Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP has Open API?
TPTP has Open API? [message #143308] Mon, 20 July 2009 08:09 Go to next message
Originally posted by: egidijus.vaisnora.nomagic.com
Does TPTP has an open API, that I could use it easily without interacting UI (only by code), store performance result in DB and
use DB data for generating reports?
In short - can I use TPTP as an replacement for org.eclipse.test.performance plugin?
Thank you
Re: TPTP has Open API? [message #143331 is a reply to message #143308] Tue, 21 July 2009 06:27 Go to previous message
Hi Egidijus,
Yes, the TPTP Test Project is built on EMF models for test artifacts,
test behaviors, and execution histories. However, we do not have support
for database persistence layer. For more information, see:
http://www.eclipse.org/tptp/test/documents/index.php >> EclipseCon 2007:
Testing Java Applications Using TPTP >> TPTP EMF Data Models
http://www.eclipse.org/tptp/test/documents/index.php >> TPTP Testing Tools
Project Architecture
http://www.eclipse.org/tptp/test/documents/index.php >> Javadoc HTML
documentation
http://www.eclipse.org/tptp/platform/documents/index.php >> TPTP EMF model
documentation (4.1.0)
Unfortunately, I am not familiar with the org.eclipse.test.performance
plug-in so I cannot compare/contrast the two.
Paul
"Egidijus Vaisnora" <egidijus.vaisnora@nomagic.com> wrote in message
news:h41mmq$h8c$1@build.eclipse.org...
> UI (only by code), store performance result in DB and use DB data for
> generating reports?
> Thank you
Previous Topic:Running TPTP
Next Topic:Profiler Panic
Current Time: Fri Jul 18 21:48:53 EDT 2025
Powered by FUDForum. Page generated in 0.04407 seconds
