Home » Eclipse Projects » DTP » [rdb] DDL generate for one column only
[rdb] DDL generate for one column only [message #1088] Fri, 29 July 2005 08:36 Go to next message
Hi all,
Can we please change 'createSQLObjects' on DDLGenerator to produce output
even if only a single Column object is passed in the SQLObject[]. We need
this for the EJB3 ORM 'columnDefinition' annotations parameter.
Dirk le Roux
Re: [rdb] DDL generate for one column only [message #1120 is a reply to message #1088] Wed, 03 August 2005 12:17 Go to previous message
Hi All,
OK, I've looked at the code and am now retracting my request. It was a bad
idea. I'll parse the table string to find the col bits.
Dirk le Roux
Re: [rdb] DDL generate for one column only [message #566244 is a reply to message #1088] Wed, 03 August 2005 12:17 Go to previous message
Hi All,
Dirk le Roux
Previous Topic:[rdb] DDL generate for one column only
Next Topic:Subproject leads for DTP
Current Time: Fri Jul 25 21:18:19 EDT 2025
Powered by FUDForum. Page generated in 0.04989 seconds
