org.eclipse.emf.codegen.jet.JETException: Template not found: ComponentSetSizeSourceTemplate.javajet [message #144876] |
Tue, 20 May 2008 06:14 |
Originally posted by: jtnews.mail2003.dnsalias.org
Hi, I get an Exception when I try to start the Visual Class Wizard:
org.eclipse.ve.internal.java.vce.templates.TemplateObjectFac tory.getClassInstance(TemplateObjectFactory.java:119)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.getGeneratorInstance(NewVisualClassCreationWiz ard.java:105)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.applyContributor(NewVisualClassCreationWizard. java:299)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.finishPage(NewVisualClassCreationWizard.java:3 48)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard$2.run(NewVisualClassCreationWizard.java:464)
org.eclipse.jdt.internal.core.BatchOperation.executeOperatio n(BatchOperation.java:39)
org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaMod elOperation.java:720)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:4466)
at org.eclipse.jdt.core.JavaCore.run(JavaCore.java:4423)
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard$3.run(NewVisualClassCreationWizard.java:475)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Does it mean that one of the mentioned dependencies
(http://wiki.eclipse.org/VE/Installing) are missing (checked it, but I may
be wrong...)?
I'm using eclipse europa Version: 3.3.2 Build id: M20080221-1800 and the VE
Build from sourceforge.
Jan
FUDForum. Page generated in 0.26320 seconds
