Home » Eclipse Projects » Eclipse Platform » Cross version API compatibility
Cross version API compatibility [message #143233] Mon, 13 October 2003 15:01 Go to next message
Originally posted by: matt_conway.nospam.i2.com
I compile my plugin against eclipse 3.0M4, and try and run it in eclipse
2.1.1, and get the following verify error. Is this expected behavior?
i.e. should eclipse 3.0 be able to build plugins for use on both
versions? If not, how do I build a multi version plugin, expecially
when the plugin uses API (code reached through a extension point that
doesn't get triggered in 2.1) that only exist in 3.0? Thanks,
Matt
java.lang.VerifyError: (class: net/sourceforge/eclipseccase/MoveHandler,
method: validateDest signature:
(Lorg/eclipse/core/resources/IResource;Lorg/eclipse/core/run time/IProgressMonitor;)Lorg/eclipse/core/runtime/IStatus;)
Incompatible object argument for function call
Re: Cross version API compatibility [message #143348 is a reply to message #143233] Mon, 13 October 2003 21:45 Go to previous message
Originally posted by: bob.objfac.com
"Matt Conway" <matt_conway@nospam.i2.com> wrote in message
news:bmesqi$jdd$1@eclipse.org...
It would be the expected behavior if the type of the argument changed
between 2.1.1 and 3.0M4.
> versions?
Oh, heck no. If you're lucky you may be able to go forward from 2.1.1 to
3.0. At least, an effort is made to make this work. But going back from 3.0
to 2.1.1 isn't in the cards.
A really good question.
The standard way to deal with version incompatibilities like this is to
engineer two (or more) loads that will fail if a particular version is not
present, that can be used as a test. Then provide two alternative ways of
doing the same thing and don't call/load classes that aren't going to work.
James Clark uses this technique in Jing to adapt to the regex packages in
Xerces 1 or Xerces 2. However, this only works if the two versions don't
have a class that is present in both but incompatible with each other, or
you will get verify errors like that one.
It is probably simpler to maintain two different versions and let your users
download one or the other.
Bob
> Matt
Previous Topic:Help! Cannot cast Selection to anything useful
Next Topic:Problem with IResourceChangeEvent ??
Current Time: Fri Jul 18 11:53:41 EDT 2025
Powered by FUDForum. Page generated in 0.04142 seconds
