Home » Archived » BIRT » Static Birt Reports
Static Birt Reports [message #143247] Sun, 12 March 2006 01:40 Go to next message
Originally posted by: vksharma44.hotmail.com
I am querying a very large Data Set 5 Million rows and the report
generation is slow. Is there any way I can generate the report every
night and deploy it as a HTML so that end users always see the HTML and do
not have to run the report query and load the server.
Re: Static Birt Reports [message #143636 is a reply to message #143247] Mon, 13 March 2006 18:22 Go to previous messageGo to next message
Originally posted by: tom.tom.com
That will be good to know. Please help anyone.
Re: Static Birt Reports [message #143838 is a reply to message #143247] Tue, 14 March 2006 17:42 Go to previous messageGo to next message
Not sure if this is possible. Anyone.
Re: Static Birt Reports [message #143849 is a reply to message #143838] Tue, 14 March 2006 18:33 Go to previous messageGo to next message
Originally posted by: ian.marlier.studentuniverse.com
A slightly different way, that should work...
(Assumes a linux server, with some kind of a static web server install, be
it apache or something else)
wget -O /path/to/apache/root/dailyReport.html
" http://birt.server/run?__report=myreport.rptdesign&myfir stparameter=paramvalue&mysecondparameter=anotherparamval ue"
There may be a way to do it within BIRT directly, but if so I don't know
what it is...
Re: Static Birt Reports [message #143968 is a reply to message #143247] Wed, 15 March 2006 09:36 Go to previous messageGo to next message
Originally posted by: b.noemailspam.nothere
You can use the Engine API RunAndRender task to generate your report as
an html file and drop it into a directory of your choice.
See the BIRT Report Engine API page.
http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
You could then use cron or similar to start the report generation each
evening.
> do not have to run the report query and load the server.
Re: Static Birt Reports [message #144166 is a reply to message #143247] Wed, 15 March 2006 13:59 Go to previous messageGo to next message
[Another message in this thread describes something similar.]
OpenSymphony's Quartz comes to mind. Set up a "job" in Quartz to
do the report generation at a convenient hour (in the middle
of the night). Set the output of the report to the expected
location in your Web app's directories. BIRT's runtime engine
would crank out the report. Your code would update a "reports"
table in your database with a new report entry.
You choose your design: save the report to a blob in the "reports"
table or save it to the file system. (I usually prefer the latter.
That requires that I save the filename as part of each record in
the "reports" table.)
The Web page which provides links to daily reports would
of course be dynamic -- i.e., your code should read the db table
which maintains the link/filename information for each daily report
and create the appropriate links.
Quartz is here:
http://www.opensymphony.com/quartz/
Quartz tutorial:
http://www.opensymphony.com/quartz/wikidocs/Cookbook.html
Here's an O'Reilly article to get you started:
http://www.onjava.com/pub/a/onjava/2006/03/01/job-scheduling -in-web-application.html
And finally, do it in Spring:
http://www.springframework.org/docs/reference/scheduling.htm l
Paul Furbacher
http://www.teamb.com
Re: Static Birt Reports [message #144728 is a reply to message #144166] Thu, 16 March 2006 16:02 Go to previous message
Originally posted by: m.n.com
And see what is being done with Pentaho. www.pentaho.org
>> and do not have to run the report query and load the server.
> Quartz is here:
> Quartz tutorial:
> Paul Furbacher
Previous Topic:Multi-select in combo box parameters?
Next Topic:Multiple Masterpages?
Current Time: Fri Jul 18 12:07:56 EDT 2025
Powered by FUDForum. Page generated in 0.38668 seconds
