Home » Modeling » GMF (Graphical Modeling Framework) » Trying to modify gmfgen to add External Label - info/advice available?
Trying to modify gmfgen to add External Label - info/advice available? [message #144818] Mon, 30 July 2007 13:23 Go to next message
I'm knee deep working on my first GMF based application. I've got a
requirement where I need a label figure that can be moved and placed
independently of the main figure, however still be part of the same edit
part or specifically model element. Basically, I need a label figure
can then be moved around the diagram, renamed, or removed but ultimately
they share the same model element.
I was having a lot of difficulty trying to understand how to do this
manually when I noticed in the gmfgen that you can specify an External
Node Label for my Edit Parts. I think this is what I'm looking for but
I couldn't find any documentation about that option anywhere.
If this is what I'm looking for, it seems that an external node label
requires a "viewmap" and a "diagramRunTimeClass". Not sure what exactly
to put in for those.
Please advise. Thanks!
Matt
Re: Trying to modify gmfgen to add External Label - info/advice available? [message #144918 is a reply to message #144818] Tue, 31 July 2007 05:02 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
TaiPan sample has an external label - port name - so you may have a
look at it. You may add external label to your gmfgen model by creating
GenExternalNodeLabel class inside node. Currently external label may
float within a limited range from the host node but you may provide
your own border item locator for the label so it may be positioned
wherever you want.
> edit part or specifically model element. Basically, I need a label
> figure can then be moved around the diagram, renamed, or removed but
> ultimately they share the same model element.
> exactly to put in for those.
> Matt
Re: Trying to modify gmfgen to add External Label - info/advice available? [message #144953 is a reply to message #144918] Tue, 31 July 2007 08:42 Go to previous messageGo to next message
Matt,
You could use the LabelLocator or ResizableLabelLocator to allow your
label to float anywhere.
Cherie
Dmitry Stadnik wrote:
> TaiPan sample has an external label - port name - so you may have a look
> float within a limited range from the host node but you may provide your
> own border item locator for the label so it may be positioned wherever
> you want.
>> but I couldn't find any documentation about that option anywhere.
>> Matt
Re: Trying to modify gmfgen to add External Label - info/advice available? [message #145870 is a reply to message #144953] Wed, 08 August 2007 17:53 Go to previous message
Thanks for the help!
Matt
Cherie Revells wrote:
> Matt,
> Cherie
>> creating GenExternalNodeLabel class inside node. Currently external
>> label may float within a limited range from the host node but you may
>> provide your own border item locator for the label so it may be
>> positioned wherever you want.
>>> External Node Label for my Edit Parts. I think this is what I'm
>>> looking for but I couldn't find any documentation about that option
>>> anywhere.
>>> Matt
Previous Topic:Compartment - Connection - Layout
Next Topic:How does a nested View's of a shortcut get rendered?
Current Time: Mon Jul 21 22:06:43 EDT 2025
Powered by FUDForum. Page generated in 0.33504 seconds
