sE67+Y UyyCG9r2SyC9
n2lqMbw9mgEB1aJfM012QS7Wi2zGgSind7YfnStbYebfMM1amkkjkezKFqIa pBEJZALqj1zg
dzgSix1RtM2LnPYgU93HCDVgyzzM1PLfijdgqUdx8jgOqIc74qmcI9MfENKS 6Y1Hb5Yk4HGb
nqAnmYI6Kc6uTkjGPmS+iDjyJxyFw2rjcIo4nBCYD9AzAfqzl+3ppVq2d8S7 Jajb9Bed7nc7
CWCs46wVmZhsoGcB4f9c+2LWFj0P1DQOvZUEe05Xw/aupEV/Q7I/uzuWweYH rHQQOGHypnQ2
J63JkWS646x45wmTc5me+OQ5Fv0dJ0wE/33iKRKy/9eml+WgH4WDXpczC11i i15FAJvdmF9M
k79u0xv0Jsh7uiXNlJKoNSUgRyz+RInI0M77Pxy+/bmUs3YkbwlY7W2cOSt1 d2dR/zuoeIaz
ZjKWzcazjRpODcg7u+OZXCKelf07N0DvocjydmlTz4YNcThzGeJrPBOgfyPa eWOtqe4etw7w
hj/0Kh93gxeQBOkDWI0mMktmNTDLCNL77JNRFOZj+0cL5muif7FfiALAZz+R w9wdL7E5qOsa
ORHECRaj6o44quJ3I/YYQl2DG+oaHBCegE3FI2weyaMwFWjLxRDhYfpCzzVv imWWx7f0xFMd
ckAHuRx7hSsKKqPWJfm9IrKEbK6SDWN2JNNZqZh5rM1hHgcWwFSzeEEUKUx0 dOesIE/gQwI8
EXttwJDNh3KEaYQ3vy0tusMpg1dxhmZZPBnLaP2darEhtz0X5Cl8eICnImgM OcvmI7gasoHN
sng23ZPpiM/LOn7Azhu+2BzgsgDXwJ2Frl7Sk+tHBE/jOnFnPSA8ABFr4U1u 5OkBPhIVoDdU
ONvmGYwU2tyWSeSwxwLV65paW2XWMXxsgGcWeiVVMOk4RvluCDgwF3OmtcqM kDALWYzifPYw
m8ZLEBqXL2pbNH9Z46KWFfOKBnRk4rlMkwaFmUw6nWvIJxaISDwPZoy4/30s uYCz2eb53AI9
M/HuJIKuXIQ0Nw9V0PFJTPM+oRLZrmQ9FkxnE8KpMKRZ3MpUMyjyFCqL5CgT wUIRrNRg8SnQ
3AtEH0G2CCflx0qXi+Xmx3KxRbFUDBt2OFsvYZoyyHhAb/uOhqy+rWnYlO6S A4BPxYE+rLmH
nLEcW6MRysTaY9l4sWFWMs34eMPgZM4hG0U9lHQ1Xw2fD2ugweRr5LIwkz4r nulslz1r8TpU
DcOYzpMUIZzPsPlTurrsOgsgkqjOZ9ock6g4Eht6Xns2nezJxaWisbgDhX5j ng2kwVnGcZs3
8EacZXJ4OztnRdo5yw4fOjgPqho5IcW0HJtyxsqiZ9mclAOy3EXwCvBMOUek xSmmif0JuyNP
xFNKzGxxNzLFwbcKA0gbAoxoOLFQmsXp3ALJ4vOhGfs/ltkooXeIm0SYoyOd ka2XEPVAxWsR
byUVdi2vq7cRxQpjX2Z72sXasPG6gWOjnBuPwvliHtlhPv1mdMazOXTE83eK xYmXrLFtQLUJ
80otmUvrFUaKgB6onDWzma2QJig4QQKp+ywU0F4TqdgG557DjxwSuADcMjoT 9UhsJzPzXo0N
GgCB7lhOKgK0UvFtSZywTCoDGNn6jJFsAtmSdr776h0/TgHRg2wCobe9Z0MC a4xtGzrTgMaG
s3b/JWvB6YphJdNDQ4IRsbFtqCMDAz7wxdx1TWgm41jBl0iLUp3t2t1yCa4B Nb9d3waPgIre
5tBalRZ0BOkYvtam9XwdhK1u1fUPX2/zHtl8pYnsfC+CS/+NNn+ff6DzEok6 K9JDZEFrxciZ
NI5YlcO4JW0HUyVi+3QGLxajwj5ycTpyhAunIwoqVqdaTaS8azIJZjLcIE7W XRbf9gmmF1a6
Mt3iXqbpMsuD2Cea5n5ccAxXAE6xx50279NBKpF17u028U9tvpvvkVuxLT2x ZHZAQePdCsFI
tvdpwglJllzRuE094rL4pc33CQtTx0HYtlt/2BjRvw+djmDhxgzmMZYN8G+8 /Kgnl0g27kx0
N65NdGtx+QGaix/+vc0P8kNQFBslk5DdlM/E9JyWVE9XPKOvxGaJjo/Y/Cg/ Bh0Bvo3C3FeN
DAQDf7T5cX4CAx3IMuflHEQ1W/wUwkKjxU9DspX52xuLUaEZTlj8C9ZoaGgo 5Wf5+QA/VyRx
AXebX+C/afxuz7WgToO8A2/8XQsH+O9eAVCodgsU3BHkF/l6/ND5YuBXbH6V X0PERPRYGgOw
XS+Mqp5WjGyx1Bs2v8n/cFLXgs2KKqW6bWhmwySVSBtprqj7ts3/1F8aNsWy i9KZuKtWVrjJ
VzGs5YQstRN7fsxgLl7o3ikMe7qKaQo9B2MjyezKh6vBosJxiAwaQRIWHb4l 3dooOpJUFX8R
29HtfRWbMTTP2bXDsZoj19DKtJVfBXSUlKMjlL+rLvp4gwwbpekIJ4P3vnig w4n4/R1WB2r1
TghrqTJsmAYo222pkVh+5YoFx6E4U6ORqKtypIQfdf4X33QHVOUQleRqydcz AVXFNG6oIO2M
B1VIjRWWYaba6qGj+ZC366pCjZd5E4pKRGdRd/wQlA50orQitpokBZq4TGpF 9KEUgHWn2Gqq
jk6d8WRcygtLPOqEi4CT8XXKB02YaagzzGWHfa1qbVWnUOAE3axnXjLJdNwn +zIxVHZi5iRt
gkAQWX/rCarp6qiAmuGVSal4Dp5BmtcJf6JgVEerYxAyCy8xpMR2Fx9APUtW O9ZWx0myWIo5
Qi5fOQIq6qVVMmVl6qxUeltKRovSKqySP3wHLg2ZvesW5LFtH7mW7LgulODI G9U8WzX1Xzs5
J9uSVHKHjM23VYuMBfXYyiyqBbmLmSRjC206nI6w1MnYAkFLtTHdtWJTIivf 2TYimY9sS8in
JzeNlPtk9/ga8IEjCxoE2lz/xyfvOjmekW9YGyI70j0RbPRIT1bfc6V2RNKg zhTQ1WkazTAV
d/LXLuRtG3ZEcoUSoQwolEefo12xFA7D5I4GSy1matIqRiNOKiVXsZF1+W/5 Z0TWObcZTrvg
wwXevCPzDEst1cVQflp0wLe1QZ9jLbUM+z4SyS8e9Uw1f8jPt5ZaoTkUCBAt /kS7zPmOkv9U
a6lVyC8iEU/IaKQ6rXEQS06LLHVnikn6P5o6ETa4XEc259gZ2X813SDoAupb U6l4ptm57sI5
VXRhTZOAFB8RBWkcmeTHWwBviiy8BwveS/FeVvA+Au+jCt5H472i4L0S71UF 72PwN4x3aY9z
n+Pd5wT9rADtRDoEv4firZEkaBOZNX0U+Ykmm4xfv+6socPwazsENIWm4skC dGdy2QlgOo4o
8OWaWt+M26m6ptbAo6am1sSjrqb2bv91VFLrn7GHDL6dGowTwOTI3XTILXT0 PoquKZ/dR3Nq
bqPqXprXSy291OoTisUFFKc6FDXFFMsLKFY5FHWFFLdRw36aCsLTCgjXOYQN BYQTdpN/L50B
wjN306kyeD9Vgb68A8PyjOMpBDIki4iwe2kjVirvctbpo/RuGiG0WdDuoVJp 9qC5j7YJeU15
ZR/tWFzfS2dHjbCxn0vcgWo9EDV9M/176CthI+SfEQ3IWNgMB3rpvD66IGqF rV76/KU01dPh
S+CsR8G8/Mt5TfZQa004ELb66Cse5dcLKD2iKdESb/ibhQt9O0+zy88hf9i4 ++qDW0TnOqHt
o/8Jm710SfllnsZXiI7fdXUMm+XXiKx+9+U6eQnUhP3hQB9dv1pIv6+5j436 5eWmfjP9sNBM
o7U1hNPZUX/Yv59uzhvqxzIU8M20xFD+kDUjqo0IjUtcQwXDwWJD3SL6lbj6 3VZsqJJwsMBQ
vQWU/YYq9Yb3Fi5UYCiLQ1bYL4ZylbmzX5nq8ru0xPnXu+XVCqPjZ2tquI9+ 3kv3RUt8M4Ng
pTWxwiWh4AxXmdIa/RYuhZS7gsgRwiXg85Qw+ZUWrywalJcHCjn+VlgEB7Mo 9VhglVCpx8Ku
0W9hW1iUcqi0n8XvXRZaqYcKPfSIsCgdzMLeQ0djOVsWL3+sl/64myZplqVe r7Asq9Fv4TJh
