Home » Modeling » M2T (model-to-text transformation) » Freshly Created JET2 Transformation Failure
Freshly Created JET2 Transformation Failure [message #13203] Sun, 22 April 2007 06:00 Go to next message
Originally posted by: daniel.carleton.pobox.com
Hello Everyone,
I'm just getting started with JET2, and having an issue running the
"sample.xml" in a freshly created project.
Here is my process:
1. File -> New -> Other... -> EMFT JET Transformation Project
2. Open "sample.xml" and add "<foo>bar</foo>" inside of "<root>."
3. Right Click "sample.xml" in Package Explorer -> Run As... -> Input for
JET Transformation
This results in the following console output.
templates/dump.jet(2,1): <c:dump entities="true" format="true" select="/*">
Error: Error executing tag handler: java.lang.NullPointerException
templates/main.jet(23,1): <ws:file template="templates/dump.jet" path="{$org.eclipse.jet.resource.project.name}/dump.xml">
Writing file: /jet2test/dump.xml
Errors occurred during execution
... and some details on the exception in workspace/.metadata/.log:
!SESSION 2007-04-22 01:45:40.839 -----------------------------------------------
eclipse.buildId=M20070212-1330
java.version=1.5.0_10
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.jet 4 2 2007-04-22 01:50:37.956
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jet".
!STACK 0
at org.eclipse.jet.internal.taglib.control.DumpTag.writeChildre n(DumpTag.java:207)
at org.eclipse.jet.internal.taglib.control.DumpTag.dump2(DumpTa g.java:151)
at org.eclipse.jet.internal.taglib.control.DumpTag.doAction(Dum pTag.java:110)
at org.eclipse.jet.internal.runtime.SafeEmptyRuntimeTag$1.doRun (SafeEmptyRuntimeTag.java:50)
at org.eclipse.jet.internal.runtime.SafeCustomRuntimeTag$TagSaf eRunnable.run(SafeCustomRuntimeTag.java:73)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.jet.internal.runtime.SafeEmptyRuntimeTag.doStart (SafeEmptyRuntimeTag.java:44)
at org.eclipse.jet.compiled._jet_dump.generate(_jet_dump.java:4 3)
at org.eclipse.jet.transform.TransformContextExtender.execute(T ransformContextExtender.java:147)
at org.eclipse.jet.transform.TransformContextExtender.execute(T ransformContextExtender.java:120)
at org.eclipse.jet.internal.taglib.workspace.FileTag.doAction(F ileTag.java:102)
at org.eclipse.jet.compiled._jet_main.generate(_jet_main.java:4 7)
at org.eclipse.jet.JET2Platform$4.run(JET2Platform.java:449)
at org.eclipse.jet.internal.runtime.JETBundleManager.run(JETBun dleManager.java:331)
at org.eclipse.jet.JET2Platform.runTransform(JET2Platform.java: 417)
at org.eclipse.jet.internal.launch.JETProcess.run(JETProcess.ja va:157)
at org.eclipse.jet.internal.launch.JET2TransformationDelegate.l aunch(JET2TransformationDelegate.java:60)
Does anyone have any thoughts before I start trying to trace into the JET2
code?
My Eclipse configuration information is attached.
I'm really looking forward to using JET2 for code generation. I've been
looking for something as general purpose with good merge functionality for
a while. My application is a passive generation system to reduce
redundant coding for a project I'm working on.
Thanks for any guidance.
- Daniel
Re: Freshly Created JET2 Transformation Failure [message #13239 is a reply to message #13203] Sun, 22 April 2007 06:14 Go to previous messageGo to next message
--------------060103050604080507000009
Whoops.., here we go.
Also, I noticed that Toby Myers was seemingly having the same problem in
the thread below. I've been running Eclipse 3.2.2 the entire time,
however, and the same version of EMF with a later version of JET.
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2t/m sg00101.html
Thanks again if you have time to take a look.
- Daniel
name="banquo_eclipse_config.txt"
Content-Disposition: inline;
filename="banquo_eclipse_config.txt"
*** Date: Sun Apr 22 01:55:25 GMT-08:00 2007
*** Platform Details:
*** System properties:
eclipse.buildId=3DM20070212-1330
eclipse.commands=3D-os
linux
-ws
gtk
-arch
x86
-launcher
/opt/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
70001d
-vm
/usr/bin/java
eclipse.ee.install.verify=3Dfalse
eclipse.product=3Dorg.eclipse.sdk.ide
eclipse.startTime=3D1177235140839
eclipse.vm=3D/usr/bin/java
eclipse.vmargs=3D-Xms40m
-Xmx256m
-jar
/opt/eclipse/startup.jar
eof=3Deof
file.encoding=3DUTF-8
file.encoding.pkg=3Dsun.io
file.separator=3D/
java.awt.graphicsenv=3Dsun.awt.X11GraphicsEnvironment
java.awt.printerjob=3Dsun.print.PSPrinterJob
java.class.path=3D/opt/eclipse/startup.jar
java.class.version=3D49.0
java.endorsed.dirs=3D/usr/lib/j2sdk1.5-sun/jre/lib/endorsed
java.ext.dirs=3D/usr/lib/j2sdk1.5-sun/jre/lib/ext
java.home=3D/usr/lib/j2sdk1.5-sun/jre
java.io.tmpdir=3D/tmp
java.library.path=3D/usr/lib/j2sdk1.5-sun/jre/lib/i386/clien t:/usr/lib/j2=
sdk1.5-sun/jre/lib/i386:/usr/lib/j2sdk1.5-sun/jre/../lib/i38 6:/usr/lib/fi=
refox/
java.runtime.name=3DJava(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=3D1.5.0_10-b03
java.specification.name=3DJava Platform API Specification
java.specification.vendor=3DSun Microsystems Inc.
java.specification.version=3D1.5
java.vendor=3DSun Microsystems Inc.
java.vendor.url=3Dhttp://java.sun.com/
java.vendor.url.bug=3Dhttp://java.sun.com/cgi-bin/bugreport.cgi
java.version=3D1.5.0_10
java.vm.info=3Dmixed mode, sharing
java.vm.name=3DJava HotSpot(TM) Client VM
java.vm.specification.name=3DJava Virtual Machine Specification
java.vm.specification.vendor=3DSun Microsystems Inc.
java.vm.specification.version=3D1.0
java.vm.vendor=3DSun Microsystems Inc.
