Home » Archived » Visual Editor (VE) » Unable to load class error
Unable to load class error [message #143171] Mon, 26 November 2007 14:30 Go to next message
Originally posted by: kamran.hamid.niit.edu.pk
Hello Folks.. i am a newbie to VE. i downloaded it and installed the
plugin.
Now when i create the visual class, and then try to run it like
run->java bean
it gives me error
IWAV0049E Unable to load class javas.threadss.First
Here is my code
package javas.threadss;
import java.awt.BorderLayout;
import javax.swing.JPanel;
import javax.swing.JFrame;
import java.awt.Dimension;
public class First extends JFrame {
private static final long serialVersionUID = 1L;
private JPanel jContentPane = null;
* This is the default constructor
public First() {
super();
initialize();
* This method initializes this
* @return void
private void initialize() {
this.setSize(300, 200);
this.setContentPane(getJContentPane());
this.setTitle("Hello");
* This method initializes jContentPane
* @return javax.swing.JPanel
private JPanel getJContentPane() {
if (jContentPane == null) {
jContentPane = new JPanel();
jContentPane.setLayout(new BorderLayout());
return jContentPane;
Plz Help Me!!
Re: Unable to load class error [message #143182 is a reply to message #143171] Mon, 26 November 2007 18:16 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There may be more errors in the .log that were listed to explain why it
couldn't be loaded.
Rich Kulp
Re: Unable to load class error [message #143190 is a reply to message #143171] Tue, 27 November 2007 06:43 Go to previous message
Thank You very much for ur reply
Itz working now
Re: Unable to load class error [message #616892 is a reply to message #143171] Mon, 26 November 2007 18:16 Go to previous message
couldn't be loaded.
Rich Kulp
Re: Unable to load class error [message #616893 is a reply to message #143171] Tue, 27 November 2007 06:43 Go to previous message
Itz working now
Previous Topic:Unable to load class error
Next Topic:Existing VE source and new Workspace NO VE palette nor Designer pane displaying
Current Time: Fri Jul 18 07:30:20 EDT 2025
Powered by FUDForum. Page generated in 0.08271 seconds