aXPI1iwfEC5PaZblUTts99LT0vNXzbdovz3n2D5ql78QLdOueVE2dB+9JJ55 xR0dURO2w2Xh
EX302syRoZHu1vxHP+beGrzyP925o7TQo/ro3ejo8GjBEzf7ZpZztGIf/WvN Pnoffz9YEwZQ
D/ax6mMzWsHRynBFL1t4VN5P2MjzwpUVXNrLZZcefMmYWb7n4HMy1MujwxX7 6SihrdxDtdGq
PXR4NCR9ZW6fGa0Kh+4Z0BMq300/Aw+Ohmp6eUwvj6/gSb18WLRyH0+DJEYf 10ZDow26y5Il
y8KhcJUvBLqGcGW4qpePXjNzzBUHX9lD7Vi9cj9ZIko0HNpPm8OhXp4lA+E9 dAZGq0TGIpKT
XJK5QhKNji0eLXNHzWg4PPaeYceKTV3Bsz0vVvAcx40VfKJ7Cow6fVRjLzeB ooIXDOfPkXBi
BS/UDrV1++RBHq3gtn42iz02S92jpJDNso9ms6KAzSq08044TZxQLngZyHmt FyTfjVbAkfT5
3VQiDj19tVBKa71H2u4yr9S4q5QpoZpweTjUx501gqNNgu4+3rzaDUYV3CXR qLIgUlVEy8Pl
zqap4DS6fkKV/Fm+jvfQAX5UTUZlcUD9QP1OPUQHfMf4kr40npf4HvQ9guf7 RpPRQgeMZ8zx
5nguNyebdWajfp9sHo0Tf6Z5otlMB8yF5jJzJZ7t5pXm1bzFvNbsM+8Evbzf g+d+8ynzgH6/
1nwW8+5BjzyfN9813+dyP/kr/WPwfDGwLbCTDjgphnqEbkM6EUUKMQtZzmwK 0RykFvOompqR
lcynhdRCJ+P3VGqlzWglaTFlaQldREvpYlpOl9MKup1WEk552kdr6G46g+6j 9fRbOpMeoxg9
Te30DCFVow1cSpu4grp5Em3hIyjDdZTlWZTjedTDC2krnybX1rSdz6Ud/Fk6 my+kc2DBz/CN
dC7/CnSP0uf4dfo8v0NfVgZdpEbTV9Q4uhjW/Zo6gr6uZtC3VZR2q1a6TC2l y9VKukJ10pVq
M12lttB31fl0tfoSXaNuoGvVD+h6dSvtgUdugA1uVG+C7iDd7AvQLb4qutU3 lW7zHUO9vlnU
51tMe31r0O6kO+G5fb4tdJdvB93r+yL93HcJ/dJ3Jd3n+wnt992F9v30K3j1 177H6AHf0/Sg
72V6yPc+PWIwPWqMpseMKfQHoxHvUXoCXn/SOImeMtroT8YKetZI0nNGNz1v XEgvGN+hvxmX
0YvG9fSS8UN61dhPrxkP0+vGk/Sm8TT9w3iG3jLepbeN9+kdU9G7ZpD+ZYbo PXMs/dMcTx+Y
E+lDczKz2cgKKDpozkS7Ge0WNs2FaK9EezUHzNPZMtdzidnOpeYWts1zeIS5 i0eZX+DR5tfx
vJorzGs5bN7M44C28UBayLyXq8z96HsIfQfQ9yyPMZ/H+2t4fx/vH/AhyFzD /iCPA+LG+8N4
n8iH+WfwFP+xPNW/lg/3b+Aj/GdxtX8b1/jP4wb/pdzov5KP9N/L0/2/4xn+ R/go/5/5GP+L
HPX/k08IVPGcwCE8NzCFmwJzuDnQyi2BU/mkwHpuDezkkwNn8ymB87ktcCEv kXRZVdOxkhK7
6TJanOUcEubqQAf38FZSPMm/mbfxdvJBkk7ewTuRHs+id/jT6DN5Dn2bz+Zz yA9knsefQV8A
+Ozmc9GygMhD+Tw+n0qAw0nY6dvJDzRW8gVCByxaetSvWs0m3iXrqaXmLP4c ePiByMs0j4Da
6PKwgE6HRwkw6vAIApUOj1JfldHDn5cZvqnGBv6CSOA7xljFX8R6Jb7jqE6v EgROS/lLGC0F
Qh0Jgr4vGj6+UNbzXebSlQKrDp0NlFouj5d93+Uv67kf0mxNZwOrDl0ZUFqm 6Wwj6TuUL0Jh
YhvdvvH8FbTKjAt9zBejNcL4jnqbvwrrjjT2q/v4a+gbZTys7uSvY5XRxtN8 An8Do+XGMxzl
b/K3qAL4jfC3QVcJxJrg8R201tOd/D98CVrtiCvH8aUUMnfRRN7Nl1GV+QUK 8uWQb4x5Gbzj
tO7F3Cswt8r/T9rFV2JueaCKOvkq8K0IzIFG3xUegVaazlejLxQ4m0ZojcpR 963P12HTdJGF
oGns5Wv667AgnsTLAJDluhZT+u8NdKM77VEydOG3qBZ582LfTGMPza4PGTOi phwqdZJO6+zL
jxZ/71KqDPt1oowE0Az7JUGXZy/fsHqXwSGjHinZL4yb8uwPpxKwXw0dT4NH 1tBoXgurraMj
+XQ6nj9F89B/CiKniLbQEcTDPS3im6Av69bNaCmUkAv5h0COD1Vvs/a0gXr2 SP6R4JQiwLPg
zw/KGXSUq+D1oJG6uU0O2fvJ9N3kpbw4L9tqtTLTa7VuNUWV1aI6R9E6PWYa N+kj8sdS9/Xr
NxmSEHdSCccpxBvoMN4IP22iuZyAbmfRydyldYs4Mri6hehYvkXrNh21dkjr puQforsy/wUy
G3gmvdS5X9S1jqjLi6pDV9SgiOpkrBV8qxa0qDqSIlLI6gvIbtdkxk0FOs1A wU68hWzO0DjO
UjWiz0zugU5bodN2WsI76Ax4YQN/GqfiObQZp95hutjXMrs62nQm92kdq6nJ 1XEJjee9ErfQ
XpvXdrN+p7z5G/q1HQtt77iURtdKZWD18l3aEQWylgtPvgCy7qLD+XOQ9Qta lipnxbwsh/DP
tCxK/pX+MHzrhuFbiopkaL4Xge9XwPdi8P3aMHzvdfm25/meiblCFcnDbQyc 43K2az24DeL2
Lez7b9MExIpDECX6uUVcbiOonH/ucttCGZfbA5grtzZNej9DxWIUuPuhvnyE 7HIjbPTyL3Rv
Ta2016NY30OBqCkYkf8thY5HpuVmYNAzCLkuB/qvoDF8JYURq6by1VTP11Aj X4/YtYfm8A10
In9fyzvHkSS/w5t4v3tR1MT3631bgqjwK42QqYiaoo2BWUrHOxPjV9Gn8fZr zDAw74BoqFZh
pAxy1OzjB9bU9vFvoSH/LmrUuYm6XApI9HrY6OzlP4xqvIrG6VTa9PLoJ908 2synyX9Cf61O
8A/gt063ninImm8NG3fwXxm11Yty19DLL10qdx1ONu8tLP3/25/NB8IByeL3 0NZhiNzbmwCI
e/ll9+5Gsn9L5tUL5evREl24Bfr4/6LB0RXfQt1WKnVbMFzqC9lSt5WES3Xd ZqNuC5dIQRVE
LSXyvsW0+2ArbPOOHA8+7cHNcv3GP4QHf0Qj+cfw4C1Uw7din/dib++ls/gO ZLb7kMX+lK7i
u+kGvpfu5V/Qg/xLepzvQ43wK3oB/niDf4v84/f0Hj/IBv+eR/PDXMWPsOz3 qfw4T+MnNAIu
oZHiKQ8BXMPvOghA61wHATyJ/8XvQb6RmP0+/xueDmO9z2DUpG10HX/AH6J9 FSgPSmZB99Ja
JReOAXqQ2hRLjkEvIGLJOVxCb1CtPoeD9A5N0edwKb3nnsM2j0B2oFtKuReV mqvy6T36Vfra
QLRxG/jIObXL2ajNddpJFkLvL1bX9irDOUMn66BSKycp9pXeem5bbi+8k/IA imO5Eqjto4OL
xbF1fcqKGo5fTfGrETZ9ITi+oV4QDLf6rzj4ar14FZtzVv8xfzJiBPHTyPQO IEr8mSr4rzSW
n0WkeA478XmcN89RFO8n8d9pKb9Ea/kVivFryDNepxSeO/lNVCv/oAv4Le2n DbKzaVd+p+5S
Je5ZvEsFdSwfS42qFCeDj8bTNPcslv+VSqzuQ3Sfpq1uoI6arK1uUqdrdT+8 aLstJf90Z6CN
6VY3Zk33bLLYMQkMa9eHDV8ItmjQ8QkWMa84+Bp8Ea0vMohzML8DkLxHowCi Cv4AofPfCNQH
qQ6+PlJxQdIxPa/odK0A69aXtKIlOMBEFR+NQoIhqhhUgXVFAROzbLel5F/U OkFXnYFV5RA9
FGDQQJAAoO8mEXlLxZV35EOvRINaNxQpuz9e+Dka4KhVdHVkAigVakSfGiW3 R4F9qmLNPhVa
o2OCH3bSY2P61LioxdESCTgWHiX6ZikZMnbT2HBJnVwu0ciwVd+rJhoC1qBc H+IFgUYduufg