java.vm.version=3D1.5.0_10-b03
line.separator=3D
org.apache.commons.logging.Log=3Dorg.apache.commons.logging. impl.SimpleLo=
g
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=3Doff
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=3D=
off
org.osgi.framework.bootdelegation=3D*
org.osgi.framework.executionenvironment=3DOSGi/Minimum-1.0,O SGi/Minimum-1=
=2E1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=3Den
org.osgi.framework.os.name=3DLinux
org.osgi.framework.os.version=3D2.6.17-10-386
org.osgi.framework.processor=3Di386
org.osgi.framework.system.packages=3Djavax.accessibility,jav ax.activity,j=
avax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax. imageio,javax=
=2Eimageio.event,javax.imageio.metadata,javax.imageio.plugin s.bmp,javax.i=
mageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,j avax.manageme=
nt,javax.management.loading,javax.management.modelmbean,java x.management.=
monitor,javax.management.openmbean,javax.management.relation ,javax.manage=
ment.remote,javax.management.remote.rmi,javax.management.tim er,javax.nami=
ng,javax.naming.directory,javax.naming.event,javax.naming.ld ap,javax.nami=
ng.spi,javax.net,javax.net.ssl,javax.print,javax.print.attri bute,javax.pr=
int.attribute.standard,javax.print.event,javax.rmi,javax.rmi .CORBA,javax.=
rmi.ssl,javax.security.auth,javax.security.auth.callback,jav ax.security.a=
uth.kerberos,javax.security.auth.login,javax.security.auth.s pi,javax.secu=
rity.auth.x500,javax.security.cert,javax.security.sasl,javax .sound.midi,j=
avax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled. spi,javax.sql=
,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.s pi,javax.swin=
g,javax.swing.border,javax.swing.colorchooser,javax.swing.ev ent,javax.swi=
ng.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax .swing.plaf.m=
etal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swi ng.table,java=
x.swing.text,javax.swing.text.html,javax.swing.text.html.par ser,javax.swi=
ng.text.rtf,javax.swing.tree,javax.swing.undo,javax.transact ion,javax.tra=
nsaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace ,javax.xml.pa=
rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax=
,javax.xml.transform.stream,javax.xml.validation,javax.xml.x path,org.ietf=
=2Ejgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.po rtable,org.om=
g.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA .portable,org=
=2Eomg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingCo=
ntextExtPackage,org.omg.CosNaming.NamingContextPackage,org.o mg.Dynamic,or=
g.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org .omg.DynamicA=
ny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage ,org.omg.IOP.=
CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,o rg.omg.Portab=
leInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org. omg.PortableS=
erver.CurrentPackage,org.omg.PortableServer.POAManagerPackag e,org.omg.Por=
tableServer.POAPackage,org.omg.PortableServer.portable,org.o mg.PortableSe=
rver.ServantLocatorPackage,org.omg.SendingContext,org.omg.st ub.java.rmi,o=
rg.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c. dom.ls,org.xm=
l.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=3DEclipse
org.osgi.framework.version=3D1.3.0
org.osgi.supports.framework.extension=3Dtrue
os.arch=3Di386
os.name=3DLinux
osgi.arch=3Dx86
osgi.bundles=3Dorg.eclipse.equinox.common@2:start, org.eclipse.update.con=
figurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=3D/opt/eclipse/configuration/org.eclipse.os gi/bundles
osgi.configuration.area=3Dfile:/opt/eclipse/configuration/
osgi.framework=3Dfile:/opt/eclipse/plugins/org.eclipse.osgi_ 3.2.2.R32x_v2=
0070118.jar
osgi.framework.beginningstartlevel=3D1
osgi.framework.shape=3Djar
osgi.framework.version=3D3.2.2.R32x_v20070118
osgi.install.area=3Dfile:/opt/eclipse/
osgi.instance.area=3Dfile:/home/dacc/workspace/
osgi.instance.area.default=3Dfile:/home/dacc/workspace/
osgi.logfile=3D/home/dacc/workspace/.metadata/.log
osgi.manifest.cache=3D/opt/eclipse/configuration/org.eclipse .osgi/manifes=
ts
osgi.nl=3Den_US
osgi.os=3Dlinux
osgi.splashLocation=3D/opt/eclipse/plugins/org.eclipse.platf orm_3.2.2.r32=
2_v20070117b/splash.bmp
osgi.splashPath=3Dplatform:/base/plugins/org.eclipse.platfor m
osgi.syspath=3D/opt/eclipse/plugins
osgi.ws=3Dgtk
path.separator=3D:
sun.arch.data.model=3D32
sun.boot.class.path=3D/usr/lib/j2sdk1.5-sun/jre/lib/rt.jar:/ usr/lib/j2sdk=
1.5-sun/jre/lib/i18n.jar:/usr/lib/j2sdk1.5-sun/jre/lib/sunrs asign.jar:/us=
r/lib/j2sdk1.5-sun/jre/lib/jsse.jar:/usr/lib/j2sdk1.5-sun/jr e/lib/jce.jar=
:/usr/lib/j2sdk1.5-sun/jre/lib/charsets.jar:/usr/lib/j2sdk1. 5-sun/jre/cla=
sses
sun.boot.library.path=3D/usr/lib/j2sdk1.5-sun/jre/lib/i386
sun.cpu.endian=3Dlittle
sun.cpu.isalist=3D
sun.io.unicode.encoding=3DUnicodeLittle
sun.jnu.encoding=3DUTF-8
sun.management.compiler=3DHotSpot Client Compiler
sun.os.patch.level=3Dunknown
user.country=3DUS
user.dir=3D/home/dacc/workspace/metacycle
user.home=3D/home/dacc
user.language=3Den
user.name=3Ddacc
user.timezone=3DGMT-08:00
*** Features:
org.eclipse.emf (2.2.2.v200702131851) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen.jet.editor (0.8.0.v200703030036) "JET Editor"
org.eclipse.emf.ecore.sdo (2.2.1.v200702131851) "EMF Service Data Objects=
(SDO)"
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework"
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java Deve=
lopment Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Ja=
va Development Tools SDK"
org.eclipse.jem (1.2.1.v20060815_M----6zXJJzKIRGVU) "Java EMF Model"
org.eclipse.jet (0.8.0.v200704041505) "Eclipse Modeling Framework Technol=
ogies - JET"
org.eclipse.mylar_feature (2.0.0.v20070403-1300) "Mylar Plug-in"
org.eclipse.mylar.ide_feature (2.0.0.v20070403-1300) "Mylar Plug-in"
org.eclipse.mylar.trac_feature (2.0.0.v20070403-1300) "Mylar Plug-in"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in D=
evelopment Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Pl=
ug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Plat=
form"
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclip=
se Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP"
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RC=
P Plug-in Developer Resources"
org.eclipse.sdk (3.2.2.r322_v20070104-dCGKm0Ln38lm-8s) "Eclipse Project S=
DK"
org.eclipse.wst (1.5.3.v200701251935-X3Tn7ug44nfs8AE) "Web Standard Tools=
(WST)"
org.eclipse.xsd (2.2.2.v200702131851) "XML Schema Infoset Model (XSD)"
org.rubypeople.rdt (0.8.1.609062100PRD) "Ruby Development Tools"
org.rubypeople.rdt.source (0.8.1.609062100PRD) "pluginName"
org.springframework.ide.eclipse (1.3.6) "Spring IDE"
org.tigris.subversion.subclipse (1.2.0) "SVN Team Provider Core"
org.tigris.subversion.subclipse.mylar (1.0.1) "Subclipse Integration for =
Mylar"
*** Plug-in Registry:
com.beust.doclipse (0.7.0) "Doclipse Plug-in" [Resolved]
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5.20061213) "International Components for Unicode for Ja=
va (ICU4J)" [Active]
com.ibm.icu.source (3.4.5.20061213) "International Components for Unicode=
for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.3.0.v200608161946) "Apache Axis 1.3.0" [Resolved]
org.apache.commons_logging (1.0.4.v200608011657) "Apache commons logging =
Plug-in" [Resolved]
org.apache.jakarta_log4j (1.2.8.v200607172048) "Apache Jakarta log4j Plug=
-in" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200608161946) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]=
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Active]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism=
" [Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression Language=
" [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Activ=
