Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Maven and rmap
Re: [buckminster-dev] Maven and rmap [message #13438] Thu, 27 March 2008 10:05
Hi Imen,
I am not sure I have understood what you mean when you say that "you
must mention the dependency in the RMAP". The RMAP is just a pointer to
the repositories that will or may contain the components you require. A
dependency will be captured by the plugin information where it would be
discovered automatically or it could be expressed explicitly in a
buckminster.cspec that you created. But in a basic plugin development
usecase you would not have to do that.
Could you post the RMAP that you have prepared to this list, so we can
have a look at what you have done so far ? And/or provide as much
additonal context as possible.
Stefan
Imen Kalboussi wrote:
> I think I have solve my problem it was very simple but now I have to
> solve the dependencies between plugins, so if a plugin
> A need a plugin B ; I must mention this kind of dependency on the RMAP
> the problem is that Ilike this plugins would be bring from a maven
> repository
> The only thing that I know is that the pom.xml must be mention but the
> syntax that I wrote is always wrong L
> So is there any one who can give he right syntax when I’m looking
> basically for an extended jar type but assuming Maven repository
> dependency information contained in a Pom.
> Thanks.
> *From:* Imen Kalboussi
> *Sent:* jeudi 27 mars 2008 09:20
> *To:* 'buckminster-dev@eclipse.org'
> *Subject:* how can I build my eclipse plugin?
> Actually I have to build eclipse plugins in order to get at the end an
> artifact (a jar) that contains a plugin and all the plugins that
> depends on him.
> So after writing a CQUERY and RMAP I don’t know how to get the final
> artifact with Buckminster.
> I would be grateful if someone will try to help me .
> Thanks
> _______________________________________________
> buckminster-dev mailing list
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:[buckminster-dev] Maven and rmap
Next Topic:[buckminster-dev] RE: buckminster-dev Digest, Vol 32, Issue 18
Current Time: Sun Aug 31 04:11:14 EDT 2025
Powered by FUDForum. Page generated in 0.05231 seconds
