Home » Newcomers » Newcomers » Working Programm not working with eclipse
Working Programm not working with eclipse [message #144489] Wed, 22 March 2006 11:31 Go to next message
Originally posted by: shamino.unicum.de
I created a minor Java GUI with swing using JPad Pro.
Now i wanted to try Eclipse.
I created a new project imported my java files and it worked
fine so far. BUT when i run my project my programm is not working properly.
It will show the contentPane but its empty no buttons no text area no
nothing..
And it totaly blew my mind when i noticed that running the program several
times without closing it makes it actually work sometimes !!
Me and Eclipse cant find any Bugs..
I reinstalled eclipse several times..
Any ideas ?
Re: Working Programm not working with eclipse [message #144507 is a reply to message #144489] Wed, 22 March 2006 13:17 Go to previous messageGo to next message
i am using eclipse 3.2
system library 1.5.0_03
win 2000
and someone else tried my programm with eclipse 3.0 on win XP and it was
working..
now i dont know if it is the version or something in the configuration...
i deleted my projects created them new over and over again cant see the
problem.. i also asked the other guy and i did exactly what he did..
-> not working for me..
eclipse should have all the necessary classes or not ?
do i have to install anything else ? any add ons ?
Re: Working Programm not working with eclipse [message #144540 is a reply to message #144489] Wed, 22 March 2006 19:35 Go to previous messageGo to next message
i upgraded my jre to 1.5.0_06 still not working..
i just visited a friend and i tried my program on his pc
with the same eclipse version and it was working fine..
do you think it could be my graphic card ?
i found the bug but still need help [message #144631 is a reply to message #144489] Thu, 23 March 2006 09:40 Go to previous messageGo to next message
hi again..
ok it was my graphic card
i installed new drivers of my ati radeon card and now its showing the gui
but its still buggy.. some features are not working properly..
anyone knows a way to make java swing work with an ati radeon card ?
maybe i should go to a java forum now but thanks anyway...
Final Solution was [message #144648 is a reply to message #144489] Thu, 23 March 2006 10:20 Go to previous messageGo to next message
I found another package on the ati website..
Installed the Microsoft .NET Framework
and now everything is working properly..
thanks if someone cared anyways...
Re: Final Solution was [message #144679 is a reply to message #144648] Thu, 23 March 2006 13:51 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
The ATI website lists the .NET framework as a required download to their
catalyst drivers.
Re: Final Solution was [message #144825 is a reply to message #144679] Fri, 24 March 2006 07:00 Go to previous message
Yes this is very true.
And of course it was my fault.
But the question remains :
Why was my programm working with JPad Pro
and not working with eclipse ?
My guess eclipse is more complicated thus using more libraries then JPad.
Previous Topic:jdk help
Next Topic:Eclipse doesnŽt start
Current Time: Sun Jul 13 16:29:19 EDT 2025
Powered by FUDForum. Page generated in 0.50624 seconds