e]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolv=
ed]
org.eclipse.core.filesystem.linux.x86 (1.0.0.v20060603) "Core File System=
for Linux" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]=
org.eclipse.core.resources (3.2.2.R32x_v20061218) "Core Resource Manageme=
nt" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource=
Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime =
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorizat=
ion Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907) "E=
clipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved=
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.2.r322_v20070202) "Debug UI" [Active]
org.eclipse.draw2d (3.2.2.v20070208) "Draw2d" [Resolved]
org.eclipse.emf (2.2.0.v200702131851) "Eclipse Modeling Framework (EMF)" =
[Resolved]
org.eclipse.emf.ant (2.2.0.v200702131851) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.2.v200702131851) "EMF Template Code Generato=
r" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.2.v200702131851) "EMF Ecore Code Gener=
ation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200702131851) "EMF Ecore Code Ge=
neration UI" [Resolved]
org.eclipse.emf.codegen.jet.editor (0.8.0.v200703030036) "JET Editor" [Re=
solved]
org.eclipse.emf.codegen.ui (2.1.0.v200702131851) "EMF Template Code Gener=
ator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200702131851) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200702131851) "EMF Common UI" [Resolved=
org.eclipse.emf.commonj.sdo (2.1.0.v200702131851) "CommonJ SDO" [Resolved=
org.eclipse.emf.converter (2.2.1.v200702131851) "EMF Model Convert Suppor=
t" [Resolved]
org.eclipse.emf.ecore (2.2.2.v200702131851) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.1.v200702131851) "EMF Ecore Change Mode=
l" [Resolved]
org.eclipse.emf.ecore.change.edit (2.2.0.v200702131851) "EMF Ecore Change=
Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200702131851) "EMF Ecore Edit Support"=
[Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200702131851) "Sample Ecore Editor" =
[Resolved]
(SDO)" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200702131851) "EMF Service Data Ob=
jects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200702131851) "EMF Service Data =
Objects (SDO) Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.2.v200702131851) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.2.v200702131851) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.1.v200702131851) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0.v200702131851) "EMF Model Export Support"=
[Resolved]
org.eclipse.emf.importer (2.2.2.v200702131851) "EMF Model Import Support"=
[Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200702131851) "EMF Ecore Importer"=
[Resolved]
org.eclipse.emf.importer.java (2.2.1.v200702131851) "EMF Annotated Java I=
mporter" [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200702131851) "EMF Rose Importer" [=
Resolved]
org.eclipse.emf.mapping (2.2.0.v200702131851) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200702131851) "Ecore to Ecore=
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200702131851) "Ecore t=
o Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200702131851) "Ecore to XML Map=
ping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200702131851) "Ecore to XML =
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200702131851) "EMF Mapping UI" [Resolv=
ed]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200702131851) "XSD to Ecore Map=
ping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200702131851) "XSD to Ec=
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime" [Ac=
tive]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse Preferenc=
es Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry S=
upport" [Active]
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework" [Resolved=
org.eclipse.help (3.2.2.R322_v20061213) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server" =
[Resolved]
org.eclipse.help.base (3.2.2.R322_v20061207) "Help System Base" [Resolved=
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.2.R322_v20061114) "Help System Webapp" [Reso=
lved]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools" [=
Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation Pro=
cessing Core" [Active]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation Proce=
ssing UI" [Resolved]
org.eclipse.jdt.core (3.2.3.v_686_R32x) "Java Development Tools Core" [Ac=
tive]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code Manip=
ulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.2.r322_v20070130) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.2.r322_v20061205) "JDI Debug UI" [Resolved]=
org.eclipse.jdt.doc.isv (3.2.1.r322_v20070109) "Eclipse JDT Plug-in Devel=
oper Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java Development=
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools JUni=
t support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development To=
ols JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development T=
ools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.2.r322_v20061114) "Java Development Tools =
Launching Support" [Active]
va Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.2.r322_v20070124) "Java Development Tools UI" [Ac=
tive]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.2.0.v20060918_M) "Java EMF Model BeanInfo (In=
trospection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support" =
[Resolved]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities" [Acti=
ve]
org.eclipse.jem.workbench (1.2.1.v20060918_M) "Java EMF Model Workbench S=
upport" [Resolved]
ogies - JET" [Active]
org.eclipse.jet.core (1.0.0.v200704041505) "Eclipse Modeling Framework Te=
chnologies - JET Core" [Active]
org.eclipse.jet.ui (0.8.0.v200704041505) "JET Transformations UI Plug-in"=
[Active]
org.eclipse.jface (3.2.2.M20061214-1200) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding"=
[Resolved]
org.eclipse.jface.text (3.2.2.r322_v20070104) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring Core=
" [Active]
org.eclipse.ltk.ui.refactoring (3.2.2.r322_v20070124) "Refactoring UI" [R=
esolved]
org.eclipse.mylar (2.0.0.v20070403-1300) "Mylar Plug-in" [Active]
org.eclipse.mylar.context.core (2.0.0.v20070403-1300) "Mylar Context Core=
Plug-in" [Active]
org.eclipse.mylar.context.ui (2.0.0.v20070403-1300) "Mylar UI Plug-in" [A=
ctive]
org.eclipse.mylar.doc (2.0.0.v20070403-1300) "Mylar Documentation Plug-in=
" [Resolved]
org.eclipse.mylar.ide (2.0.0.v20070403-1300) "Mylar Ide Plug-in" [Active]=
org.eclipse.mylar.java (2.0.0.v20070403-1300) "Mylar Java Plug-in" [Activ=
e]
org.eclipse.mylar.monitor.core (2.0.0.v20070403-1300) "Mylar Monitor Core=
Plug-in" [Resolved]
org.eclipse.mylar.monitor.ui (2.0.0.v20070403-1300) "Mylar Monitor UI Plu=
g-in" [Active]
org.eclipse.mylar.resources (2.0.0.v20070403-1300) "Mylar Resources Plugi=
n" [Active]
org.eclipse.mylar.tasks.core (2.0.0.v20070403-1300) "Mylar Tasks Core Plu=
g-in" [Active]
org.eclipse.mylar.tasks.ui (2.0.0.v20070403-1300) "Mylar Tasks UI Plug-in=
" [Active]
org.eclipse.mylar.tasks.web (2.0.0.v20070403-1300) "Mylar Web Tasks Plug-=
in" [Active]
org.eclipse.mylar.team (2.0.0.v20070403-1300) "Mylar Team Plug-in" [Activ=
e]
org.eclipse.mylar.trac.core (2.0.0.v20070403-1300) "Mylar Trac Core Plug-=
in" [Active]
org.eclipse.mylar.trac.ui (2.0.0.v20070403-1300) "Mylar Trac UI Plug-in" =
[Active]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services" [=
Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes" [Reso=
lved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development Envir=
