Home » Eclipse Projects » Subversive » Cannot figure out how to get a specific verion
Cannot figure out how to get a specific verion [message #13237] Fri, 08 February 2008 20:09 Go to next message
I'm trying to get a specific revision of the repository but cannot
figure out how to do it.
"CheckOut" and Checkout as" do not have a filed to enter the revision
number.
Ray
Re: Cannot figure out how to get a specific verion [message #13267 is a reply to message #13237] Sat, 09 February 2008 05:09 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hi Ray,
Definitely the Subversive UI should be improved in order to make this
operation clean, but you can do this with existing Subversive version.
Please make revision link to required revision using "Add Revision Link"
pop-up menu item, then go to "Revision Link" and checkout it.
Re: Cannot figure out how to get a specific verion [message #13854 is a reply to message #13237] Thu, 21 February 2008 08:54 Go to previous message
Originally posted by: d.d.com
I usually use "Switch..." command
"Ray Hurst" <rhurst2@cox.net> ha scritto nel messaggio
news:foiuhe$fc4$1@build.eclipse.org...
> I'm trying to get a specific revision of the repository but cannot figure
> out how to do it.
> number.
> Ray
Previous Topic:Update site broken?
Next Topic:Subversive and Subversion 1.5
Current Time: Mon Dec 01 05:07:33 EST 2025
Powered by FUDForum. Page generated in 0.10080 seconds
