Home » Modeling » GMF (Graphical Modeling Framework) » GENERATION PROBLEM
GENERATION PROBLEM [message #144747] Mon, 30 July 2007 10:50 Go to next message
Originally posted by: prodanov.tk.informatik.tu-darmstadt.de
Hello everyone,
I have a problem wiht the generetion step. As usual I have my metamodel in
ecore file and then I create my emf .genmodel and when I set a "base
package" i.e. com.myproject.managers then GMF generates wrong imports. I
give an example:
"import com.myproject.managers.Metamodel.MetamodelCommons;" is generated
and then when has to use some import it is generated:
"return
Metamodel.MetamodelCommons.MetamodelCommonsPackage.eINSTANCE .getMyElement(); "
where MetamodelCommons is a package in .ecore and in the EMF genmodel.
the right import hast to be "import
com.myproject.managers.Metamodel.MetamodelCommons.MetamodelC ommonsPackage; "
because this is actually the interface to be used(from the generated EMF
code)and then simply:
return MetamodelCommonsPackage.eINSTANCE.getMyElement(); When I don't use
the base Package, it generates the imports properly.
Can somebody help me whit this. I'm suffering from this problem too much.
And it is I think Bug in the GMF Jet generation.
Thanks in advance!
Martin
Re: GENERATION PROBLEM [message #144756 is a reply to message #144747] Mon, 30 July 2007 11:00 Go to previous messageGo to next message
Hi Martin,
If I understand your description correctly, the problem is that the
import statement imports a package name, and not a class name. This is a
known behavior of the GMF generator in some situations. Since there is
no purely semantic way to distinguish between names of packages, classes
and attributes, we employ a heuristics whereas if the name starts with a
lowercase letter, it is assumed to stand for a package, if it is
all-uppercase, it is considered an attribute (with several hardcoded
exceptions, i.e. SWT, NLS and URI), otherwise it is a class/interface.
Your package starts with an uppercase letter, thus failing this heuristics.
I would recommend to change the name of your package to match these
criteria, which do not seem too strict after all.
Boris
Martin Prodanov wrote:
> Hello everyone,
> in ecore file and then I create my emf .genmodel and when I set a "base
> give an example:
> "return
> code)and then simply: return
> MetamodelCommonsPackage.eINSTANCE.getMyElement(); When I don't use the
> much. And it is I think Bug in the GMF Jet generation.
> Thanks in advance!
> Martin
Errata [message #144765 is a reply to message #144756] Mon, 30 July 2007 11:03 Go to previous messageGo to next message
Hi Martin,
In my previous post, the word semantic was used where syntactic was meant.
Boris
Boris Blajer wrote:
> Hi Martin,
> Best regards,
> Boris
>> Hello everyone,
>> metamodel in ecore file and then I create my emf .genmodel and when I
>> set a "base package" i.e. com.myproject.managers then GMF generates
>> wrong imports. I give an example:
>> generated and then when has to use some import it is generated:
>> "return
>> genmodel. the right import hast to be "import
>> EMF code)and then simply: return
>> Thanks in advance!
>> Martin
Re: Errata [message #144774 is a reply to message #144765] Mon, 30 July 2007 11:09 Go to previous message
Thanks for the fast answer Boris!
Cheers
Martin
Previous Topic:Modify values diagram elements variables
Next Topic:Drag from a view, drop onto the diagram, and create a node
Current Time: Sat Jul 26 13:15:15 EDT 2025
Powered by FUDForum. Page generated in 0.06568 seconds