onment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development Environ=
ment Build Support" [Active]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core" [A=
ctive]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in Developm=
ent User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test" =
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environmen=
t Runtime" [Resolved]
ug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI" [Activ=
e]
org.eclipse.platform (3.2.2.r322_v20070117b) "Eclipse Platform" [Resolved=
org.eclipse.platform.doc.isv (3.2.2.R32x_v20070115) "Eclipse Platform Plu=
g-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse Workben=
ch User Guide" [Resolved]
se Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.linux.gtk.x86 (3.2.2.r322_v20070119-RQghndJN8=
IM0MsK) "Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
P Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.linux.gtk.x86 (3.2.2.r322_v20070104-8pcviKVqd8J7C1=
U) "Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.2.2.r322_v20070212) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Active]
org.eclipse.swt (3.2.2.v3236b) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86 (3.2.2.v3236) "Standard Widget Toolkit for =
GTK 2.0" [Resolved]
org.eclipse.team.core (3.2.2.M20061114) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.2.M20061205) "CVS Team Provider Core" [Act=
ive]
org.eclipse.team.cvs.ssh (3.2.1.M20061205) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.1.M20061205) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.2.M20061121) "CVS Team Provider UI" [Active]=
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Active]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.1.M20061108) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolve=
d]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Acti=
ve]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools" [A=
ctive]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.2.R322_v20061214) "Welcome Framework" [Resolved=
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal Welcome"=
[Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View" [=
Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator Wor=
kbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation=
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed Pro=
perties View" [Resolved]
org.eclipse.ui.workbench (3.2.2.M20070119-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench =
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor F=
ramework" [Active]
org.eclipse.update.configurator (3.2.2.R32x_v20070111) "Install/Update Co=
nfigurator" [Active]
org.eclipse.update.core (3.2.3.R32x_v20070118) "Install/Update Core" [Act=
ive]
org.eclipse.update.core.linux (3.2.0.v20060605) "Install/Update Core for =
Linux" [Resolved]
org.eclipse.update.scheduler (3.2.2.R32x_v20061214) "Automatic Updates Sc=
heduler" [Active]
org.eclipse.update.ui (3.2.2.R32x_v20070111) "Install/Update UI" [Resolve=
d]
org.eclipse.wst (1.0.1.v200605040144) "Web Standard Tools (WST)" [Resolve=
d]
org.eclipse.wst.command.env (1.0.103.v200702021949) "Environment Command =
Framework (headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.102.v200702021949) "Environment Com=
mand Framework (core)" [Resolved]
org.eclipse.wst.command.env.doc.user (1.5.0.v20060831345) "Web services A=
xis Ant task documentation" [Resolved]
org.eclipse.wst.command.env.infopop (1.0.2.v200605070230) "Web services U=
I" [Resolved]
org.eclipse.wst.command.env.ui (1.0.102.v200608222020) "Environment Comma=
nd Framework (GUI)" [Resolved]
org.eclipse.wst.common.core (1.1.100.v200608220540) "WST Common Core Plug=
-in" [Resolved]
org.eclipse.wst.common.emf (1.1.3.v200612061436) "EMF Utilities" [Resolve=
d]
org.eclipse.wst.common.emfworkbench.integration (1.1.4.v200702021430) "EM=
F Workbench Edit Plug-in" [Resolved]
org.eclipse.wst.common.environment (1.0.100.v200608251934) "Enviornment P=
lug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.1.3.v200702071605) "Common Framework=
s" [Active]
org.eclipse.wst.common.frameworks.ui (1.1.2.v200702071605) "WTP UI Plug-i=
n" [Resolved]
org.eclipse.wst.common.infopop (1.0.1.v200605270041) "Common WST infopops=
" [Resolved]
org.eclipse.wst.common.modulecore (1.1.52.v200701251700) "Modulecore Plug=
-in" [Resolved]
org.eclipse.wst.common.project.facet.core (1.1.1.v200608112156) "Project =
Facet Core" [Active]
org.eclipse.wst.common.project.facet.ui (1.1.2.v200701192142) "Project Fa=
cet UI" [Resolved]
org.eclipse.wst.common.snippets (1.1.1.v200609140550) "Snippets View" [Re=
solved]
org.eclipse.wst.common.ui (1.1.101.v200702021750) "Eclipse Base UI extens=
ions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.101.v200609140551) "Common Prop=
erties UI" [Resolved]
org.eclipse.wst.common.uriresolver (1.1.101.v200702021717) "Common URI Re=
solver Framework" [Active]
org.eclipse.wst.css.core (1.1.1.v200609140550) "Structured Source CSS Mod=
el" [Active]
org.eclipse.wst.css.ui (1.0.101.v200609140550) "SSE CSS Source Editor" [R=
esolved]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.203.v200608310305) =
"Data documentation" [Resolved]
org.eclipse.wst.datatools.data.ui.doc.user (1.0.203.v200608310305) "Data =
tools data user interface documentation" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.203.v200608310305) "Data do=
org.eclipse.wst.datatools.server.ui.doc.user (1.0.203.v200608310305) "Dat=
abase Explorer documentation" [Resolved]
org.eclipse.wst.doc.user (1.0.203.v200608231821) "Master User Doc TOC" [R=
esolved]
org.eclipse.wst.dtd.core (1.1.1.v200609210600) "Structured Source DTD Cor=
e" [Resolved]
org.eclipse.wst.dtd.ui (1.0.102.v200702021750) "SSE DTD Source Editor" [R=
esolved]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200605040131) "DTD Editor infopops=
" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.203.v200609221649) "DTD Editor do=
org.eclipse.wst.html.core (1.1.2.v200612200820) "Structured Source HTML M=
odel" [Active]
org.eclipse.wst.html.standard.dtds (1.0.1.v200608220315) "Known DTDs" [Re=
solved]
org.eclipse.wst.html.ui (1.0.102.v200702021750) "HTML UI Source Editor" [=
Resolved]
org.eclipse.wst.html.ui.infopop (1.0.1.v200605040131) "HTML editor infopo=
ps" [Resolved]
org.eclipse.wst.internet.cache (1.0.103.v200612070353) "Cache URI Resolve=
r Plug-in" [Active]
org.eclipse.wst.internet.monitor.core (1.0.103.v20060809) "Monitor" [Reso=
lved]
org.eclipse.wst.internet.monitor.ui (1.0.103.v20060809) "TCP/IP Monitor" =
[Resolved]
org.eclipse.wst.internet.proxy (1.0.101.v200702021949) "Internet Proxy Pr=
eferences" [Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200605070230) "Internet Pr=
oxy Infopops" [Resolved]
org.eclipse.wst.javascript.core (1.0.1.v200609140550) "Structured Source =
JavaScript Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.2.v200701250230) "SSE JavaScript Sourc=
e Editor" [Resolved]
org.eclipse.wst.javascript.ui.infopop (1.0.1.v200605040131) "Javascript i=
nfopop" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.106.v200701032244) "RDB Connection=
=2Eui" [Resolved]
org.eclipse.wst.rdb.connection.ui.infopop (1.0.0.v200605040131) "New Conn=
ection wizard infopops" [Resolved]
org.eclipse.wst.rdb.core (1.1.119.v200702062139) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.108.v200701032153) "Core UI plugin" [Res=
olved]
org.eclipse.wst.rdb.data.core (1.0.107.v200612130213) "Data Core Plugin" =
[Resolved]
org.eclipse.wst.rdb.data.ui (1.0.110.v200612130213) "Data UI Plugin" [Res=
olved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.105.v200610161941) "DB2=
UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.107.v200702021852) "DB2 UDB=
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.104.v200610161905) "DB2=
UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.derby (1.0.104.v200610161905) "Derby Dat=
abase Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.generic.jdbc (1.0.101.v200605040131) "DB=
Definition Generic JDBC Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.104.v200610261819) "Inform=
ix Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.101.v200610161905) "DBDefinit=
ion Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.103.v200702062139) "Oracle D=
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.105.v200610161905) "SQL S=
erver Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.106.v200610261819) "Sybase D=
org.eclipse.wst.rdb.derby (1.0.106.v200612130213) "RDB Derby Plug-in" [Re=
solved]
org.eclipse.wst.rdb.derby.ui (1.0.103.v200612130213) "RDB Derby Ui Plug-i=
n" [Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.104.v200612130213) "FE UI Plug-in" [Resolv=
ed]
org.eclipse.wst.rdb.fe.ui.actions (1.0.103.v200612130213) "FE Ui Actions =
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0.v200605040131) "Generate DDL wiz=
org.eclipse.wst.rdb.models.dbdefinition (1.0.103.v200702062139) "DBDefini=
tion Model" [Resolved]
org.eclipse.wst.rdb.models.sql (1.0.104.v200612130213) "SQLModel Plug-in"=
[Resolved]
org.eclipse.wst.rdb.models.sql.edit (1.0.103.v200612130213) "SQLModel Edi=
org.eclipse.wst.rdb.mysql (1.0.104.v200612130213) "RDB Mysql Plug-in" [Re=
solved]
org.eclipse.wst.rdb.outputview (1.0.107.v200612130213) "Data Output Plug-=
in" [Resolved]
org.eclipse.wst.rdb.outputview.infopop (1.0.0.v200605040131) "Data Output=
view infopops" [Resolved]
org.eclipse.wst.rdb.server.extensions (1.0.105.v200612130213) "Server Exp=
lorer Extensions Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.110.v200701242205) "Server Explorer pl=
ugin" [Resolved]
org.eclipse.wst.rdb.server.ui.infopop (1.0.0.v200605040131) "Server Explo=
rer view infopops" [Resolved]
org.eclipse.wst.rdb.sqleditor (1.0.106.v200612130213) "SQL Source Editor =
Plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0.v200605040131) "SQL infopops=
" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.103.v200612130213) "Sqlscrapbook Pl=
ug-in" [Resolved]
org.eclipse.wst.server.core (1.0.105.v20070202b) "Server Core" [Resolved]=
org.eclipse.wst.server.ui (1.0.105.v20070124b) "Server UI" [Resolved]
org.eclipse.wst.server.ui.doc.user (1.0.203.v200609221649) "Server Tools =
documentation for Web Standard Tools" [Resolved]
org.eclipse.wst.server.ui.infopop (1.0.3.v200609140551) "Server Tools inf=
opops for Web Standard Tools" [Resolved]
org.eclipse.wst.sqleditor.doc.user (1.0.2.v200608310308) "SQL Editor Docu=
org.eclipse.wst.sse.core (1.1.101.v200611210021) "Structured Text Model" =
[Active]
org.eclipse.wst.sse.doc.user (1.0.203.v200608300230) "Structured text edi=
tor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.202.v200701252330) "Structured Source Editor"=
[Active]
org.eclipse.wst.sse.ui.infopop (1.0.101.v200605040131) "SSE infopops" [Re=
solved]
org.eclipse.wst.validation (1.1.3.v200702021430) "Validation Framework" [=
Active]
org.eclipse.wst.validation.infopop (1.0.201.v200606130645) "WST validatio=
n infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.2.v200612061436) "Validation Framework=
UI" [Resolved]
org.eclipse.wst.web (1.1.2.v200610182223) "Simple Web Plug-in" [Resolved]=
org.eclipse.wst.web.ui (1.1.1.v200609132124) "Simple Web UI Plug-in" [Res=
olved]
org.eclipse.wst.web.ui.infopop (1.0.201.v200605070230) "Static Web infopo=
p" [Resolved]
org.eclipse.wst.webtools.doc.user (1.0.203.v200609221649) "Web tools docu=
org.eclipse.wst.ws (1.0.102.v200702021949) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (1.0.104.v200701250524) "Web Services Explore=
r" [Resolved]
org.eclipse.wst.ws.infopop (1.0.202.v20070131) "Web Services UI" [Resolve=
d]
org.eclipse.wst.ws.parser (1.0.101.v200609062128) "Web Services Descripti=
on Parser" [Resolved]
org.eclipse.wst.ws.ui (1.0.102.v200702021555) "Web Services UI" [Resolved=
org.eclipse.wst.wsdl (1.0.103.v200702021033) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (1.1.101.v200702082034) "WSDL UI" [Resolved]
org.eclipse.wst.wsdl.ui.doc.user (1.0.203.v200609221649) "WSDL Editor Doc=
org.eclipse.wst.wsdl.validation (1.1.101.v200701260245) "WSDL Validator" =
[Resolved]
org.eclipse.wst.wsi (1.0.104.v200702021430) "WSI Conformance Tools" [Reso=
lved]
org.eclipse.wst.wsi.ui (1.0.101.v20060850312) "Soap Monitor" [Resolved]
org.eclipse.wst.wsi.ui.doc.user (1.0.202.v200609221649) "WS-I Validation =
Documentation" [Resolved]
org.eclipse.wst.xml.core (1.1.100.v200702021717) "Structured Source XML M=
odel" [Active]
org.eclipse.wst.xml.ui (1.0.201.v200702021717) "XML UI Plugin" [Active]
org.eclipse.wst.xml.ui.infopop (1.0.1.v200605040131) "XML infopops" [Reso=
lved]
org.eclipse.wst.xmleditor.doc.user (1.0.203.v200609221649) "XML editor" [=
Resolved]
org.eclipse.wst.xsd.core (1.1.101.v200701312359) "XSD Core Plugin" [Resol=
ved]
org.eclipse.wst.xsd.ui (1.1.102.v200701312359) "XML Schema Editor" [Resol=
ved]
org.eclipse.wst.xsdeditor.doc.user (1.0.203.v200609221649) "XML schema ed=
itor" [Resolved]
org.eclipse.xsd (2.2.2.v200702131851) "XML Schema Infoset Model (XSD)" [A=
ctive]
org.eclipse.xsd.ecore.exporter (2.2.1.v200702131851) "XML Schema Exporter=
for EMF" [Resolved]
org.eclipse.xsd.ecore.importer (2.2.0.v200702131851) "XML Schema Importer=
for EMF" [Resolved]
org.eclipse.xsd.edit (2.2.1.v200702131851) "XML Schema Edit Framework" [R=
esolved]
org.eclipse.xsd.editor (2.2.0.v200702131851) "XML Schema Editor" [Resolve=
d]
org.epic.regexp (0.1.4) "Regexp Plug-in" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Resolved]
org.kxml2 (2.1.4) "Kxml2" [Resolved]
org.rubypeople.rdt (0.8.1.609062100PRD) "Ruby Development Tools" [Resolve=
d]
org.rubypeople.rdt.core (0.8.1.609062100PRD) "Ruby Development Tools Core=
" [Resolved]
org.rubypeople.rdt.debug.core (0.8.1.609062100PRD) "Ruby Development Debu=
g Core" [Resolved]
org.rubypeople.rdt.debug.ui (0.8.1.609062100PRD) "Ruby Development Tools =
org.rubypeople.rdt.doc.user (0.8.1.609062100PRD) "Ruby Development Docume=
ntation" [Resolved]
org.rubypeople.rdt.launching (0.8.1.609062100PRD) "Ruby Development Tools=
Launching Support" [Resolved]
org.rubypeople.rdt.source (0.8.1.609062100PRD) "pluginName" [Resolved]
org.rubypeople.rdt.testunit (0.8.1.609062100PRD) "Ruby Development Tools =
Test::Unit support" [Resolved]
org.rubypeople.rdt.ui (0.8.1.609062100PRD) "Ruby Development Tools UI" [R=
esolved]
org.springframework.ide.eclipse (1.3.6) "Spring IDE" [Resolved]
org.springframework.ide.eclipse.beans.core (1.3.5) "Spring IDE Beans Core=
" [Active]
org.springframework.ide.eclipse.beans.ui (1.3.6) "Spring IDE Beans UI" [A=
ctive]
org.springframework.ide.eclipse.beans.ui.editor (1.3.6) "Spring IDE Beans=
Config Editor" [Active]
org.springframework.ide.eclipse.beans.ui.graph (1.3.1) "Spring IDE Beans =
Graph" [Resolved]
org.springframework.ide.eclipse.beans.ui.navigator (0.9.0) "Spring IDE Be=
ans Navigator" [Resolved]
org.springframework.ide.eclipse.beans.ui.search (1.0.2) "Spring IDE Beans=
UI Search" [Resolved]
org.springframework.ide.eclipse.core (1.3.6) "Spring IDE Core" [Active]
org.springframework.ide.eclipse.core.doc (1.2.8) "Spring Framework Refere=
nce Documentation" [Resolved]
org.springframework.ide.eclipse.ui (1.3.3) "Spring IDE UI" [Active]
org.tigris.subversion.subclipse.core (1.2.0) "SVN Team Provider Core" [Ac=
tive]
org.tigris.subversion.subclipse.doc (1.2.0) "Subclipse Documentation" [Re=
solved]
Mylar" [Active]
org.tigris.subversion.subclipse.ui (1.2.0) "SVN Team Provider UI" [Active=
org.uddi4j (2.0.5.v200608231542) "UDDI4J 2.0.5" [Resolved]