b2RKLz0dDsidDNaoDFtyJ4PRyXInU+q7SS4KhxkMB+8ZfszsVYetDutc8obV IZwoJk6D2/Hn
AN1FDyEZPYD3u+hxmP9JehUGPUBvcwnb+RPnYl0hIaNTiPkqQBOVRYcqm2ar ETRXjaQm1DKf
UuW0U1XQOSoEtFah2h6DynosqugwKufxdLOaSLeoSrpdRahPTaK71OG0H5XP o6i8/qAm0+Nq
Cj2JvufQ9wb6/qFq6W28H1RHsK2qeYSq50rVwBPUkRpC3YgocHU+ph0KWiem HaqrDKVbUmX4
ULFNwCpbAaEyLueLdN46G5yqdd46l/4C+H0L4GmCxsepaQDxOQCfVBklqCdM p3LDfknmobYI
1MJ/Yh5ncog7ODM+Cc5M1lArwplRhDN/Ec7MIpwJROVksuS80jhLhS0HYlVo AGM1cnEtGJgo
SHNaAIcg7dfOIfe03NbrVSoFOmUyqgETBNJKhh0Ml9wz/JihkWaKCW5YrYE2 l27DnwO0D8fE
I3jOReuP8NcT9Aq9jve32OLSPNAu1FdMR6OYnUnj1LE0Qc2i49UJANocAO1E Wqfm0TbVBKDN
p/NVC31JLaBvqJPoMrWQvqdOpptUG/1ENdNtagn1qqW0T62k+5CqPKJW02Pq VPqjWk5PoO9Z
9L2OvjfVWnoL7x+qVVyqVnOZOp0r1Bk8Xq3vD8g8MQ+yiXmQTVQNLsgmqkYN siBXaGgZSNae
19ASkP1VQ0tA9mcNrQDtxJEg0LKo14WWhXVeRkx0Usdu95PjqL3qSKSnauai uh+3VfCmH+v4
GKRSdbxrrSpwINVJhopTidqAkY04UjcVlAWjXMlRbapZajZWAIxhT5HcRnV6 HuyKPjXX+zZI
azAifMbvVSfW3O2/hkr2qua9dMY+4jV9akFNrzqpP9zrL5WqG3FhCxbJgHmW RqoeuG5rwSfI
8fomBaLLN3qXzUKdQxNNkHJItTrf7SrUKV6jVd+JFmXiagd47KRy9Wkar87O l9VB+brvrtru
rtqg11jkLbbEa5zqNZZ7jZVFfBx9zgWf88DnfPD5LE1RF1C92tVfxgM28nua WqPdgXSUGDBS
/w9QSwcIBLnyS3QgAABzQAAAUEsDBBQACAAIALmz9jgAAAAAAAAAAAAAAAAM AAAAYnJva2Vy
ZGIudHh07VhtT9swEP7MpP0Hi+/EoYwNIVZpvOwTGaLlD7jOkVpL4sx2Kf33 81uDA4V1KbSp
QOqH5mQ/Pj9399wlJ6qUx5ngk0qi+yLXD9rwfXesVHWM8XQ6jYDmrJIQcZFh ymXBJR4J/hvE
bv/zp52Ter95co9jLlU/55Tk5t8Jrm31ipIU0E94yRQXrMzQOVEEDaDi0lhm botdVG9haf9l
p6QiCu+7rXpxvVFyUv3SULIiFEKM6YHd3ovjAxwfYrNuD8o7yHkFDqa5tUYU QLlIb2YVLMR9
xjcHuWjvg6tAJ4Kp2dKwfj0eEcmo9/kJRg2fgqSCVYrxsj/UHjGpmA6SZT8h JclAOIxwYeCc
uGMUpLU0TM4SRPZR/FY9PoBusJLqjUUmIsNuxEoFoiR5lNLI0RMy5mFwEycA hzKtuMbwth1/
RJ3Fx0fxUYzJPZM9PGcCB7cILhGe1YSdRyhgbUUez66GydXQ1U8rDp/JLEvt 0+u8TN3SnLUk
q2GxeegstfysIEaXPMteS4lyh4V73RQj71639Cjkf81atPTRT2qoqRVzOfL8 vpoiLVVWZ6cX
Q///3erP/0i3D3oHlWhIiiqHQIPQlKmxfs50qxHEMNpKlW5Aqp+QniXnp/ig m8qktIu3kNIi
HW1QndCCPL+4N1EhAiWpQGpMFCJUSUT0D2lSwcRFS4ghd12ytbWl5xPRc2Yo 29DwZBx5HL1G
nSEvqaFTy7JrkvjW8irpGAqC9/fivRiLAH5d9IZXWnCjjdB8PQGtbK/P7x+D uy5i7SVaMLqB
9mFdbdU3wEofFKnAX7rZNh487NZM22gaNgoESWbD43IWKY5SbgviFpnMZaAb SkZYOQ/w27cR
5ySg5HzQLMqul6N3XHPbtgzfbQd+oK6D8+8AJJ8ICit/Dyxyo1mHG9YsVw4y 8mQVuSuSIjfH
fMNxr8OaZQfdidSiNEwuP+baf33ZKvL2FbXyB9Xkcvsk3DHWySlKy44O4aoa RCrd040Kfe3m
5DT3bys06IdxFun5ezRDppg1MJg3cKZfxF3GrkuinCdbV27W7Y95qT1xbzQt BU+y/xdQSwcI
NIaHIyADAACRHQAAUEsDBBQACAAIAPBMXTkAAAAAAAAAAAAAAAAPAAAAbG9n NGphcHBlbmQu
dHh0rVLBattAEL0H8g8DiaAN8coJLYSADo6bgMGuTdNb6WG8GkvbrnaX3ZVs U/LvHWlTF1qc
XDIHwcy+9+ZpZs4u3jZOT86m1u29quoI7+R7uB6Pb2B2t4Cp9c56jMoaBk20 hgEUwFMg31Ep
4GutAjhvK48NoCkh1gQopW0cmr0yFTQYySvUgSXQE+clIzpUGteaoDUl+YHF sCaA3QzJvdTK
BYJVu9ZKwlxJMpx2V2LMOttayfrQRlFgDvsoVYherdve8OXghot/W2Fkah2j u83z7XYrKPUQ
1le5pgp1Tk6PuquxqGOjGTtMxiRJ68Mt58Dxz2hgBMqoyL8Ik9UstW2cpoZM /DO7t1/ZC5Gc
w9xWsFGah7OxHqbLx8XyET7dL5bp/XWBRBkSbasPPwR/K/L9vA6zkzY0NhSz zw/LywMhodE5
6pcrUrnoaehQ1iQS4IvVmi/kgT1OnrFHuKLHFOe/JEZkCoo1BnrKGRvy5KCX PEZO4kX0LR2D
aNzbNv5vcYWRz9LMh+eXyYJPpSMfeOHPrCIr4VsWv0M2+uggk5Dt+FayJjPH lBa4u0P5s3Uz
ru6K69OT31BLBwhJZP5HtAEAAO0DAABQSwECFAAUAAgACABAp8M6sn8C7hsA AAAZAAAAFAAE
AAAAAAAAAAAAAAAAAAAATUVUQS1JTkYvTUFOSUZFU1QuTUb+ygAAUEsBAhQA FAAIAAgAEqfD
Or3Ev8kJAgAAVAQAAEYAAAAAAAAAAAAAAAAAYQAAAG9yZy9lY2xpcHNlL2Nv c21vcy9kZW1v
L2ludGVybmFsL2NvbmZpZy9EZW1vQ29uZmlnJEphckZpbGVGaWx0ZXIuY2xh c3NQSwECFAAU
AAgACAASp8M6BLnyS3QgAABzQAAAOAAAAAAAAAAAAAAAAADeAgAAb3JnL2Vj bGlwc2UvY29z
bW9zL2RlbW8vaW50ZXJuYWwvY29uZmlnL0RlbW9Db25maWcuY2xhc3NQSwEC FAAUAAgACAC5
s/Y4NIaHIyADAACRHQAADAAAAAAAAAAAAAAAAAC4IwAAYnJva2VyZGIudHh0 UEsBAhQAFAAI
AAgA8ExdOUlk/ke0AQAA7QMAAA8AAAAAAAAAAAAAAAAAEicAAGxvZzRqYXBw ZW5kLnR4dFBL
BQYAAAAABQAFAJcBAAADKQAAAAA=
--------------050701010304040306000204--
Re: How to creating a Data Manager [message #573030 is a reply to message #13464] |
Wed, 20 May 2009 00:33  |
Jennifer wrote:
> Hello£¬
> I am trying to follow the instructions of creating a Data Manager in the
> Developer's Guide. I also read COSMOS Installation Guide and COSMOS User's
> Guide.But here are some problems.
> When I point my web browser to display the COSMOS Web User Interface,the
> Data Manager Navigator is loading Data Managers all the time.At the same
> time,the Console displays the error information as follows:
