Home » Language IDEs » ServerTools (WTP) » Strange Errors?
Strange Errors? [message #144595] Wed, 19 October 2005 22:44 Go to next message
Eclipse 3.1.1/WTP 0.7.1
I'm noticing strange errors in the "Error Log" such as:
"Contributor org.eclipse.wst.rdb.server.ui.navigator.serverExplorer
cannot be created."
and:
Error 2005-10-19 20:27:35.320 An unexpected exception was thrown.
org.eclipse.wst.common.ui.properties.internal.view.TabbedPro pertyRegistry.getConfigurationElements(TabbedPropertyRegistr y.java:219)
org.eclipse.wst.common.ui.properties.internal.view.TabbedPro pertyRegistry.readTabDescriptors(TabbedPropertyRegistry.java :350)
org.eclipse.wst.common.ui.properties.internal.view.TabbedPro pertyRegistry.getAllTabDescriptors(TabbedPropertyRegistry.ja va:334)
org.eclipse.wst.common.ui.properties.internal.view.TabbedPro pertyRegistry.getTabDescriptors(TabbedPropertyRegistry.java: 283)
org.eclipse.wst.common.ui.properties.internal.provisional.Ta bbedPropertySheetPage.setInput(TabbedPropertySheetPage.java: 542)
org.eclipse.wst.common.ui.properties.internal.provisional.Ta bbedPropertySheetPage.selectionChanged(TabbedPropertySheetPa ge.java:415)
org.eclipse.ui.views.properties.PropertySheet.selectionChang ed(PropertySheet.java:212)
org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(AbstractSelectionService.java:156)
org.eclipse.ui.internal.AbstractSelectionService.setActivePa rt(AbstractSelectionService.java:278)
org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePart Changed(WorkbenchPagePartList.java:59)
at org.eclipse.ui.internal.PartList.setActivePart(PartList.java :117)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2910)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:2512)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:249)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:295)
org.eclipse.ui.internal.PartStack.presentationSelectionChang ed(PartStack.java:788)
at org.eclipse.ui.internal.PartStack.access$0(PartStack.java:77 1)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.jav a:119)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:126)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:267)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:276)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$2.handleEvent(DefaultTabFolder.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 60)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va:3138)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:19 22)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:288)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Strange Errors? [message #144708 is a reply to message #144595] Thu, 20 October 2005 12:53 Go to previous message
These errors obviously should not be occurring. Please open a bug for each
error. It will be very helpful if you can also include what you were doing
with WTP when the error occurred (if you know).
Thanks for reporting these problems.
Lawrence
Previous Topic:WSDL file generated by WTP
Next Topic:JBossIDE strange packaging
Current Time: Sat Oct 11 16:35:55 EDT 2025
Powered by FUDForum. Page generated in 0.04383 seconds
