Home » Newcomers » Newcomers » jdk help
jdk help [message #144392] Wed, 22 March 2006 05:54 Go to next message
hi there,
how do I make "F1" work in eclipse,
I want to press "F1" and get the javadoc abut this function/keyword
10x
Re: jdk help [message #144533 is a reply to message #144392] Wed, 22 March 2006 17:47 Go to previous messageGo to next message
Originally posted by: csae7511.uibk.ac.at
If you want to get javadoc from the JDK, you have to switch from your
jre to your jdk in:
Window --> Preferences --> Java --> Installed JREs
Usually you'll get the javadoc by hovering over a function / field /
etc. or pressing F2 when you are with the cursor over it.
Hope that helps,
Stefan
cyclop schrieb:
> hi there,
> 10x
Re: jdk help [message #144748 is a reply to message #144392] Thu, 23 March 2006 17:17 Go to previous messageGo to next message
cyclop wrote:
> hi there,
> 10x
As Stefan said, you can pull the JDK source into eclipse. There are
more detail instructions at
http://www.eclipsezone.com/eclipse/forums/t49624.html
You can use Shift-F2 to launch a browser with the javadoc in it. By
default, when I select a JDK identifier such as String and hit shift-F2,
my browser opens to a web page at Sun with the javadoc.
Jeff
Re: jdk help [message #144816 is a reply to message #144392] Fri, 24 March 2006 06:23 Go to previous message
Originally posted by: nk_smallbee.yahoo.com.cn
Write a plugin you self to hook the F2 maybe a good idea :D
Previous Topic:two web projects use same servlets
Next Topic:Working Programm not working with eclipse
Current Time: Tue Jul 22 02:35:08 EDT 2025
Powered by FUDForum. Page generated in 0.13675 seconds
