Home » Modeling » GMF (Graphical Modeling Framework) » Compatibility GMF1.0.3 / GMF2.0
Compatibility GMF1.0.3 / GMF2.0 [message #143311] Wed, 18 July 2007 11:28 Go to next message
Originally posted by: Halimatou.Pouye-Diaw.thomson.net
Hi, everybody
I worked on a model with GMF 1.0.3. which contains for example some
compartments (a node X can contain many nodes X recursively). It works
fine.
I migrated to GMF 2.0 and I no longer can add a node X in the editor.
The compatibility GMF1.0.3 / GMF2.0 is not ensured?
Thanks for any reply.
Lima.
Re: Compatibility GMF1.0.3 / GMF2.0 [message #143326 is a reply to message #143311] Wed, 18 July 2007 12:38 Go to previous messageGo to next message
Hi Lima,
Have you actually "migrated", that is, used the right-click "Migrate to
GMF 2.0" action on gmfmap and gmfgen models?
Andrew
Re: Compatibility GMF1.0.3 / GMF2.0 [message #143386 is a reply to message #143326] Thu, 19 July 2007 04:17 Go to previous messageGo to next message
Hi, Andrew
Thank you for your reply.
Yes effectively, I used the "Migrate to GMF 2.0" action for the GMF graph,
the GMF map and I regenerated the GMF gen.
I can't understand why a model working with GMF1.0.3 doesn't work with
GMF2.0.
Lima.
Re: Compatibility GMF1.0.3 / GMF2.0 [message #144048 is a reply to message #143311] Wed, 25 July 2007 07:56 Go to previous message
Hello Lima,
It should be. Can you please find the problem in your particular case and
report an error - we will fix it.
Alex Shatalin
Previous Topic:Override "DEL" keybinding in diagram
Next Topic:Connection to a shortcut
Current Time: Mon Jul 21 22:22:52 EDT 2025
Powered by FUDForum. Page generated in 0.05486 seconds
