XML Validator hangs [message #144394] |
Wed, 19 October 2005 04:56  |
Originally posted by: lf_killspam.hemmis.be
I am using wtp1.0M8 and am experiencing problems with the XML validator
(I had the same problemns with 1.0M7). I recently did a full rebuild of
my project and the XML validator keeps on hanging. The progress window
just says 'Performing XML validation on project ...' and nothing
happens. I have to kill the eclipse process to make it stop. But as soon
as I restart, and automatic build starts, it hangs again on XML validation.
So I have turned of XML validation for now, but would like to know how I
could find out what file the XML validator is choking upon. Now I don't
know if the problem is related to an error in my XML files or to a bug
in WTP.
Also, could anyone tell me if there is documentation on how to use the
XML catalog in eclipse? I have been able to define certain entries in
it, but am getting errors on the validation of my webservices xml files
(that was before the XML validator kept hanging on validation). See my
post of 30 sept 2005. I don't understand how I should add entries for
schemalocations like 'http://java.sun.com/xml/ns/j2ee
http://www.ibm.com/webservices/xsd/j2ee_web_services_1_1.xsd'
Thanks a lot.
Luc
Re: XML Validator hangs [message #144603 is a reply to message #144429] |
Thu, 20 October 2005 02:15   |
Wolfgang,
thanks for the reply. The problem was related to your suggestion.
Eclipse could connect to the internet (my proxy settings are OK), but
one of the sites containing a required xsd was down. Copying the xsd
locally solved the 'hanging' problem.
But the underlying problem still remains: It is pretty hard to find out
what file is actually causing the XML validator to get stuck. Is there a
way to see what file the validators are processing? That would help an
awful lot in case of problems like this one. I hope someone can give me
a hint.
Thanks a lot.
Luc Feys
Wolfgang Knauf wrote:
> Hi Luc,
> can Eclipse connect to the internet ? I saw this behaviour with WTP
> 1.0M8 when sitting behind a proxy server. After having configured the
> proxy it worked fine.
> Hope I could help
> Wolfgang
> Luc Feys wrote:
>> Hello,
>> validator (I had the same problemns with 1.0M7). I recently did a full
>> rebuild of my project and the XML validator keeps on hanging. The
>> progress window just says 'Performing XML validation on project ...'
>> and nothing happens. I have to kill the eclipse process to make it
>> stop. But as soon as I restart, and automatic build starts, it hangs
>> I could find out what file the XML validator is choking upon. Now I
>> don't know if the problem is related to an error in my XML files or to
>> a bug in WTP.
>> files (that was before the XML validator kept hanging on validation).
>> See my post of 30 sept 2005. I don't understand how I should add
>> entries for schemalocations like 'http://java.sun.com/xml/ns/j2ee
>> Thanks a lot.
>> Luc
Re: XML Validator hangs [message #144776 is a reply to message #144701] |
Fri, 21 October 2005 04:06  |
Thanks for the information.
There is already an existing enhancement request to show more details
during validation. I found it in bug 110428.
lmandel@ca.ibm.com wrote:
> Hi Luc,
> Several people have reported the disconnected XML validation problem you
> ran into. We're looking into this (see bugs 110618 and 112970) and, I
> hope, will have a solution for in M9.
> WRT which file is validating, I'd think the validation framework can
> probably display this information in the progress bar. Please open an
> enhancement request against the framework for this and we can look into
> it.
> Lawrence
FUDForum. Page generated in 0.25755 seconds
