Home » Archived » BIRT » How to integrate data from 2 or more Sources in one report?
How to integrate data from 2 or more Sources in one report? [message #144391] Thu, 16 March 2006 02:19 Go to next message
Some time we want to make a report that includes data from serveral
diffrent database, how to do this?
Re: How to integrate data from 2 or more Sources in one report? [message #144408 is a reply to message #144391] Thu, 16 March 2006 04:48 Go to previous messageGo to next message
Originally posted by: rebprotizer_2k3.hotmail.com
Hi Aaron,
I have tested to create 2 data sources : one postgreSQL JDBC access and on
XML datasource.
Then, I have inserted a grid of 2 columns and 1 line, and a table in each
column of the grid. In the first i put data of JDBC access and in the
other one data of XML file.
And when i'm running the report i'have data of my 2 different sources in
each columns.
But if you want to create a report with one table and join the 2 sata
sources in this one, i don't know how to do this, because one table is
linking with one dataset.
Re: How to integrate data from 2 or more Sources in one report? [message #144746 is a reply to message #144391] Thu, 16 March 2006 16:17 Go to previous messageGo to next message
Originally posted by: David.Peterson.mtvnmix.com
https://bugs.eclipse.org/bugs/show_bug.cgi?id=132245
I've added in a feature request for this. Feel free to monitor and vote for
it.
Re: How to integrate data from 2 or more Sources in one report? [message #144772 is a reply to message #144408] Thu, 16 March 2006 16:45 Go to previous messageGo to next message
I've had some success accessing data from my outer table in the innertable
of the same row. If the fieldname that I want to access in the outer table
is called NumReceived, you'd normally try:
row["NumReceived"]
However that won't work, this does however seem to work:
rows[0]["NumReceived"]
(assuming that the outer table is the outermost object). If for instance
you have an outer grid and then a table with a subtable, then you'd use
rows[1]["NumReceived"]
Milestone is 2.1.0 RC0 [message #145068 is a reply to message #144391] Fri, 17 March 2006 08:42 Go to previous message
Target Milestone is 2.1.0 RC0
https://bugs.eclipse.org/bugs/show_bug.cgi?id=131040
http://www.eclipse.org/birt/release20specs/DataSetJoinSpec.p df
Previous Topic:java.lang.OutOfMemoryError: PermGen
Next Topic:import ing java objects in Scripted datasource
Current Time: Thu Jul 17 21:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.08689 seconds
