UML Import [message #13385] |
Fri, 30 January 2009 04:43  |
I am coming back to a subject that might have already been discussed
several times.
I have a UML model, the SID, in RSM 7.5. I have tried a simple import into
a blank Tigerstripe project.
I arrive at the model mapping part and I have nearly hundreds of objects
with a question mark.
Not being a specialist of the whole SID, I don't see how I can on the fly
modify all these mappings and furthermore, 2 different peoples doing the
same import are likely to make different choices.
Is there a way to automate this more? For instance, is there some
stereotypes that Tigerstripe recognizes that I can put in my RSM model to
indicate the type of artifact? or is there a way to record the choice of
mapping made in a config file that would be reused for subsequent mappings?
Marc
FUDForum. Page generated in 0.24529 seconds