> Serious: Servlet.service() for servlet json threw exception
> java.lang.ClassNotFoundException: org.apache.axis2.AxisFault
> at
> org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1387)
> at
> org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1233)
> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:337 )
> at
> org.eclipse.cosmos.internal.dr.drs.service.outputter.BrokerO utputter.render(BrokerOutputter.java:97)
> at
> org.eclipse.cosmos.internal.dr.drs.service.outputter.DomainO utputter.render(DomainOutputter.java:38)
> at
> org.eclipse.cosmos.internal.dr.drs.service.handler.common.Ou tputterDelegator.delegateRequest(OutputterDelegator.java:72)
> at
> org.eclipse.cosmos.internal.dr.drs.service.handler.common.Ou tputterDelegator.doGet(OutputterDelegator.java:40)
> at
> org.eclipse.cosmos.internal.dr.drs.service.handler.common.UR LDelegator.doGet(URLDelegator.java:75)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:286)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:845)
> at
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:583)
> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
> at java.lang.Thread.run(Thread.java:659)
> And,I try to do as the Creating the Student-Teacher Project in COSMOS DG.
> Clicking File > New > Project,
> I can't find Web to expand.
Web won't show up unless you've installed the Web Tools Platform as
listed in the prerequisites. Which versions of Eclipse / WTP / Axis2,
etc. do you have installed?
David
Re: How to creating a Data Manager [message #573107 is a reply to message #13527] |
Mon, 25 May 2009 23:34  |
I did as what you told me,but the problem is still there.
When I start the Tomcat within Eclipse SDK,there are some unusual
information as follows,
2009-5-26 11:22:00 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
2009-5-26 11:22:02 org.apache.catalina.startup.ContextConfig
applicationWebConfig
INFO: Missing application web.xml, using defaults only
StandardEngine[Catalina].StandardHost[localhost].StandardCon text[/COSMOSReportViewer]
When I start COSMOS UI in the web browser, the information on the Console is
as follow
Serise: Servlet.service() for servlet json threw exception
java.lang.NoClassDefFoundError: org/apache/axis2/AxisFault
news:83c404242c967e49f9511f9272337ea3$1@www.eclipse.org...
> There would be a folder in "eclipse/plugins" by name of
> "org.apache.axis2". Can you create "lib" folder in it and place all the
> jars of axis2 in it and then start eclipse with -clean option.
Re: How to creating a Data Manager [message #573128 is a reply to message #13568] |
Tue, 26 May 2009 03:51  |
Hi Jennifer
Web Standard Tools (WST) : 3.0.1.v200807220139-7A-8c8QqT3lv4VSXAI28OHWz-I88
setup.
message.
any errors.
thanks
Saurabh Dravid
Re: How to creating a Data Manager [message #573138 is a reply to message #13589] |
Hi Saurabh Dravid,
Jennifer
> Hi Jennifer
> setup.
> message.
> any errors.
> thanks
> Saurabh Dravid
Re: How to creating a Data Manager [message #573173 is a reply to message #13610] |
Jennifer wrote:
> Hi Saurabh Dravid,
> Jennifer
Jennifer,
David
Re: How to creating a Data Manager [message #573197 is a reply to message #13631] |
Hi David,
Jennifer
> Jennifer wrote:
>> Hi Saurabh Dravid,
>> Thanks,
>> Jennifer
> Jennifer,
> demo program?
> David
Re: How to creating a Data Manager [message #573233 is a reply to message #13650] |
Sun, 31 May 2009 14:10  |
Jennifer wrote:
> Hi David,
I'm guessing there is sensitivity to the spaces in the file names. Try
putting double quotes around each argument. Let me know if that's not
the problem, and I'll look at the source code for the demo runner.
David
Re: How to creating a Data Manager [message #573250 is a reply to message #13670] |
Mon, 01 June 2009 22:39  |
David,
Jennifer
news:gvuh6k$90e$1@build.eclipse.org...
> Jennifer wrote:
>> Hi David,
> putting double quotes around each argument. Let me know if that's not the
> David
Re: How to creating a Data Manager [message #573298 is a reply to message #13690] |
Tue, 02 June 2009 18:31  |
--------------010307050400030700030509
Jennifer wrote:
> David,
> Jennifer
Jennifer,
home folder.
