Home » Eclipse Projects » GEF » Problem about getAdapter() method
Problem about getAdapter() method [message #143155] Sun, 18 July 2004 23:09 Go to next message
Dear fellows working in GEF,
There are the following source in class LogicEditor.java in the example of
org.eclipse.gef.examples.logic_2.1.2:
public Object getAdapter(Class type){
if (type == CommandStackInspectorPage.class)
return new CommandStackInspectorPage(getCommandStack());
if (type == IContentOutlinePage.class)
return new OutlinePage(new TreeViewer());
if (type == ZoomManager.class)
return (
(ScalableFreeformRootEditPart) getGraphicalViewer()
.getRootEditPart())
.getZoomManager();
return super.getAdapter(type);
I am not sure what the method getAdapter() is supposed to do, what is
the purpose of the class CommandStackInspectorPage.class,
And in what kind of situation, the statement if (type ==
CommandStackInspectorPage.class) will return true?
I really appreciate your help.
Thank you
Re: Problem about getAdapter() method [message #143298 is a reply to message #143155] Mon, 19 July 2004 10:09 Go to previous messageGo to next message
> return (
> .getRootEditPart())
> .getZoomManager();
It will return true if both classes are the same. The getAdapter()
method is part of the IAdaptable Interface. It is needed to provide a
extension point with the need to directly implement an Interface.
For example this lines:
To provide an extension to the workbench one might have done something
like this:
if (unknownClass instanceOf IMyInterface){
//Go, use it..
But this is to inflexible. Think of what Interfaces a Editor need to
Implement to provide a IContentOutlinePage...
But if you have the getAdapter method you Just say:
IMyInterface myInt=unknownClass.getAdapter(IMyInterface.class);
if (myInt!=null){
//Go, use it
That is much more flexible and doesn't force the unknownClass to
directly implement an Interface, but to provide an Object that
implements that Interface.
In case of IContentOutlinePage it asks every Editor whether it is an
IAdaptable and when, whether he knows about the IContentOutlinePage.clas...
Karsten
Re: Problem about getAdapter() method [message #143450 is a reply to message #143298] Mon, 19 July 2004 21:24 Go to previous messageGo to next message
> > return (
> > .getRootEditPart())
> > .getZoomManager();
> like this:
> //Go, use it..
> if (myInt!=null){
> //Go, use it
> Karsten
Thanks a lot
Re: Problem about getAdapter() method [message #143460 is a reply to message #143298] Mon, 19 July 2004 21:59 Go to previous message
> > return (
> > .getRootEditPart())
> > .getZoomManager();
> like this:
> //Go, use it..
> if (myInt!=null){
> //Go, use it
> Karsten
Thank you very much for your answer.
I have one more question.
What is the class org.eclipse.gef.ui.stackview.CommandStackInspectorPage
supposed to do?
I do not find javaDoc for it in GEF.
Thanks for your time.
Previous Topic:Problems printing images
Next Topic:GEF and RCP application Help
Current Time: Fri Jul 18 14:33:44 EDT 2025
Powered by FUDForum. Page generated in 0.05512 seconds