org.wsdl4j (1.4.0.v200702061629) "WSDL4J 1.4" [Resolved]
system.bundle (3.2.2.R32x_v20070118) "OSGi System Bundle" [Active]
ViPluginEclipseLayer (1.14.0) "Vi Plug-in" [Active]
viPluginHelp (1.14.0) "ViPluginHelp Plug-in" [Resolved]
*** User Preferences:
#Sun Apr 22 01:55:25 GMT-08:00 2007
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.ind=
ent_parameter_description=3Dtrue
@org.eclipse.ui.editors=3D3.2.1.r321_v20060721
@org.eclipse.debug.ui=3D3.2.2.r322_v20070202
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_spac=
e_after_at_in_annotation_type_declaration=3Ddo not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_posit=
ion_for_enum_constant=3Dend_of_line
/instance/org.eclipse.ui.workbench/org.eclipse.debug.ui.Debu gPerspective_=
persp=3D<?xml version\=3D"1.0" encoding\=3D"UTF-8"?>\n<perspective editor=
AreaVisible\=3D"1" fixed\=3D"0" version\=3D"0.016">\n<descriptor class\=3D=
"org.eclipse.debug.internal.ui.DebugPerspectiveFactory" id\=3D"org.eclips=
e.debug.ui.DebugPerspective" label\=3D"Debug"/>\n<window height\=3D"764" =
width\=3D"1680" x\=3D"0" y\=3D"286"/>\n<alwaysOnActionSet id\=3D"org.ecli=
pse.ui.actionSet.keyBindings"/>\n<alwaysOnActionSet id\=3D"org.eclipse.ui=
=2EWorkingSetActionSet"/>\n<alwaysOnActionSet id\=3D"org.eclipse.update.u=
i.softwareUpdates"/>\n<alwaysOnActionSet id\=3D"org.eclipse.ui.externalto=
ols.ExternalToolsSet"/>\n<alwaysOnActionSet id\=3D"org.eclipse.ui.edit.te=
xt.actionSet.openExternalFile"/>\n<alwaysOnActionSet id\=3D"org.eclipse.u=
i.edit.text.actionSet.annotationNavigation"/>\n<alwaysOnActionSet id\=3D"=
org.eclipse.ui.edit.text.actionSet.navigation"/>\n<alwaysOnActionSet id\=3D=
"org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo"/ >\n<alwaysOn=
ActionSet id\=3D"org.eclipse.search.searchActionSet"/>\n<alwaysOnActionSe=
t id\=3D"org.eclipse.ui.cheatsheets.actionSet"/>\n<alwaysOnActionSet id\=3D=
"org.eclipse.wst.server.ui.internal.webbrowser.actionSet"/>\n <alwaysOnAct=
ionSet id\=3D"org.springframework.ide.eclipse.beans.ui.actionSet"/ >\n<alw=
aysOnActionSet id\=3D"org.springframework.ide.eclipse.beans.search.action=
Set"/>\n<alwaysOnActionSet id\=3D"viPlugin.actionSet"/>\n<alwaysOnActionS=
et id\=3D"org.eclipse.mylar.ui.mylar.actionSet"/>\n<alwaysOnActionSet id\=
=3D"org.eclipse.mylar.tasks.navigation"/>\n<alwaysOnActionSet id\=3D"org.=
eclipse.mylar.doc.actionSet"/>\n<alwaysOnActionSet id\=3D"org.rubypeople.=
rdt.debug.ui.RDTDebugActionSet"/>\n<alwaysOnActionSet id\=3D"org.eclipse.=
debug.ui.launchActionSet"/>\n<alwaysOnActionSet id\=3D"org.eclipse.ui.Nav=
igateActionSet"/>\n<alwaysOnActionSet id\=3D"org.eclipse.debug.ui.breakpo=
intActionSet"/>\n<alwaysOnActionSet id\=3D"org.eclipse.jdt.debug.ui.JDTDe=
bugActionSet"/>\n<alwaysOnActionSet id\=3D"org.eclipse.jdt.ui.JavaActionS=
et"/>\n<alwaysOnActionSet id\=3D"org.eclipse.debug.ui.debugActionSet"/>\n=
<show_view_action id\=3D"org.eclipse.debug.ui.DebugView"/>\n<show_view_ac=
tion id\=3D"org.eclipse.debug.ui.VariableView"/>\n<show_view_action id\=3D=
"org.eclipse.debug.ui.BreakpointView"/>\n<show_view_action id\=3D"org.ecl=
ipse.debug.ui.ExpressionView"/>\n<show_view_action id\=3D"org.eclipse.ui.=
views.ContentOutline"/>\n<show_view_action id\=3D"org.eclipse.ui.console.=
ConsoleView"/>\n<show_view_action id\=3D"org.eclipse.ui.views.TaskList"/>=
\n<show_view_action id\=3D"org.eclipse.ant.ui.views.AntView"/>\n<show_vie=
w_action id\=3D"org.eclipse.jdt.debug.ui.DisplayView"/>\n<show_view_actio=
n id\=3D"org.eclipse.pde.runtime.LogView"/>\n<perspective_action id\=3D"o=
rg.eclipse.jdt.ui.JavaPerspective"/>\n<perspective_action id\=3D"org.ecli=
pse.jdt.ui.JavaBrowsingPerspective"/>\n<perspective_action id\=3D"org.rub=
ypeople.rdt.ui.PerspectiveRuby"/>\n<perspective_action id\=3D"org.rubypeo=
ple.rdt.ui.RubyBrowsingPerspective"/>\n<view id\=3D"org.eclipse.ui.consol=
e.ConsoleView"/>\n<view id\=3D"org.eclipse.ui.views.TaskList"/>\n<view id=
\=3D"org.eclipse.debug.ui.DebugView"/>\n<view id\=3D"org.eclipse.wst.serv=
er.ui.ServersView"/>\n<view id\=3D"org.eclipse.debug.ui.VariableView"/>\n=
<view id\=3D"org.eclipse.debug.ui.BreakpointView"/>\n<layout>\n <mainWindo=
w>\n<info folder\=3D"true" part\=3D"org.eclipse.debug.internal.ui.Navigat=
orFolderView">\n<folder activePageID\=3D"org.eclipse.debug.ui.DebugView" =
appearance\=3D"2" expanded\=3D"2">\n<page content\=3D"org.eclipse.debug.u=
i.DebugView" label\=3D"Debug"/>\n<page content\=3D"org.eclipse.ui.views.R=
esourceNavigator" label\=3D"LabelNotFound"/>\n<page content\=3D"org.eclip=
se.jdt.ui.PackageExplorer" label\=3D"LabelNotFound"/>\n<page content\=3D"=
org.eclipse.jdt.ui.TypeHierarchy" label\=3D"LabelNotFound"/>\n<page conte=
nt\=3D"org.eclipse.wst.server.ui.ServersView" label\=3D"Servers"/>\n<pres=
entation id\=3D"org.eclipse.ui.presentations.WorkbenchPresentationFactory=
">\n<part id\=3D"0"/>\n<part id\=3D"1"/>\n</presentation>\n</folder>\n</i=
nfo>\n<info folder\=3D"true" part\=3D"stickyFolderRight" ratio\=3D"0.75" =
ratioLeft\=3D"1245" ratioRight\=3D"415" relationship\=3D"2" relative\=3D"=
org.eclipse.debug.internal.ui.NavigatorFolderView">\n<folder appearance\=3D=
"2" expanded\=3D"2">\n<page content\=3D"org.eclipse.help.ui.HelpView" lab=
el\=3D"LabelNotFound"/>\n<page content\=3D"org.eclipse.ui.internal.introv=
iew" label\=3D"LabelNotFound"/>\n<page content\=3D"org.eclipse.ui.cheatsh=
eets.views.CheatSheetView" label\=3D"LabelNotFound"/>\n</folder>\n</info>=
\n<info folder\=3D"true" part\=3D"org.eclipse.debug.internal.ui.ConsoleFo=
lderView" ratio\=3D"0.7503852" ratioLeft\=3D"487" ratioRight\=3D"162" rel=
ationship\=3D"4" relative\=3D"org.eclipse.debug.internal.ui.NavigatorFold=
erView">\n<folder activePageID\=3D"org.eclipse.ui.console.ConsoleView" ap=
pearance\=3D"2" expanded\=3D"2">\n<page content\=3D"org.eclipse.ui.consol=
e.ConsoleView" label\=3D"Console"/>\n<page content\=3D"org.eclipse.ui.vie=
ws.TaskList" label\=3D"Tasks"/>\n<page content\=3D"org.eclipse.ui.views.B=
ookmarkView" label\=3D"LabelNotFound"/>\n<page content\=3D"org.eclipse.ui=
=2Eviews.PropertySheet" label\=3D"LabelNotFound"/>\n<page content\=3D"org=
=2Eeclipse.jdt.debug.ui.DisplayView" label\=3D"LabelNotFound"/>\n<page co=
ntent\=3D"org.eclipse.search.SearchResultView" label\=3D"LabelNotFound"/>=
\n<presentation id\=3D"org.eclipse.ui.presentations.WorkbenchPresentation=
Factory">\n<part id\=3D"0"/>\n<part id\=3D"1"/>\n</presentation>\n</folde=
r>\n</info>\n<info part\=3D"org.eclipse.ui.editorss" ratio\=3D"0.5382775"=
ratioLeft\=3D"225" ratioRight\=3D"193" relationship\=3D"4" relative\=3D"=
org.eclipse.debug.internal.ui.NavigatorFolderView"/>\n<info folder\=3D"tr=
ue" part\=3D"org.eclipse.debug.internal.ui.OutlineFolderView" ratio\=3D"0=
=2E75" ratioLeft\=3D"1245" ratioRight\=3D"415" relationship\=3D"2" relati=
ve\=3D"org.eclipse.ui.editorss">\n<folder appearance\=3D"2" expanded\=3D"=
2">\n<page content\=3D"org.eclipse.ui.views.ContentOutline" label\=3D"Lab=
elNotFound"/>\n<page content\=3D"org.eclipse.ant.ui.views.AntView" label\=
=3D"LabelNotFound"/>\n<presentation id\=3D"org.eclipse.ui.presentations.W=
orkbenchPresentationFactory"/>\n</folder>\n</info>\n<info folder\=3D"true=
" part\=3D"org.eclipse.debug.internal.ui.ToolsFolderView" ratio\=3D"0.5" =
ratioLeft\=3D"830" ratioRight\=3D"830" relationship\=3D"2" relative\=3D"o=
rg.eclipse.debug.internal.ui.NavigatorFolderView">\n<folder activePageID\=
=3D"org.eclipse.debug.ui.VariableView" appearance\=3D"2" expanded\=3D"2">=
\n<page content\=3D"org.eclipse.debug.ui.VariableView" label\=3D"Variable=
s"/>\n<page content\=3D"org.eclipse.debug.ui.BreakpointView" label\=3D"Br=
eakpoints"/>\n<page content\=3D"org.eclipse.debug.ui.ExpressionView" labe=
l\=3D"LabelNotFound"/>\n<page content\=3D"org.eclipse.debug.ui.RegisterVi=