Hope this helps,
David
name="config.jar"
UEsDBBQACAAIAGiTwjoAAAAAAAAAAAAAAAAUAAQATUVUQS1JTkYvTUFOSUZF U1QuTUb+ygAA
803My0xLLS7RDUstKs7Mz7NSMNQz4OXi5QIAUEsHCLJ/Au4bAAAAGQAAAFBL AwQUAAgACADD
kMI6AAAAAAAAAAAAAAAARgAAAG9yZy9lY2xpcHNlL2Nvc21vcy9kZW1vL2lu dGVybmFsL2Nv
bmZpZy9EZW1vQ29uZmlnJEphckZpbGVGaWx0ZXIuY2xhc3OlU01v00AQfeuk cWpM4oZSvr/a
UOwE4oIqcQhCiCAkkFUORUHqbeMsyUbOOrJdJCQkEP+C/9ALB1qJAz+AH4WY dSPSCC4NsnZ3
ZvbN27cz65+/vv8AcB9bJgyGJ3Ey8EUYyUkq/DBOx3Hq98U49qXKRKJ4REH1 Vg78ZxTs5Gb9
JU+ey0jQIIiJIoMz4u+4H3E18F/1RiLMTJQYanlUxv4MzVDKhjKtbzFsB6c/ uk35j6SS2WOG
h+4iBF6XodiJ+2IZDGdtmChbKKBqYxkOQ8HVgGogldjZH/dE8pr3IkFXCeKQ R12eSO1Pg0V9
FYanC+iYr6G+Fg9DMckYVtzgZNna3p6Fi7hs4hKDfXLHxhVcZTAHItvhY5Kz 6nrBrA+7WSLV
oF3GdRLaGvHEwk2sm7g1161jlI0N1BnKQvXTNzIbMpx3/6by9ggy4dlQ5cdV 5nUyvF+oIf9f
PK9rUS893UGLwdqN95NQ75HG6iyppdVSCV8oJZJOxNNUpCZaDA9OL4BezpwE qiw9HRpLYI6j
3xT9YQUYWhFFz5C3TZ5Bq9VofoPdOELlK3kGVmguEQbGB9TItrVNWeewSis1 AmtThmDK4DQP
caF27RA3vmCpeFA4+MNToTNhfIRtfELF+JzzrR3nTPm0dRubpBKk7c6UeZMw Ba2j0TyC+29d
Rj4a+dzE3Vwjo+8efBi/AVBLBwjnbzbaCQIAAFQEAABQSwMEFAAIAAgAw5DC OgAAAAAAAAAA
bmZpZy5jbGFzc51aCZxbVdU/5+a95CXzpsvMpG260LTQMp2VFiiQbrTTbWBa SlfaCnyZmbRN
m0mmSaabCyoVBZHPTxFoAUE+pPqxCAIzQLGAQkGBIouyCCIIqCibiigo/f7n vvcyySyAwm/y
7rv33Hu2/z33nPv6sw/vOkBEU9XSACmmaZnsxsZEWyrZmUs0tmVyHZlcY3ui I9OYTOcT2XQ8
hc70huTGxvnobNLNABlMwzbHt8UbU/H0xsbTWjcn2vJMwXymoy2en5/MMlW0 9I6vyGeT6Y0z
mAKysB4ua01m8+uSncvi+U1MVnxHMjdtexwD/pnJdDI/m8lXPWU1k9GUaU+E yEdDbApRGdPQ
lmQ6sbSrozWRXRlvTSWEU6Ytnlodzybl3e008puSOabjWv597SCnmcvHs1Bo RPX6/mpMWR0k
DNlkkl9ao2wKOK3RNllOa6xNQfKH0DrCpvEUZRq+LZ5KtsfziZW9NoKK64I0 kY4K0JElBl2x
M5dPdNg0iSaDKtMFUcKOIMlM4zJIkYcsiXjHjABVM43sK+K8rmSqPZG1qAYy Nac156jDN9qe
zMJXmezOWDRER1OdmLUey1cPpKhQNNp0DE2FY+KdnYl0O1P9QKT9ulwZZsgS x9p0HB0PN+cz
ziBTVXX/KaA9gU4K0IlMlQMoa1NMJA10SlcqLcadadMsMe5Qz7jzHXxZNIfp aE/zptNWLDlt
RVTcHk2m4dpUqtQMTHNtmicLVXkLzQM8BVf5ZCZt0Xym8d5qnUBsNJ+Jzmte vjK6K9kZ3ZBM
JZxVFtq0SFYZ5a0yV2C9Jp7tXamZaUzflTT4G4B+Z5VTbWoRpBuJHcm8dCy1 6TRZdlgypxds
dnRItFt0OtNs3RdN5qLpTN7TL9EejacH4OCRdWYz25LtifaGqEUrYG53SRmO t2ayeYyEaBWt
CdDqUmBqR9l0Bq2FJ6BGV+K0DUyTiyHhRIMBIDHDovUAQeP2RCuwlBPVzrTp LDqbqbwrDVN6
5oLvBsDYAKhbZ1Gc6YSF8aRonO91r1Y4mklHnYjUEI0OoKFFbUzVzb0W8ybN 7Yy3bUp4OyaX
yG5LZBsChLBie7hcCI4WAciBgjbtlJTNtPkTS79a5qRs6qA0YmcqmcvLqoha w6unrG8p5jRD
KDtt2iq7KLAxkV8a70hIX044IjocWV1KPxi3bTZtFyj5ga1cPmfRTrh3TaI1 ChVSSQekgMSn
Abr+iGpNtMW7coloPLq9z4ztScEZTJaDXNG0/MRT2LPtO6MOowZx9mdt+hyd A2C3ZTrBd/yA
MntvU1Zb9AW9WTz2fZjGIOe52Pp9pLfoS9iA0bZMV6pdy9+a6FWhQaLREPn5 ikS18/sEs0GR
6wUzi76KzdLoBJTliU7gaHUysT2RFfW+ZtNF4n1TY9mir8Mtq6TZCeF1tABA +0+16BtMs/r3
NxadkPXZrnQ+2ZGon3b2sWcf0wiVHZoFO+IdnQLEi3EMDizVJTZdSpcBNR2Z bYl2OXU+xu7Y
U3txcDZlOpOe3GL5bXpFuFNzHEyVK5hOWpDNZrLRTFtbVzYrbtuUSEe1STph yY8wBPbjt5mm
u/upN0JrL27IdCGe4Q8yDBDPMfdqhBbZqsm2BHB9DU5ed6VGva8b1yyYV9+8 dGFjL8212M+C
HrcHeLqO6ZSPw71H/fGYt+h7OJxLAezOFvD+H7KgIvYW3YBQ5kn3b6t/E1Nk YIVTyVaLbkZO
4g07C6xqLqYI0A+ZTv73k6WjTolnBTf4ywvgbqHbJCTdzrSz+j/Jvf6DOaUi uIGuR8LqHUyT
SsHu0fQJrxbdxTTRhbxYL7oZZ6Uc7LlerK5qhpnvZpqxLJtBjtmRK8Y4SKMS 1gTiH7nAAZyW
pY4o2fQlTruXqe5jhOqzgX7MtOA/Fa/PUvfjHHIcUA93JNJ5R6aDCHCpzMbj Nkt+8JBNP6Wf
MYV0vpxbk5RkfsBUElHlERyMg2rjcIo6nBCmD9HPA/SYlwjqpRbsaEt0Soi3 6XFdCXQ6uWG8
bcvKbFw20JOA8L+vfSlri34B1DQOvJUEe05Xw46OlEVPM02Z2RnPYvMDVjoI zJq4KZPLS2ti
NJVp25JonzUxn+1KTJxt0bM4b6L47xNPkQD+K5uel2N/GI59Xeksdokt+jUC 2MzGwmKa/Dc2
vUQvg7yrUzJQqZaa0wJyROZPlJYM7LxXcBT3plnO2tGCJWC113ACrdLd7SX9 v2dqHMyaqXgu
l8g1ajg1ICXtTGTzyYROpeoC9EcUWd4unde1YUMCzlyO+JrIBugNRDtvrDnd 2eWWCN7wW15R
5G7wIpIQvUnvSIj6s+RZfXOOEP2J/iqj7yKJ6B0tmq+JXqf3hOjvwGcvkcPc HX/fpg90ySMn
gjjBon8xRR1V8bsRewyhrsENdQ0OCGfJpjpsMzFjKtCWjyPCw/TFnmvaFM+u SGztSqTb5LgO
sQ97hY2ioqn5tMJegSzstzkgG8ZsS2VyUkxz0OYQo8cCpprEC6JIcdqjO2eE uJyHBngI9lqf
IZuH8XCmId78lozoDqf0X8UZmmFxJZbR+juFZEN+Rz7EYR4Z4BEIGgPOsnkU RyAb2CxP5DJd
2bbE3JzjB+y8wevQPi4L8Bi4s9jVp3XlexHBo3kc3MlHAMJ9ELEO3uQoTwzw BBSH3lDxbJuP
