Re: Report Scripting : change cell background [message #145006 is a reply to message #144663] |
Fri, 17 March 2006 05:48  |
I've found the solution ....
I've created a class which implements ICellEventHandler and applied it
to the specific cell in my rptdesign :
For example :
public class CellImpl implements ICellEventHandler {
public void onCreate(ICellInstance arg0, IReportContext arg1) {
try {
Object data = arg0.getData();
if (data != null) {
if ("".equals(data.toString().trim())) {
arg0.getStyle().setBackgroundColor("yellow");
} catch (Exception e) {
// TODO: handle exception
public void onPrepare(ICell arg0, IReportContext arg1) {}
public void onRender(ICellInstance arg0, IReportContext arg1) {}
Best regards
Dov
Jason Weathersby a écrit :
> You can set the background of a cell using the onCreate and
> this.getStyle().backgroundColor = "blue";
> I assume you want to do this based on a value in the control on the cell.
> If you have a value in a data element called samplevalue in the cell and
> you color the cell if this value is > 5,
> then in the onCreate of the row you could.
> if( this.getRowData().getExpressionValue( "row[SampleValue]" ) > 5 ){
> yellowme = true;
> }else{
> yellowme = false;
> define yellowme in initialize
> yellowme = false;
> finally on the chosen cell
> if( yellowme ){
> this.getStyle().backgroundColor = "Yellow";
> I dont think this will work if you try to to set it on the getValue() of the
> control, because by that time the onCreate has already been executed on the
> cell.
> Jason
> "Dov MORYUSF" <moryusef@hotmail.com> wrote in message
> news:dvc6nk$kh8$1@utils.eclipse.org...
>>Hi to all,
>>Is it possible to change in a row the background of a unique cell ?
>>I've found examples for changing the background of a whole row but not for
>>a cell:
>> http://www.eclipse.org/birt/phoenix/deploy/reportScripting.p hp
>>Thanks a lot for your help
>>DM
FUDForum. Page generated in 0.06343 seconds
