Problem with PrintAction [message #143548] |
Tue, 20 July 2004 09:54  |
Originally posted by: markp.softlanding.com
I tried adding this in an old thread but did not get any replies.
I have moved to GEF 3.0, and I have a diagramming app that uses the
default PrintAction to provide printing support. In general this works
much better than 2.1 did. However, there is one problem from 2.1 that
still exists and I thought had been fixed by this bug based on threads
on this list.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=28766
My diagram uses GIF's next to some of the labels to decorate them, kind
of how you might decorate a method or field in a class diagram.
Anyway, those GIF's do not print, instead I get a black dot. I think
in 2.1 it just didn't print anything.
I am not really clear on what the root of the problem is based on the
Bugzilla above. Would there be a way to work around the problem by
using a different graphic format like PNG?
Mark
Re: Problem with PrintAction [message #145915 is a reply to message #145742] |
Mon, 02 August 2004 10:35  |
Randy,
I was just curious as to whether you plan on taking a look at the Test
case I submitted to see if it was a problem in something I was doing,
or whether it really is an SWT problem.
I noticed you had added some comments and samples to the bug before me,
and yours mentioned something about a stretched image. I didn't think
I was doing anything other than supplying an image. Maybe I am
supposed to set a size for it somewhere?
Mark
Mark Phippard wrote:
> Randy,
> I just attached a zip file to the bugzilla. It is a HelloWorld GEF
> editor project that shows the problem.
> Thanks
> Mark
> Randy Hudson wrote:
> > Please provide the simple image and testcase and attach it to the
> > bugzilla below.
> > "Mark Phippard" <markp@softlanding.com> wrote in message
> > news:cdj86c$ave$1@eclipse.org...
> > > the default PrintAction to provide printing support. In general
> > > this works much better than 2.1 did. However, there is one
> > > problem from 2.1 that still exists and I thought had been fixed
> > > by this bug based on threads on this list.
> > > kind of how you might decorate a method or field in a class
> > > diagram. Anyway, those GIF's do not print, instead I get a black
> > > dot. I think in 2.1 it just didn't print anything.
> > > the Bugzilla above. Would there be a way to work around the
> > > problem by using a different graphic format like PNG?
> > > Thanks
> > > Mark
FUDForum. Page generated in 0.05088 seconds
