Home » Eclipse Projects » GEF » How to remove focus decoration
How to remove focus decoration [message #143097] Sun, 18 July 2004 11:42 Go to next message
Originally posted by: hello.yahoo.com
Now I want to remove some focus decorations in my figure when it is
selected.For example:
In GEF when I selected an figure to resize or to move the figure will be
added some decorations which has eight squares. and when use move the
mouse on the figure the cursor will change to resize cursor or move
cursor.What I want is to remove all squares and only when I move mouse on
the right bound or left bounds the cursor will change to the resize cursor
and so does the move cursor.
Should I add some selectinEditPolicy extends from Resizable or
NonResizable EditPolicy?
Can you help me?
Daniel
thanks in advance.
Re: How to remove focus decoration [message #143118 is a reply to message #143097] Sun, 18 July 2004 13:12 Go to previous messageGo to next message
i don't know the best answer, but what you suggested is exactly what i do
to modify the selection decoration.
i created a editpolicy with a new implementation of
createSelectionHandles() then use it by setting it up in my Diagrams main
edit policy as such:
public class DiagramComponentRoleEditPolicy extends XYLayoutEditPolicy {
protected EditPolicy createChildEditPolicy(EditPart child) {
return new MyNewEditPolicyToControlHandles();
you'd probably still want to create "handles" from the existing MoveHandle
and ResizeHandle, but give them no graphically representation, i.e. empty
paintFigure() implemntation. then you can get all the existing code
behind the handles for managing the resizing, positioning, cursors, etc.
steve
daniel wrote:
> Hi
> Can you help me?
> Daniel
> thanks in advance.
Re: How to remove focus decoration [message #143149 is a reply to message #143118] Sun, 18 July 2004 22:50 Go to previous message
thanks it works
> steve
> daniel wrote:
> > Hi
> > Can you help me?
> > Daniel
> > thanks in advance.
Previous Topic:FlowLayout shrink on remove
Next Topic:Dragging and moving
Current Time: Sat Nov 15 09:49:23 EST 2025
Powered by FUDForum. Page generated in 0.03504 seconds
