Home » Newcomers » Newcomers » attaching source hangs for 5 minutes
attaching source hangs for 5 minutes [message #143943] Sun, 19 March 2006 19:05 Go to next message
Originally posted by: adam.no.spam.cyberspaceroad.spam
This is v 3.1.1
If I attach the source code of an external jar using the 'Attach
Source...' button on the class in the Java editor when the jar has
previously no source attachment, it takes ages and ages, at least 5 minutes.
When it unfreezes, the source code file is not opened either, Eclipse
shows the previous Java file in the Java editor, so it looks like
something on the 'attach source' process crashed, although there are no
errors logged.
However, the source is at that point thereafter still attached.
Eclipse is great but seems to be creaking under the load - I use all
projects with ClearCase plugin, XmlBuddy, Amateras JSP editor, SQL
Explorer, Spring-IDE. Could these be causing problems?
Adam
Re: attaching source hangs for 5 minutes [message #145698 is a reply to message #143943] Thu, 30 March 2006 13:11 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
adam wrote:
> This is v 3.1.1
> minutes.
> errors logged.
That is definitely not normal behavior - I've used Attach Source for
years and never see it do that.
My first guess would be that it is related to ClearCase integration.
What type of view(s) are you using? It is possible that the
network/ClearCase overhead is giving Eclipse some trouble. Is the JAR
that you're attaching source for in your ClearCase view? Is it local or
remote? What about the source location you are using?
Hope this helps,
Eric
Previous Topic:Search whole word in many files
Next Topic:Dependency Check and automatic download
Current Time: Thu Jul 17 19:21:41 EDT 2025
Powered by FUDForum. Page generated in 0.07646 seconds
