debug error mi_cmd_env_cd [message #144186] |
Thu, 28 April 2005 20:44 |
I'm having a problem debugging with eclipse on linux.
Build & run work fine but when I go to debug I get this error msg:
"Failed to set program arguments, environemt or working directory.
Unable to set working directory: mi_cmd_env_cd: Usage DIRECTORY"
gdb is installed and seems to work correctly for KDevelop and from the
command line.
I've searched and can find very little info on what could be causing this
error.
Its bound to be some silly configuration error, somewhere, any ideas,
anyone?
Thanks George
I've tried eclipse 3.02 with cdt 2.1.1 and 3.1M6 with cdt 3.
jdk 1.5 update 2
Ubuntu Hoary. gdb 6.3, gcc 3.3, kernel 2.6.10-5_amd64.
It may be the whole64-bit thing but I suspect not.
FUDForum. Page generated in 0.03449 seconds
