Home » Eclipse Projects » JFace » [Databinding] binding to objects attributes
[Databinding] binding to objects attributes [message #13379] |
Wed, 10 June 2009 08:32  |
is it possible to bind to attributes of objects within objects?
E.g. I have an Object Person with the attributes:
String firstName;
String lastName;
Address address;
where Address is an object with the attribute:
String street;
Can I bind direct to street via the person object? Something like this:
BeansObservables.observeValue(person, "address.street");
Or do I to use
BeansObservables.observeValue(person.getAddress(), "street");
Best regards, Lars
Re: [Databinding] binding to objects attributes [message #14063 is a reply to message #13400] |
Wed, 10 June 2009 10:33   |
Hi Tom,
xool, this is a nice feature in Eclipse 3.5.
I'll add a beans example to my databinding tutorial and put your blog
entries as references into it:
http://www.vogella.de/articles/EclipseDataBinding/article.ht ml
Thank you,
Lars
Tom Schindl wrote:
> With 3.4 you need to do this your own
> -----------8<-----------
> IObservable parent = BeansObservables.observeValue(person,"address");
> IObservableValue child =
> BeansObservables.observeDetail(parent,"street",Person.class);
> With 3.5 this works out of the box (when using Properties-API):
> IObservableValue v = BeanProperties.value("address.street").observe(person);
> You can read some details in my current blog. I'm discussing this at
> EMF-Level but the code is the same for Beans. The nice thing with 3.5 is
> that this even works in Table/Trees :-)
> Tom
> [1] http://tomsondev.bestsolution.at/2009/06/07/galileo-emf-data binding-part-2/
> Lars Vogel schrieb:
>> String firstName;
>> String lastName;
>> Address address;
>> String street;
>> Or do I to use
>> Best regards, Lars
Re: [Databinding] binding to objects attributes [message #14130 is a reply to message #13400] |
Wed, 10 June 2009 15:30   |
Hi Tom,
thanks again, I included a tiny bean example for the Properties API in
my tutorial.
Best regards, Lars
Tom Schindl wrote:
> Tom
> Lars Vogel schrieb:
>> String firstName;
>> String lastName;
>> Address address;
>> String street;
>> Or do I to use
>> Best regards, Lars
Re: [Databinding] binding to objects attributes [message #14147 is a reply to message #14130] |
Wed, 10 June 2009 17:56  |
I just saw that there's a bug in my example :-) Naturally the second
line should be:
BeansObservables.observeDetail(parent,"street",Address.class);
Tom
Lars Vogel schrieb:
> Hi Tom,
> my tutorial.
> Best regards, Lars
> Tom Schindl wrote:
>> Tom
>> Lars Vogel schrieb:
>>> Hi,
>>> String firstName;
>>> String lastName;
>>> Address address;
>>> String street;
>>> Or do I to use
>>> Best regards, Lars
Current Time: Sun Aug 31 04:11:17 EDT 2025
Powered by FUDForum. Page generated in 0.06476 seconds
