Home » Newcomers » Newcomers » Can't access "help contents" from a workbench - firewall problem?
Can't access "help contents" from a workbench - firewall problem? [message #143111] Tue, 14 March 2006 22:04 Go to next message
Originally posted by: whaebich.netspace.net.au
We have installed Eclipse (Version: 3.1.1, Build id: M20050929-0840) at a
client site.
When I select help contents from a workbench window, I get the error
message below.
Is this due to some process running in Eclipse that is blocked by the
company firewall? What can be done to get around it?
ERROR
The requested URL could not be retrieved
While trying to retrieve the URL: http://127.0.0.1:59111/help/index.jsp
The following error was encountered:
Connection Failed
The system returned:
(146) Connection refused
The remote host or network may be down. Please try the request again.
Re: Can't access "help contents" from a workbench - firewall problem? [message #143407 is a reply to message #143111] Thu, 16 March 2006 09:41 Go to previous message
Originally posted by: dalroth5.hotmail.com
Hello there.
You'll have noticed that the URL refers to the IP address 127.0.0.1, which
is the fakey address given to your machine's loopback interface. IOW, no
TCP was leaving your machine at that point; Eclipse launches a separate
Tomcat server for documentation and was merely trying to point its browser
at that server (listening on your machine on port 59111 in your failure
message).
Take a look here for more info:
http://www.eclipse.org/search/search.cgi?t=All&t=Doc& ;t=Downloads&t=Wiki&wf=574a74&q=help+server& x=9&y=10
Hope this helps.
Steve
Previous Topic:error: entry point not found
Next Topic:How to fold Java if/while etc.?
Current Time: Mon Jul 21 04:11:58 EDT 2025
Powered by FUDForum. Page generated in 0.06843 seconds
