Home » Modeling » MoDisco » Java code generation from MoDisco J2SE5 models?
Java code generation from MoDisco J2SE5 models? [message #1091] Thu, 07 May 2009 11:35 Go to next message
Is there a way to transform a MoDisco J2SE5 model to a corresponding
Java code?
Roman
Re: Java code generation from MoDisco J2SE5 models? [message #1119 is a reply to message #1091] Fri, 08 May 2009 05:00 Go to previous messageGo to next message
It is not provided yet but it is a feature we have planned to add.
The simplest way to do this is to develop a code generator (by using a M2T
component).
Re: Java code generation from MoDisco J2SE5 models? [message #1144 is a reply to message #1119] Fri, 08 May 2009 07:15 Go to previous message
It took me about 250 lines of code in Xpand to generate Java code from
J2SE5 model for my purposes. It is not hard, but still need some testing.
I have skipped generics and comments as I don't need them right now.
Probably I will be able to share that work but not before July.
Krzysztof Kowalczyk
Re: Java code generation from MoDisco J2SE5 models? [message #573170 is a reply to message #1091] Fri, 08 May 2009 05:00 Go to previous message
component).
Re: Java code generation from MoDisco J2SE5 models? [message #573192 is a reply to message #1119] Fri, 08 May 2009 07:15 Go to previous message
Krzysztof Kowalczyk
Previous Topic:Java code generation from MoDisco J2SE5 models?
Next Topic:UML Diagram Generation
Current Time: Mon Jul 07 16:33:21 EDT 2025
Powered by FUDForum. Page generated in 0.47094 seconds