5KNg2+3ZZB57LFC9fl5zs8yazNUBPrrYK+miSVMYtbkh4MBczJnSLDP8wsxv cQNK20E2jZcg
NK5Y0rJk/vLGJQtWzi0Z0JGJj2Ga0C/MZDOZfEMhsUBE4mkwY9T972PJAU4+ zubjeTr0zCY6
Uwi6ckfS1DRQrcco4+d+QiVyHal6LJjJJYVTcUizOMZU0y/yFCuL5CgbxUJR rNRg8Uxo7gWi
jyCbjZPyY6XLx/Pz4/n4kng6jg07mK1PZjqqn/GA3tadDTl9kdOwKdMhBwDP w4E+qLkHnDEf
W6MRysRb47lEqWEWMk37eMPgZM4jG0V1lHI1XwyfD2qg/uSn4JBpzWa2JLLt rbJnLW5BDTGI
6TxJEcJ5qc362sLfsQUgkqjOp9u8XKLiUGzoua25TKorn5D6xuKVTOWNBTaQ BmcZr7Z5DZ+B
s0wOb2fnrMw4Z9nkgYNzvxqS10lpLcemnLGy6KdsPlMOyAoXwSvBM+0ckRaf zTSuN2F35Il6
SomZLY4jU+x/4dCHtCHAbViqWJqlmfxCyeILoRn7P57dKKF3gEtGmKMtk5Wt lxT1QCWaDJFU
2LW8ruWGlCqMfZnrahVrw8br+44Ncy5DiudzEn/NTD79ZrQncnl0JArXjaWJ l6yxvU/tCfNK
ZZnP6BWGioAeqJw1c9ltkCYkOEECqfsslNNeE6nYBufWw48cErgA3LI6E/VI bCcz816NDRoA
gc54XioCtNKJ7SmcsEwqC6Pb+oyRbALZkna+++odP04B0YVsAqG3tWtDEmuM ahk404DGhrN2
7/1r0emKYSXTwwOCEbGxZaAjAwM+8MXc9QgIvlQCK/iSGVGqvVW7W+7HNaDm t+qL4iFQ0dsc
Wquyoo4QTeSLbWrhb0HY6mZd//ClNl8mm68smZvvRXDp32vz5XyFzksk6qzM DJAFrRMjZzM4
YlUe45a0HUwFxfaZrPaD30GTe6nvSFXkeWH2XZuv0xEgmXO2F+rhYOEuUo6T /7P5er5B7qO2
dsVTuT7Fg3cfA4Fs7wuBs9APsGsGuB+BsNLr0KCgLS+JUt53BkhnMSpUU7+J oD023yGCmjpU
Qf1O/VliSO9WcTpCxXsnVIBBLsAHvBSmK59MNe5KdjZCNJEjxD+iOvzwfTb/ mH8CcwHL2aQA
vpAs6TkL0l0diay+w5ohpnnA5oP8IEwDfGwU5r5qJAkY+KnNP+OHMdCGRHBu 3nF6k8WPYuc2
WoyiKbSqcN1i8eMgcCIXyiNfQ0NDGf+Cnw7wL0skLuJu8zP8rIbYjvwClFKQ t+99veuYAP/K
y9GL1V4ABXeG+Dm+FD/UKQZ+0ebf8EtwCDb4sjiwl3fC+LDqKaXgE0v91uZX +FUnuyzaTygk
qlsGZjZI3ofMjupE3d/b/Af9nWBTPLckk024auWEmx8uwVpOVFG7sC1H9ufi RdddwrCro5Sm
2HMwNvLAjkJE6S8qHIfNqxEkkcvhG+zURtGbfUTp96ydnd43rWkD85xZOxir 2XJvzH+3+R/8
vg5kEt3Dhcvlkk8vMNU7MLmTZHvfK9DhBOXeDqsN5XQ7hLUUqk2zAcp2Wkph +VUrF56I+kkZ
yKWViazto47o0qvpgAoMUOytkZQ6G1BBptEDxVFnPKQsVSYsUTbVVg8ccAe8 Dld+JR8V1dCS
Ks5Z1B0fjuye6qVVaasqqaHEZVLOoQ/ZOrWrkbYapWNceyKVkArAEo864SLg JGXt8jkSZhro
mHHZYV+rI2w1XmGlkJuYzE2lmE78ZJ8SBkogzLxkNhAIIusvNSF1lJocUJO8 SiadyMMzyMTa
4U/UdOpoVY1IW3zPIFWwu3gf6hmyWo2taiWfK8McIZfPEgFV72U+MmVVeks6 sz0toyWZD1Yp
nI99l4bM3o0IUs2Wj1xLdlwHqmSkduo4Wx3fezPkfL45LZ3aKWMn2OpEGQvp sVU5JPRyXTJE
xmbYVElVlpqFCBqy1Bymu1duSubkK9lG5NvR7Un5cORmenLl617B9vkikQMN Am2+99ORd+OL
Yj8abd4Q3ZnpimKjR7ty+ioqvTOaAXW2iK5O02iG6YSTYnYgtdqwM5ovlgiZ erE8+i64I57G
GZra2WCpuUzztIqxqJPtyG1pdH3h8/yZ0fXOhYPTLjpJ8eadtGdaqknXK4Vp sT5fxvp9TLXU
Auz7aLSweMwz1fwBP75aapHmUCRArPQD63LnYC98aLUUstWp0agnZCxandE4 iKemRJe5M8Uk
vZ88nQgbWqEjm3PsDO29PW4QdAH1zel0Itvk3EjhnCq5U6YJQIqPiAxS8tUf LSXf/PXTcp9B
/awEZYjK8GvjrRFPxtOs6aHyWzTZUPz6dWcNDcOv7RDQcKrAkwWIzuTymWAx mihwQU2tb9rt
FK6pNfAYWVNr4hGpqT3gv5aCtf5p+8jg22mMMQtMxu2lI35IE/bT0WsrpvRQ bc1tFO6mhm6a
1k3TfUIxo4hitkMxspTi5CKKJociUkxxG405SJNAuKCIcLFDOKaIcOxe8t9B p4BwyV46XQYf
pBGgr1iGYXkux1MIZEgWEWHvoJVYqWKds04PfWovDRHa/wLtPiqTZiua+6ld yEdWbOihTUvr
u2lLzIgYBznoDoT1QMz0Tffvo69FjLB/WiwgYxEzEuimTA9lY1bE6qauPTTJ 02EHOOtRMK/Y
VdBkHzXXRAIRq4c+41F+vojSIzoqFvSGv1i80O4CzW4/h/0R48B3Dm8VnSNC 20PnRcxu+nLF
BZ7GF4qO/+3qGDEr/kdk9bsv35SXQE3EHwn00LfWCOkezX1UzC8vl/ea6cpi M12lrSGctsT8
Ef9BurFgqO/IUMA33RJD+cPWtJg2IjQOuoYKRUKlhvpf0S/o6vfdUkMFI6Ei Q+0rouw1VJk3
/P3ihYoMZXHYivjFUK4y1/cqE664UUtceP2BvFoRdNyytoZ76NZu6o4FfdND YKU1sSLBcGia
q0xZjX6LlEHK3SEOhyJB8HlOmNypxSuPheRlfzHHHwmLUH8WZR4LrBIu81jY NfotYguLMg6X
9bK4x2Whlbqv2EM/ERZl/VnY++g4LGfL4hUPdNODe8V2YFnm9QrL8hr9FikX ljaHbc3yZ8Ll
Yc2yImZH7G56VHqe0HxL9ttTju1jdsUvY+XaNc/Ihu6h58QzL7ijQ2oidqQ8 MqSHXpw+NDzU
3Zq/7cXcq/1X/p07d5gWelgP/SE2PDJc8MTzfNMrOFa5n15fu5/+hL8310aG 99DbPfSXHvpb
rJJjVZHKbvoHHlUPEjbyyZGqin9204d7Dr9uTK/Yd/gVGelmFak8SMeClM19 VBsbsY8mx8LS
V+72mbERkfA9fXrCFXvpXrDgWLimm61utiu5opurYlX7eTQEMXp4bCw83KC7 LVmyPBKOjPCF
R3bz+EhVZEQ3T1o7feSVh/+0j1qxetVBskSU2kj4IG2OhLu5TgYi++hMjI4Q GUtIFrkkc4Qk
FhtVOlrujpqxSGTUPYOOlVq6kus9J1Zyo+PFSp7qHgLDPjWssZuPBUUlnzCY O4fCh5V8kvan
rdsz+jm0kmf1spnjsZnrniTFbJo+ms2CIjaL0C44oVmcUCFw6cv5VC9G/iFW Kcjo2ktBceiS
NUIprWUe6QqXeZWGXZVMCddEKiLhHl5VE6mq5LUC7h5ev8aNRZV8lgSjqqJA VRmriFQ4e6aS