ew" label\=3D"LabelNotFound"/>\n<presentation id\=3D"org.eclipse.ui.prese=
ntations.WorkbenchPresentationFactory">\n<part id\=3D"0"/>\n<part id\=3D"=
1"/>\n</presentation>\n</folder>\n</info>\n</mainWindow >\n</layout>\n</pe=
rspective>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.M2_=
REPO=3D/home/dacc/.m2/repository
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUN=
IT_HOME=3D/opt/eclipse/plugins/org.junit_3.8.1
e_after_binary_operator=3Dinsert
e_after_comma_in_method_invocation_arguments=3Dinsert
e_after_prefix_operator=3Ddo not insert
e_before_closing_paren_in_if=3Ddo not insert
e_after_comma_in_type_arguments=3Dinsert
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.=
eclipse.jdt.debug.ui.show_null_entries=3Dtrue
e_before_comma_in_method_declaration_throws=3Ddo not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_f=
or_enum_constants=3D0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates=3D <=
?xml version\=3D"1.0" encoding\=3D"UTF-8"?><templates/>
e_before_opening_brace_in_annotation_type_declaration=3Dinse rt
e_after_opening_bracket_in_array_allocation_expression=3Ddo not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=3D=
1.5
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=3Dfalse
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_swit=
chstatements_compare_to_cases=3Dtrue
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=3Dhttp\://dev.=
exaptic.com/trac/metacycle/browser/metacycle/trunk/build.xml |*|http\://de=
v.exaptic.com/trac/metacycle/browser/metacycle/trunk|*|http\ ://dev.exapti=
c.com/trac/metacycle/browser/metacycle|*|http\://dev.exaptic .com/trac/met=
acycle/browser|*|http\://dev.exaptic.com/trac/metacycle/wiki |*|http\://de=
v.exaptic.com/trac/metacycle/timeline|*|http\://dev.exaptic. com/trac/meta=
cycle/ticket/1\#comment\:2|*|http\://dev.exaptic.com/trac/me tacycle/ticke=
t/1|*|http\://dev.exaptic.com/trac/metacycle/query?status\=3 Dnew&status\=3D=
assigned&status\=3Dreopened&milestone\=3DManual+Rout e+Conflation+Package|=
*|http\://dev.exaptic.com/trac/metacycle/roadmap|*|http\://d ev.exaptic.co=
m/trac/metacycle/report|*|http\://dev.exaptic.com/trac/metac ycle/settings=
|*|http\://dev.exaptic.com/trac/metacycle/ticket/1\#comment\ :1|*|http\://=
dev.exaptic.com/trac/metacycle/ticket/1\#preview|*|http\://d ev.exaptic.co=
m/trac/metacycle/newticket|*|http\://dev.exaptic.com/trac/me tacycle/miles=
tone/Manual%20Route%20Conflation%20Package|*|http\://dev.exa ptic.com/trac=
/metacycle/milestone?action\=3Dnew|*|http\://dev.exaptic.com/trac/metacyc=
le/milestone|*|http\://dev.exaptic.com/trac/metacycle/wiki/W ikiFormatting=
|*|http\://dev.exaptic.com/trac/metacycle/milestone/mileston e4?action\=3D=
delete|*|http\://dev.exaptic.com/trac/metacycle/milestone/mi lestone4|*|ht=
tp\://dev.exaptic.com/trac/metacycle/milestone/milestone3?ac tion\=3Ddelet=
e|*|http\://dev.exaptic.com/trac/metacycle/milestone/milesto ne3|*|http\:/=
/dev.exaptic.com/trac/metacycle/milestone/milestone2?action\ =3Ddelete|*|h=
ttp\://dev.exaptic.com/trac/metacycle/milestone/milestone2|* |http\://dev.=
exaptic.com/trac/metacycle/milestone/milestone1?action\=3Dde lete|*|http\:=
//dev.exaptic.com/trac/metacycle/milestone/milestone1|*|
e_before_closing_paren_in_synchronized=3Ddo not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.overrideanno tation=3Dtrue=
e_before_question_in_conditional=3Dinsert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_else_s=
tatement_on_same_line=3Dfalse
/instance/org.eclipse.ui.editors/printMargin=3Dtrue
e_after_opening_paren_in_parenthesized_expression=3Ddo not insert
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=3Dfalse=
/instan
Re: Freshly Created JET2 Transformation Failure [message #13279 is a reply to message #13239] Tue, 24 April 2007 08:14 Go to previous messageGo to next message
Daniel:
There is something wrong with c:dump - not your fault.
Bug 178693 ( https://bugs.eclipse.org/bugs/show_bug.cgi?id=178693) tracks
this.
For the time being, you can either comment out the c:dump tag in main.jet,
delete it, or ignore the error.
It's obviously time I fixed this.
Paul
"Daniel A Carleton" <daniel.carleton@pobox.com> wrote in message
news:f0fcj3$433$1@build.eclipse.org...
> - Daniel
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
70001d
-vm
/usr/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1177235140839
eclipse.vm=/usr/bin/java
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/opt/eclipse/startup.jar
java.class.version=49.0
java.endorsed.dirs=/usr/lib/j2sdk1.5-sun/jre/lib/endorsed
java.ext.dirs=/usr/lib/j2sdk1.5-sun/jre/lib/ext
java.home=/usr/lib/j2sdk1.5-sun/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/j2sdk1.5-sun/jre/lib/i386/client: /usr/lib/j2sdk1.5-sun/jre/lib/i386:/usr/lib/j2sdk1.5-sun/jre /../lib/i386:/usr/lib/firefox/
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_10-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_10-b03
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.17-10-386
org.osgi.framework.processor=i386
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/opt/eclipse/configuration/org.eclipse.osgi /bundles
osgi.configuration.area=file:/opt/eclipse/configuration/
osgi.framework=file:/opt/eclipse/plugins/org.eclipse.osgi_3. 2.2.R32x_v20070118.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/opt/eclipse/
osgi.instance.area=file:/home/dacc/workspace/
osgi.instance.area.default=file:/home/dacc/workspace/
osgi.logfile=/home/dacc/workspace/.metadata/.log
osgi.manifest.cache=/opt/eclipse/configuration/org.eclipse.o sgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/opt/eclipse/plugins/org.eclipse.platfor m_3.2.2.r322_v20070117b/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/opt/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/lib/j2sdk1.5-sun/jre/lib/rt.jar:/us r/lib/j2sdk1.5-sun/jre/lib/i18n.jar:/usr/lib/j2sdk1.5-sun/jr e/lib/sunrsasign.jar:/usr/lib/j2sdk1.5-sun/jre/lib/jsse.jar: /usr/lib/j2sdk1.5-sun/jre/lib/jce.jar:/usr/lib/j2sdk1.5-sun/ jre/lib/charsets.jar:/usr/lib/j2sdk1.5-sun/jre/classes
sun.boot.library.path=/usr/lib/j2sdk1.5-sun/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/home/dacc/workspace/metacycle
user.home=/home/dacc
user.language=en
user.name=dacc
user.timezone=GMT-08:00
*** Features:
(SDO)"
Development Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java
Technologies - JET"
Development Environment"
Plug-in Development Environment Developer Resources"
Platform"
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP
org.eclipse.sdk (3.2.2.r322_v20070104-dCGKm0Ln38lm-8s) "Eclipse Project SDK"
(WST)"
Mylar"
com.ibm.icu (3.4.5.20061213) "International Components for Unicode for Java
(ICU4J)" [Active]
Plug-in" [Resolved]
Plug-in" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.resources (3.2.2.R32x_v20061218) "Core Resource Management"
[Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorization
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved]
[Resolved]
org.eclipse.emf.codegen (2.2.2.v200702131851) "EMF Template Code Generator"
[Resolved]
Generation" [Resolved]
Generation UI" [Resolved]
[Resolved]
Generator UI" [Resolved]
org.eclipse.emf.common.ui (2.2.1.v200702131851) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.v200702131851) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200702131851) "EMF Model Convert Support"
[Resolved]
org.eclipse.emf.ecore.change (2.2.1.v200702131851) "EMF Ecore Change Model"
[Resolved]
[Resolved]
[Resolved]
(SDO)" [Resolved]
Objects (SDO) Edit Support" [Resolved]
[Resolved]
[Resolved]
[Resolved]
Importer" [Resolved]
[Resolved]
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200702131851) "Ecore to
Mapping" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200702131851) "EMF Mapping UI" [Resolved]
