Home » Eclipse Projects » Eclipse Platform » [OT?] TableViewer with multiple colums
[OT?] TableViewer with multiple colums [message #144870] Thu, 16 October 2003 09:58 Go to next message
Originally posted by: tcn.spamgourmet.com
Hi!
Well, this probably does not belong to this group but there are no
appropriate ones...
I tried to write a plugin for eclipse. So, I have a TableViewer and I even
already have two colums:
TableColumn column;
column = new TableColumn(viewer.getTable(), SWT.LEFT);
column.setText("One");
column.setText("Two");
Works. But how do I add text to the various columns? The following code in
the Provider does not work:
public String getColumnText(Object obj, int index)
Line l = (Line)obj;
switch (index)
case 0 :
return getText(l.getLevel());
case 1 :
return getText(l.getMessage());
return "N/A";
Only the first column is filled with l.getLevel(), the second remains empty.
Why?
And by the way how do I dynamically add lines to the table?
Timo
Re: [OT?] TableViewer with multiple colums [message #144879 is a reply to message #144870] Thu, 16 October 2003 10:15 Go to previous messageGo to next message
Hi Timo,
I just compared your code to something similar that's working and it
looks pretty much identical, so:
1. Have you tried returning a "test" string from case 1... you say the
column remains empty, but I would expect it to contain "N/A" if this was
not being successfully matched.
2. could getText(l.getMessage()) be returning a null or empty string?
cheers
Rich
Timo Nentwig wrote:
> Hi!
> appropriate ones...
> TableColumn column;
> Line l = (Line)obj;
> switch (index)
> case 0 :
> case 1 :
> return "N/A";
> Why?
> Thanks :)
> Timo
Re: [OT?] TableViewer with multiple colums [message #145057 is a reply to message #144879] Thu, 16 October 2003 12:40 Go to previous messageGo to next message
Yes :-(
Nope, l.getMessage() returns "message".
The problem must be something like "enabling" the second column or something
since despite two columns are shown
is never called with a index != 0. That's actually the problem, everytime
getColumnText() is called, it is called with index == 0.
Cheers
Timo
Re: [OT?] TableViewer with multiple colums [message #145070 is a reply to message #144879] Thu, 16 October 2003 12:50 Go to previous messageGo to next message
Simply create a sample View plugin using eclipse' wizard and add
TableColumn column;
column.setText("Name");
column.setWidth(200);
column.setText("Size");
column.setWidth(100);
in createPartControl() directly after the viewer stuff.
Re: [OT?] TableViewer with multiple colums [message #145102 is a reply to message #145057] Thu, 16 October 2003 13:01 Go to previous messageGo to next message
something
Another long shot... I recall seeing something similar once; I think it
was down to me connecting the the wrong label provider.
Where: MyTableLP (implemented ITableLabelProvider) and extended
MyListLP which extended
LabelProvider
I just tested this by replacing the MyTableLP with a MyListLP and saw
exactly the behaviour you describe. If it's not that you're somehow
connected to an old (non ITableLabelProvider) label provider then I'm
right out of ideas!
rich
Re: [OT?] TableViewer with multiple colums [message #145495 is a reply to message #145102] Fri, 17 October 2003 03:46 Go to previous messageGo to next message
> LabelProvider
> right out of ideas!
class ViewLabelProvider extends LabelProvider
implements
ITableLabelProvider
Line l = (Line)obj;
switch (index)
case 0 :
case 1 :
return "N/A";
public Image getColumnImage(Object obj, int index)
return getImage(obj);
public Image getImage(Object obj)
return PlatformUI.getWorkbench().getSharedImages()
.getImage(ISharedImages.IMG_OBJ_ELEMENT);
public void createPartControl(Composite parent)
viewer = new TableViewer(parent, SWT.MULTI | SWT.H_SCROLL
| SWT.V_SCROLL);
viewer.setContentProvider(new ViewContentProvider());
viewer.setLabelProvider(new ViewLabelProvider());
viewer.setSorter(new NameSorter());
viewer.setInput(ResourcesPlugin.getWorkspace());
TableColumn column;
viewer.getTable().setHeaderVisible(true);
makeActions();
hookContextMenu();
hookDoubleClickAction();
contributeToActionBars();
uggc://avgjvg.qr
Re: [OT?] TableViewer with multiple colums [message #145521 is a reply to message #145495] Fri, 17 October 2003 04:38 Go to previous messageGo to next message
Hi Timo - Got it :)
The problem was the position of setLabelProvider()... I re-jigged your
sample code and which now works on the my "TestPlugin".
Solved?
Rich
public void createPartControl(Composite parent) {
viewer = new TableViewer(parent, SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL);
TableColumn column;
// moved to below column addition
makeActions();
hookContextMenu();
Re: [OT?] TableViewer with multiple colums [message #145560 is a reply to message #145521] Fri, 17 October 2003 05:52 Go to previous message
> Solved?
YES! Cool, thanks!
....but the wizard should generate a comment for such stuff...
Timo
Previous Topic:breakpoints visible across projects?
Next Topic:Changing IDE background colour under Motif
Current Time: Thu Jul 17 04:44:58 EDT 2025
Powered by FUDForum. Page generated in 0.04059 seconds