5QC6har4i3wt76ND/KSaqCbRIXW9elT9nA75jvelfBk8L/M95nsCzw+MecYC OmS8aI42R7PP
nGDWmg36fYJ5LA7848055jw6ZC4yTzdX4hk3rzSv5lbzGrPbvBP08n4AzwfM Z83n9fs15kuY
dwA98vyt+Z75PvoP+yv9I9jnfy2wLbCTDjkZhnqCbkM2cSwyiONoCB1PYTqB JlOMqmkmkpJZ
tJhm0yk0l06nebSZmihFiyiH3gupmS6iFrqCltDttJR6QLGfltMBWk0P0Bn0 CK2lp2gdPU/r
6UU6C6nL2VxGca6kJE+gzXw0beE6SvEM6uC5lObFlOEzqJP/i7byOZTlL1IX X0DbYMHt/H3a
wQ+B7kn6HL9F5/B7tFsZ9CU1nM5To+nLsO756mi6QE2ji1SMvqma6WK1jL6l VtElqp0uVZvp
MrWV9qgv0F51Pl2uvkdXqOvpKnUrXQ2PfAc2uEa9A7rDdJ0vQNf7RtANvkl0 o+94+oFvBt3s
W0q3+Nai3U63wnO3+bbS7b6ddJfvK7Tfdxn9yPdtOuC7he7x3Y32g3QfvPpj 31P0E9/z9JDv
j/RT3wf0sMH0iDGcHjWOgmcb8R6jx+H1J4xF9KTRQk8ZK+lXRoqeNzrpBeMC +rVxCb1oXE6/
Ma6jl42b6DXjIP3OeJx+bzxLrxvP0x+NF+kN4+/0pvEBvW0qescM0Z/NKvqL OZLeMkfT38yx
9J45gd4Hkj4Aiv5uHo/2PLTn04fmIrRXor0apd96ZvMsVmacDbOTTfMzHDDP 5aB5HofMr+N5
NdvmNVxh3sCVQFsVkDbEvJeHmg+g7zH0PY++l3iY+Vu8v4H39/H+Tx5pHuYK f5AFcVX+UTzS
P5bH+qfyOP90PsK/lsf7Exz1b+YJ/m18pP8cPtp/GVf7r+Qp/nu5xv8I1/of 5zr/C9zgf42P
9b/L0wNhPiEwjk8MHMkzArN4ZmAxzw4s45MDZ/G8wE5uCnya5wc+zwsC5wNJ yJZVNXCMjNjN
ltHidk4gX64OtPIG3kgKvJO8iZPkA/c23sxbkB3PoPc4hT6TZ9O3uIPT5Md6 n+cM+gIan51o
WUDkeN7KWQoChxM4hz4/0FjFeaEDFi096lfN5lzukvXUMjPG28DDD0RernkE 1EaXhwV0OjyC
wKjDIwRUOjzKfCOMPG+XGb5JRoJ3iAS+441VvBPrBX0nUp1eJQSclvEujJYB oY4EId9XDMWf
lvV8l7t0ZcCqQ2cDpZbL44++q/gzeu6HNFPT2cCqQ1cOlJZrOttI+Y7gz6Iu sY1O32j+HFrl
xgU+wp710xDjEvVX/jysO9Q4qO7nL6BvmPG4uhOxMEnDjed5Jp+L0QrjRT6J d/OXqBL4Hc/n
ga4KiDXB48tonUV38Vf4fLTiiCuTEAfC5rk0jr/KF9II8zwK8dcg30gTZYPb uhdzL8LcEf53
aTf/N+ZWBMLUzl8H38rALGj0P8IjsJim8jfQFw58moZojSpQhLUUyrApusZC 0DTu4G/2lmEh
PIlPBUBadCmm9N+ldJk77UnUewE8l9QibV7qm27so5n1YWNazJRDpU6yaZ18 +dHiS/ZQVcSv
82Tkf2bEL/m5PLt5z5rdBoeNemRkPzFuKLCfjJKReBl0PB0eWU7DeQVFeSUd w6voJF5Dc9F/
Kq/Voi12BPFwT0v4SujLuvVttKQsXcxXATk+FKRN2tMGqI/hqwWnFAWeBX9+ UI7Hm6PgHtBI
Wdskh+yDZPpu8DJenJcttVqZ6lqt24SSwmpJnaNonR4zjRt8vWodIaLymRTk syjMZ9ORCP5T
OU5zuBUqJbQ6UYetq06YGvg7Wp2pGN2o1VHyD7tdMQ9CTAPPdV6y3CvdYke6 uSX1oCtdSKTb
W6SVUwZJtSij9d5oifQ1QAXJJuLNNBrmrOYUTecOOpEztJA7aSVvpdWcozO4 S2tS40jmamLT
Ur5Ga1JNx7iaLKQK/l8JSGgvKui0Rb8T1bqyjenVKQKdrt1DFXjLVPK+bv5+ XxNXCFPeCSF3
0dH8aZqCvSvCjHCWLAgznm/Uwij5x+2DMI4Mxvgm1BoDM/4iGJ8LxrvB+LxB GN/sMj6twDiu
b0+oF0mVfAvc4fK2aweAksPuAhrKX0WcuBDLXlTEboLLbigMfKvL7iw622X3 MObKhUyT3qtQ
sp/fZaC+km+TLWxEjG7u1t01tdJehkJ8HwViGh9Y8hgkT7O89MpFyTeA8W/S SL6YInwJTeZL
gePLsOWuoFl8JfD+beD9ai3wbEeUwvZt4jvdS6AmvktvyiDFeL9GyWSoKuoY NAfHmQQzE+MX
IU1TfLe+g2LIARXVaoyUQ46a/fyjtbU9fA9U5HtjRp2bhUvBL6HpfqO9mx8a 1ngVjdZ5sukl
yY+4SbJZyIEPob9WZ+8/x2+dbj1RlBLfGjHu5KcYhdNzco/Qzc/voTovVfcW lv4XelP1QCQg
Kfo+2jYIkXszEwBxN//avZeR1N6SefVC+XIsqKuyQA+/FgsNr7wYRVmZFGWh SJkvbEtRFoyU
6aLMRlEWCUq1FEKhJPL+jmnv4WbY5nWJ/T7twc1ytcbXwoPfBbyugwe/RzVI AObyDbSJb0Ia
+wOkqLcgLb2VruLb6Hsoye+D1x6Dv57m/fQCH6BX+R56m3+M5OJ+ep8fYIPv 5+H8II/gh3gM
38ST+FGewoc0Ai4TrlzjIYBr+I8OAtDqdBDAE/hP/IbIh9lvIiU2INVwxB0/ /LydruW3+R20
rwLlnyVtoPtoHf8FPQF6jFr4r5JA0KuIVnLIBult7Ec5ZEP0Hh2lD9kyet89 ZG0egqPfab3r
XkI6XP+md+nn6Jy+aMMZGdCH0G5npzbVaSdZCLLda9D1nnNATqwRX9bKMYl9 pfee25abCe8Y
fAGVr5T7taj2l4pj63r4g5jh+NUUvxoR0xeG48fXC4LhVv+Vh9+oF69ic9b1 nuGniD35CaRx
T+Lof4oq+Wkaxc/QEfwsNfJzdAKeMbwv4l/TMn4RFnsZ5corSCJeRXnyCu3i 36H8+D2dy69r
P22QnU27Czt1N//TPWh38790PB+FdT/EOeajMYh/zkG7jI7VVvfhJJiirW4g 3k3UVjep3bW6
H1603ZaSf9nS18Z0qxu0pno2WeqYBIa16yOGLwxbjNcmgEXMKw+/CcPX1pcY ZCJAQIBRkN+m
YfxnGOQvNBbPaji6Du49BnVWb0YxtaDoVK0A69YurWgQh5io4gP9BK2KQZVY VxQwaZKrigSn
l+hlJ+qqM7GqgGU8wKCBIAFA3zsi9JaJK68txF6JBrVeKDrcGy/8HAtwzCq5 FjIBlErFPcon
N0OB/cq/dr+y1uqY4Ied9FioR5XHLI4F5e71H3gE9a1RKmzspVGRYJ3cHNHQ iFXfrYYZAtaQ
XA3iBYFGVew7/LBMQb0fCciFC4KWGbHkwgWjYblwKfPdIJeAgwxGQvcMPmZ2 qxFrIjpR3LMm
jBPFxJF8O/4/RHfTz5FpHsL73fQ0zP8svYG9e4je5SDbhRPnIjoSZn0fZc0H 2Ln/whnxIY1X
imaiVJmjsJoK0FnKol0qSJ9VZSilbbpQlaM0HoJyeChdh0LmRlVJP1Qhul2N oB41ku5WY+mg
GkdPqiPoF2oUPY2y+1n0/RZ9b6Pvz2oCvYv3w2oc2+oIHqKO5Cp1FI9VkzWE OhFR4OpCTBuv
Im5MG69LCKVbUkL4IPdYNRpFggHpK/izOimdCU5jdFI6h34D+H0J4JlHL9Ak 8LTos8i5pIQI
