Home » Archived » BIRT » show display text of dynamic parameter on report
show display text of dynamic parameter on report [message #144781] Thu, 16 March 2006 16:58 Go to next message
Originally posted by: vladperl.semanticprogrammer.org
I have dynamic parameter called "departmentID" that get value (id) from
dataset "departments".
Dataset "departments" use query: "select id, name from Departments".
How can I get department name from selected row of "departments" dataset?
I need to present name of department on report .
Thank you,
Vladimir
Re: show display text of dynamic parameter on report [message #144848 is a reply to message #144781] Thu, 16 March 2006 19:07 Go to previous messageGo to next message
Originally posted by: David.Peterson.mtvnmix.com
I'm not totally sure what you're asking, but I think you just want to create
the parameter as a dynamic combo box with ID and name, then you can access
directly as
params["Name"]
Re: show display text of dynamic parameter on report [message #145412 is a reply to message #144848] Fri, 17 March 2006 10:58 Go to previous messageGo to next message
Hi David,
Thank you for response.
> create the parameter as a dynamic combo box with ID and name, then you can
> access directly as
> params["Name"]
I have tried that. It doesn't work.
Here is my parameter:
<scalar-parameter name="departmentID" id="11">
<property name="valueType">dynamic</property>
<property name="dataType">decimal</property>
<property name="promptText">Department</property>
<property name="format">Unformatted</property>
<property name="controlType">list-box</property>
<property name="dataSetName">departments</property>
<expression name="valueExpr">row["ID"]</expression>
<expression name="labelExpr">row["Name"]</expression>
<property name="mustMatch">true</property>
<property name="fixedOrder">true</property>
<property name="defaultValue">9</property>
</scalar-parameter>
here is "departments" DataSet:
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="departments" id="6">
<property name="dataSource">midwood</property>
<property name="queryText">select ID, Name
from dbo.Department
order by name</property>
</oda-data-set>
I need to show selected department name.
Thank you,
Vladimir
Re: show display text of dynamic parameter on report [message #145539 is a reply to message #145412] Fri, 17 March 2006 13:23 Go to previous messageGo to next message
<I need to show selected department name.>
I see what you're asking now. The parameter is really the department id.
You don't really have a handle to the combo parameter 'name' part. You have
params["department-id"], but nothing for params["department-name"] as it's
displayed to the user, but it isn't a param per se.
What I do is a bit different. I use the DepartmentID to index into my
departments table to return a dataset for my report. As part of that, I
also return the department-name in dataset query even though I may not
actually need it for the report. Then I display that in my report header as
row["department-name"]. Will this work for you?
So what I have is actually two datasets:
1. dataset departments which is used to form the parameter with query:
select ID, Name from dbo.Department order by name.
2. dataset department which is used in my actual report with query: select
ID, Name from dbo.Department where ID=? <bound to parameter DepartmentID>
and used to display the department name in my report.
is this clear?
Re: show display text of dynamic parameter on report [message #145582 is a reply to message #145539] Fri, 17 March 2006 13:54 Go to previous messageGo to next message
> have params["department-id"], but nothing for params["department-name"] as
> it's displayed to the user, but it isn't a param per se.
> as row["department-name"]. Will this work for you?
> select ID, Name from dbo.Department where ID=? <bound to parameter
> DepartmentID> and used to display the department name in my report.
> is this clear?
Yes it's clear. In fact I use the same approach as you.
Only instead of second query I'm using "getDepartmentByID" stored procedure
with related parameter.
But it doesn't look for me as elegant solution.
We have to use additional dataset and additional report item such as table
with additional parameter bounding just to work out the issue.
I have suggestion to file enhancement. What do you think?
In case you agree with me on this, please make enhancement.
I will add comments later to show them it's not just one developer who need
that enhancement.
Thank you,
Vladimir
Re: show display text of dynamic parameter on report [message #145643 is a reply to message #145582] Fri, 17 March 2006 14:50 Go to previous messageGo to next message
Given all the things that I need from Birt, the lack of elegance isn't a big
issue with me. Combined datasets is a much bigger issue for me.
Re: show display text of dynamic parameter on report [message #145730 is a reply to message #145643] Fri, 17 March 2006 16:42 Go to previous message
I have filed enhancement:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132401
In case you are interesting to get updated on this issue put your e-mail
address there.
Previous Topic:Sybase Stored Proc Issue
Next Topic:getting objects from the session
Current Time: Tue Jul 22 00:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.09620 seconds
