Home » Language IDEs » Java Development Tools (JDT) » custom launch configuration vs. bootclasspath
custom launch configuration vs. bootclasspath [message #143207] Wed, 18 February 2004 18:42 Go to next message
Originally posted by: brian_vosburgh.yahoo.com
I am trying to configure a custom launch configuration that does not use
the default classpath. I want to add a number of jars that are not used
during build. But this seems to trigger something in the launcher that
thinks I want a custom bootclasspath also. I cannot figure out any way to
stop the launcher from starting my program with a -Xbootclasspath option.
This causes problems with JCE (I get a NoSuchAlgorithmException when the
bootclasspath is specified and things work fine when there is no
bootclasspath specified). Of course, if anyone could tell me how to get
eclipse to configure my bootclasspath to work with JCE, that would be
helpful also.
Thanks.
Brian
Re: custom launch configuration vs. bootclasspath [message #143227 is a reply to message #143207] Wed, 18 February 2004 19:01 Go to previous messageGo to next message
You have found a bug that is fixed in the latest builds of the 3.0 stream.
You did not indicated which build you are using (please always do this as it
helps us help you), but this has been fixed in builds > M5
There is a workarounds listed in the bug report
https://bugs.eclipse.org/bugs/show_bug.cgi?id=38370
if you do not wish to upgrade (see comment #13)
HTH
Darins
"Brian Vosburgh" <brian_vosburgh@yahoo.com> wrote in message
news:c10t8b$660$1@eclipse.org...
> helpful also.
> Thanks.
> Brian
Re: custom launch configuration vs. bootclasspath [message #143235 is a reply to message #143227] Wed, 18 February 2004 20:10 Go to previous message
Thanks, Darin. I am using 2.1.2, and the workaround worked for me. I guess
I searched the newsgroups for this problem, but not bugzilla. Sorry about
that.
Thanks for the quick response.
Brian
> HTH
> Darins
> > helpful also.
> > Thanks.
> > Brian
Previous Topic:(pde junit) test actions
Next Topic:getting started with eclipse - java webapp development
Current Time: Mon Jul 21 22:08:16 EDT 2025
Powered by FUDForum. Page generated in 0.42337 seconds
