Home » Archived » BIRT » IDeviceRenderer bug?
IDeviceRenderer bug? [message #144833] |
Thu, 16 March 2006 18:34  |
Originally posted by: zerokelvin.gmx.net
hello,
After I finally found where to look at to output my charts I ran into an
exception. I am trying to use the device renderer to output my chart to
a file.
And this is the exception:
org.eclipse.birt.chart.exception.ChartException: $NO-RB$ Source value
can not be null
at org.eclipse.birt.chart.factory.Generator.render(Generator.ja va:1214)
Here is the relevant source code:
--snip--
final PluginSettings ps = PluginSettings.instance();
try {
dRenderer = ps.getDevice("dv.GIF");//$NON-NLS-1$
} catch (ChartException ex) {
ex.printStackTrace();
BufferedImage img = new BufferedImage(500, 500,
BufferedImage.TYPE_INT_ARGB);
Graphics g = img.getGraphics();
Graphics2D g2d = (Graphics2D) g;
dRenderer.setProperty(IDeviceRenderer.GRAPHICS_CONTEXT, g2d);
dRenderer.setProperty(IDeviceRenderer.FILE_IDENTIFIER,"C:\\ChartImage.gif ");
Bounds bo = BoundsImpl.create(0, 0, 500, 500);
bo.scale(72d / dRenderer.getDisplayServer().getDpiResolution());
Generator gr = Generator.instance();
try {
gcs = gr.build(dRenderer.getDisplayServer(), chart, bo, null, null , null);
gr.render(dRenderer, gcs);
} catch (ChartException e) {
e.printStackTrace();
--snip--
IDeviceRenderer bug!!! [message #144855 is a reply to message #144833] |
Thu, 16 March 2006 19:11   |
hello,
I found out the following. If I use the serializer.write method on the
chart before I render it with the device renderer, this exception
occurs. Otherwise I could output it on the device renderer. Same for
charts that I have read with the serializer.
But how can I read a chart representation from an xml representation now
and output it to a renderer?
thank you for your help,
hubi
zero kelvin wrote:
> hello,
> a file.
> can not be null
> --snip--
> try {
> try {
> null);
> --snip--
Re: IDeviceRenderer bug!!! [message #144892 is a reply to message #144855] |
Fri, 17 March 2006 01:58   |
You need to bind the runtime dataset again after you
serialized/deserialized the chart model. the serialization will
eliminate all the runtime information including the runtime dataset.
Zhiqiang Qian
zero kelvin wrote:
> hello,
> hubi
> zero kelvin wrote:
>> hello,
>> an exception. I am trying to use the device renderer to output my
>> chart to a file.
>> can not be null
>> at
>> --snip--
>> try {
>> try {
>> , null);
>> --snip--
Re: IDeviceRenderer bug!!! [message #144925 is a reply to message #144892] |
Fri, 17 March 2006 03:11   |
Thank you for the tip. I already thougt of something like that. But how
can I do this? So far I was only using the chartwizard with my custom
IDataServiceProvider. I dont know what I need to bind now.
hubi
> Zhiqiang Qian
> zero kelvin wrote:
>> hello,
>> now and output it to a renderer?
>> hubi
>> zero kelvin wrote:
>>> hello,
>>> chart to a file.
>>> can not be null
>>> at
>>> --snip--
>>> try {
>>> g2d);
>>> try {
>>> null , null);
>>> --snip--
Re: IDeviceRenderer bug!!! [message #145818 is a reply to message #144925] |
Sun, 19 March 2006 22:23   |
You need to implement the interface IDataRowExpressionEvaluator, then
use Generator.bindData(). The IDataServiceProvider is only used by the
Chart Builder at design time.
Zhiqiang Qian
> hubi
>> Zhiqiang Qian
>> zero kelvin wrote:
>>> hello,
>>> the chart before I render it with the device renderer, this exception
>>> hubi
>>> zero kelvin wrote:
>>>> hello,
>>>> into an exception. I am trying to use the device renderer to output
>>>> my chart to a file.
>>>> value can not be null
>>>> at
>>>> --snip--
>>>> try {
>>>> g2d);
>>>> try {
>>>> null , null);
>>>> --snip--
Re: IDeviceRenderer bug!!! [message #147090 is a reply to message #145818] |
Wed, 22 March 2006 11:48  |
Thank you for the tip... I am now using the bindData method from the
UiHelper class (or similar) to bind the Dataset with the
IDataserviceProvider.
I just got confused by the IDataRowExpressionEvaluator but it works fine
now!
> Zhiqiang Qian
>> how can I do this? So far I was only using the chartwizard with my custom
>> hubi
>>> Zhiqiang Qian
>>> zero kelvin wrote:
>>>> hello,
>>>> exception occurs. Otherwise I could output it on the device
>>>> renderer. Same for charts that I have read with the serializer.
>>>> hubi
>>>> zero kelvin wrote:
>>>>> hello,
>>>>> my chart to a file.
>>>>> at
>>>>> --snip--
>>>>> try {
>>>>> g2d);
>>>>> try {
>>>>> null , null);
>>>>> --snip--
Current Time: Mon Jul 21 23:59:14 EDT 2025
Powered by FUDForum. Page generated in 0.04657 seconds