olgwnbIM++XMAtSWgFr4jyvgTA5xB2fGJ8GZyRpqJTgzSnDmL8GZWYIzgajk +/+Q80rjLB2x
HIiNQAMYGyeX0oKBYYI0pwVwCNJ+6hxyj8pNvKwCwAQEMAEXMCEgLTjoYCR4 z+BjhkaaKSbY
s0YDbQ7dhv8P0X4cE0/gOQetX8Jfz9Cf6C28/5UtLisA7QJEEFJIcFQdjVb1 NFZNpZPUsQDa
cQDadFqvTqDt6kQALUZfUDPofDWTvqFm0eVqNn1XnUw3qHl0izqJblMLqFst pP3qVHpAtdAT
cNhTahH9UjXTM+h7GX1voe8dtYz+ivcPVQuXqSVcrpZzpVrBY9Sq3oDM4wog G1cA2TjA0wHZ
ODVRgyzElRpaBp1Er2hoCche0tASkP1aQytAu3AkCLQs6nahZWGd5+l4N3fs dD/3DbtDHYn8
VE1ZUndzSyWvvVnHxxCVwTaOtUaAA6l1ZKj1qPI/hZEzyVZnFZUGw1zJUUqq BiUfBAFjdYyW
3EbpuRX2RZ+a5n33o7WkNJ8xd6hjaw74r6HgHUq+k+0nXtujTqrpVrHecD9a zgu1gXxqIxbZ
BOZJGqq2wHWpos+LY/Q1CUSX7+Mum8U6iSYaK9ebaqbzTa5SzfYaM/WFZ0kq rjLg0UkVaiuN
UdlCzRySL+vuqq3uqg16jZO9xeZ5jfleY6HXWFzCx9GnC3y2gc928NlBR6md VK929dbo6hT9
eyogJO5guoUYUFL/D1BLBwgRZ+Xxpx8AANo+AABQSwMEFAAIAAgAubP2OAAA AAAAAAAAAAAA
AAwAAABicm9rZXJkYi50eHTtWG1P2zAQ/syk/QeL78ShjA0hVmm87BMZouUP uM6RWkvizHYp
/ffzW4MDhXUptKlA6ofmZD8+P3f33CUnqpTHmeCTSqL7ItcP2vB9d6xUdYzx dDqNgOaskhBx
kWHKZcElHgn+G8Ru//OnnZN6v3lyj2MuVT/nlOTm3wmubfWKkhTQT3jJFBes zNA5UQQNoOLS
WGZui11Ub2Fp/2WnpCIK77utenG9UXJS/dJQsiIUQozpgd3ei+MDHB9is24P yjvIeQUOprm1
RhRAuUhvZhUsxH3GNwe5aO+Dq0AngqnZ0rB+PR4Ryaj3+QlGDZ+CpIJVivGy P9QeMamYDpJl
PyElyUA4jHBh4Jy4YxSktTRMzhJE9lH8Vj0+gG6wkuqNRSYiw27ESgWiJHmU 0sjREzLmYXAT
JwCHMq24xvC2HX9EncXHR/FRjMk9kz08ZwIHtwguEZ7VhJ1HKGBtRR7ProbJ 1dDVTysOn8ks
S+3T67xM3dKctSSrYbF56Cy1/KwgRpc8y15LiXKHhXvdFCPvXrf0KOR/zVq0 9NFPaqipFXM5
8vy+miItVVZnpxdD///d6s//SLcPegeVaEiKKodAg9CUqbF+znSrEcQw2kqV bkCqn5CeJeen
+KCbyqS0i7eQ0iIdbVCd0II8v7g3USECJalAakwUIlRJRPQPaVLBxEVLiCF3 XbK1taXnE9Fz
Zijb0PBkHHkcvUadIS+poVPLsmuS+NbyKukYCoL39+K9GIsAfl30hldacKON 0Hw9Aa1sr8/v
H4O7LmLtJVowuoH2YV1t1TfASh8UqcBfutk2Hjzs1kzbaBo2CgRJZsPjchYp jlJuC+IWmcxl
oBtKRlg5D/DbtxHnJKDkfNAsyq6Xo3dcc9u2DN9tB36groPz7wAknwgKK38P LHKjWYcb1ixX
DjLyZBW5K5IiN8d8w3Gvw5plB92J1KI0TC4/5tp/fdkq8vYVtfIH1eRy+yTc MdbJKUrLjg7h
qhpEKt3TjQp97ebkNPdvKzToh3EW6fl7NEOmmDUwmDdwpl/EXcauS6KcJ1tX btbtj3mpPXFv
NC0FT7L/F1BLBwg0hocjIAMAAJEdAABQSwMEFAAIAAgA8ExdOQAAAAAAAAAA AAAAAA8AAABs
b2c0amFwcGVuZC50eHStUsFq20AQvQfyDwOJoA3xygkthIAOjpuAwa5N01vp YbwaS9uudpfd
lWxT8u8daVMXWpxcMgfBzL735mlmzi7eNk5PzqbW7b2q6gjv5Hu4Ho9vYHa3 gKn1znqMyhoG
TbSGARTAUyDfUSnga60COG8rjw2gKSHWBCilbRyavTIVNBjJK9SBJdAT5yUj OlQa15qgNSX5
gcWwJoDdDMm91MoFglW71krCXEkynHZXYsw621rJ+tBGUWAO+yhViF6t297w 5eCGi39bYWRq
HaO7zfPtdiso9RDWV7mmCnVOTo+6q7GoY6MZO0zGJEnrwy3nwPHPaGAEyqjI vwiT1Sy1bZym
hkz8M7u3X9kLkZzD3FawUZqHs7EepsvHxfIRPt0vlun9dYFEGRJtqw8/BH8r 8v28DrOTNjQ2
FLPPD8vLAyGh0TnqlytSuehp6FDWJBLgi9WaL+SBPU6esUe4oscU578kRmQK ijUGesoZG/Lk
oJc8Rk7iRfQtHYNo3Ns2/m9xhZHP0syH55fJgk+lIx944c+sIivhWxa/Qzb6 6CCTkO34VrIm
M8eUFri7Q/mzdTOu7orr05PfUEsHCElk/ke0AQAA7QMAAFBLAQIUABQACAAI AGiTwjqyfwLu
GwAAABkAAAAUAAQAAAAAAAAAAAAAAAAAAABNRVRBLUlORi9NQU5JRkVTVC5N Rv7KAABQSwEC
FAAUAAgACADDkMI652822gkCAABUBAAARgAAAAAAAAAAAAAAAABhAAAAb3Jn L2VjbGlwc2Uv
Y29zbW9zL2RlbW8vaW50ZXJuYWwvY29uZmlnL0RlbW9Db25maWckSmFyRmls ZUZpbHRlci5j
bGFzc1BLAQIUABQACAAIAMOQwjoRZ+Xxpx8AANo+AAA4AAAAAAAAAAAAAAAA AN4CAABvcmcv
ZWNsaXBzZS9jb3Ntb3MvZGVtby9pbnRlcm5hbC9jb25maWcvRGVtb0NvbmZp Zy5jbGFzc1BL
AQIUABQACAAIALmz9jg0hocjIAMAAJEdAAAMAAAAAAAAAAAAAAAAAOsiAABi cm9rZXJkYi50
eHRQSwECFAAUAAgACADwTF05SWT+R7QBAADtAwAADwAAAAAAAAAAAAAAAABF JgAAbG9nNGph
cHBlbmQudHh0UEsFBgAAAAAFAAUAlwEAADYoAAAAAA==
--------------010307050400030700030509--
Re: How to creating a Data Manager [message #573323 is a reply to message #13711] |
David,
console is
server
program o
Jennifer
> Jennifer wrote:
>> David,
>> Thanks,
>> Jennifer
> Jennifer,
> home folder.
> Hope this helps,
> David
Re: How to creating a Data Manager [message #573360 is a reply to message #13732] |
Jennifer wrote:
> David,
> console is
> server
> program o
> Jennifer
David
name="config.jar"
Current Time: Tue Jul 22 17:51:51 EDT 2025
Powered by FUDForum. Page generated in 0.10328 seconds