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200702131851) "XSD to Ecore
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse Preferences
Mechanism" [Active]
Support" [Active]
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework" [Resolved]
[Resolved]
org.eclipse.help.base (3.2.2.R322_v20061207) "Help System Base" [Resolved]
[Resolved]
[Resolved]
Processing Core" [Active]
Processing UI" [Resolved]
[Active]
Manipulation Functionality" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools JUnit
support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development Tools
Tools JUnit4 runtime support" [Resolved]
[Active]
(Introspection) Support" [Resolved]
[Resolved]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities" [Active]
Support" [Resolved]
Technologies - JET" [Active]
Technologies - JET Core" [Active]
[Active]
[Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring Core"
[Active]
[Resolved]
Plug-in" [Active]
[Active]
org.eclipse.mylar.doc (2.0.0.v20070403-1300) "Mylar Documentation Plug-in"
[Resolved]
org.eclipse.mylar.java (2.0.0.v20070403-1300) "Mylar Java Plug-in" [Active]
Plug-in" [Resolved]
Plug-in" [Active]
org.eclipse.mylar.resources (2.0.0.v20070403-1300) "Mylar Resources Plugin"
[Active]
Plug-in" [Active]
org.eclipse.mylar.tasks.ui (2.0.0.v20070403-1300) "Mylar Tasks UI Plug-in"
[Active]
org.eclipse.mylar.tasks.web (2.0.0.v20070403-1300) "Mylar Web Tasks Plug-in"
[Active]
org.eclipse.mylar.team (2.0.0.v20070403-1300) "Mylar Team Plug-in" [Active]
org.eclipse.mylar.trac.core (2.0.0.v20070403-1300) "Mylar Trac Core Plug-in"
[Active]
[Active]
[Resolved]
[Resolved]
Environment" [Resolved]
Environment Build Support" [Active]
[Active]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in Development
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment
Runtime" [Resolved]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI" [Active]
org.eclipse.platform (3.2.2.r322_v20070117b) "Eclipse Platform" [Resolved]
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse Workbench
(3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform Plug-in Developer
org.eclipse.rcp.source.linux.gtk.x86 (3.2.2.r322_v20070104-8pcviKVqd8J7C1U)
org.eclipse.swt.gtk.linux.x86 (3.2.2.v3236) "Standard Widget Toolkit for GTK
2.0" [Resolved]
[Active]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
[Active]
org.eclipse.ui.intro (3.2.2.R322_v20061214) "Welcome Framework" [Resolved]
[Resolved]
[Resolved]
Workbench Components" [Resolved]
Plug-in" [Resolved]
Properties View" [Resolved]
Framework" [Active]
Configurator" [Active]
[Active]
Linux" [Resolved]
Scheduler" [Active]
org.eclipse.update.ui (3.2.2.R32x_v20070111) "Install/Update UI" [Resolved]
org.eclipse.wst (1.0.1.v200605040144) "Web Standard Tools (WST)" [Resolved]
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.doc.user (1.5.0.v20060831345) "Web services Axis
org.eclipse.wst.command.env.infopop (1.0.2.v200605070230) "Web services UI"
[Resolved]
org.eclipse.wst.command.env.ui (1.0.102.v200608222020) "Environment Command
Plug-in" [Resolved]
org.eclipse.wst.common.emf (1.1.3.v200612061436) "EMF Utilities" [Resolved]
org.eclipse.wst.common.emfworkbench.integration (1.1.4.v200702021430) "EMF
Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.1.3.v200702071605) "Common Frameworks"
[Active]
org.eclipse.wst.common.frameworks.ui (1.1.2.v200702071605) "WTP UI Plug-in"
[Resolved]
org.eclipse.wst.common.infopop (1.0.1.v200605270041) "Common WST infopops"
[Resolved]
Plug-in" [Resolved]
org.eclipse.wst.common.project.facet.ui (1.1.2.v200701192142) "Project Facet
UI" [Resolved]
[Resolved]
extensions" [Resolved]
Properties UI" [Resolved]
Resolver Framework" [Active]
org.eclipse.wst.css.core (1.1.1.v200609140550) "Structured Source CSS Model"
[Active]
[Resolved]
"Database Explorer documentation" [Resolved]
[Resolved]
org.eclipse.wst.dtd.core (1.1.1.v200609210600) "Structured Source DTD Core"
[Resolved]
[Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200605040131) "DTD Editor infopops"
[Resolved]
Model" [Active]
[Resolved]
[Resolved]
org.eclipse.wst.html.ui.infopop (1.0.1.v200605040131) "HTML editor infopops"
[Resolved]
org.eclipse.wst.internet.cache (1.0.103.v200612070353) "Cache URI Resolver
Plug-in" [Active]
[Resolved]
[Resolved]
Preferences" [Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200605070230) "Internet Proxy
org.eclipse.wst.javascript.ui (1.0.2.v200701250230) "SSE JavaScript Source
Editor" [Resolved]
infopop" [Resolved]
Connection.ui" [Resolved]
Connection wizard infopops" [Resolved]
[Resolved]
[Resolved]
[Resolved]
Database Definition" [Resolved]
"DBDefinition Generic JDBC Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.104.v200610261819) "Informix
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.101.v200610161905) "DBDefinition
Server Database Definition Plug-in" [Resolved]
[Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.103.v200612130213) "RDB Derby Ui Plug-in"
[Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.104.v200612130213) "FE UI Plug-in" [Resolved]
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0.v200605040131) "Generate DDL wizard
"DBDefinition Model" [Resolved]
[Resolved]
org.eclipse.wst.rdb.models.sql.edit (1.0.103.v200612130213) "SQLModel Edit
Plug-in" [Resolved]
[Resolved]
org.eclipse.wst.rdb.outputview (1.0.107.v200612130213) "Data Output Plug-in"
[Resolved]
Explorer Extensions Plug-in" [Resolved]
plugin" [Resolved]
org.eclipse.wst.rdb.server.ui.infopop (1.0.0.v200605040131) "Server Explorer
Plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0.v200605040131) "SQL infopops"
[Resolved]
Plug-in" [Resolved]
infopops for Web Standard Tools" [Resolved]
[Active]
org.eclipse.wst.sse.doc.user (1.0.203.v200608300230) "Structured text editor
[Active]
[Resolved]
[Active]
org.eclipse.wst.validation.infopop (1.0.201.v200606130645) "WST validation
UI" [Resolved]
[Resolved]
org.eclipse.wst.web.ui.infopop (1.0.201.v200605070230) "Static Web infopop"
[Resolved]
org.eclipse.wst.ws.explorer (1.0.104.v200701250524) "Web Services Explorer"
[Resolved]
org.eclipse.wst.ws.infopop (1.0.202.v20070131) "Web Services UI" [Resolved]
org.eclipse.wst.ws.parser (1.0.101.v200609062128) "Web Services Description
Parser" [Resolved]
org.eclipse.wst.ws.ui (1.0.102.v200702021555) "Web Services UI" [Resolved]
[Resolved]
[Resolved]
Model" [Active]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
editor" [Resolved]
[Active]
for EMF" [Resolved]
for EMF" [Resolved]
[Resolved]
org.eclipse.xsd.editor (2.2.0.v200702131851) "XML Schema Editor" [Resolved]
org.rubypeople.rdt (0.8.1.609062100PRD) "Ruby Development Tools" [Resolved]
org.rubypeople.rdt.core (0.8.1.609062100PRD) "Ruby Development Tools Core"
[Resolved]
org.rubypeople.rdt.debug.core (0.8.1.609062100PRD) "Ruby Development Debug
Core" [Resolved]
[Resolved]
org.springframework.ide.eclipse.beans.core (1.3.5) "Spring IDE Beans Core"
[Active]
[Active]
Graph" [Resolved]
org.springframework.ide.eclipse.beans.ui.navigator (0.9.0) "Spring IDE Beans
org.springframework.ide.eclipse.beans.ui.search (1.0.2) "Spring IDE Beans UI
Search" [Resolved]
org.springframework.ide.eclipse.core.doc (1.2.8) "Spring Framework Reference
[Active]
[Resolved]
Mylar" [Active]
org.tigris.subversion.subclipse.ui (1.2.0) "SVN Team Provider UI" [Active]
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.indent_parameter_description=true
@org.eclipse.ui.editors=3.2.1.r321_v20060721
@org.eclipse.debug.ui=3.2.2.r322_v20070202
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_at_in_annotation_type_declaration=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.brace_position_for_enum_constant=end_of_line
/instance/org.eclipse.ui.workbench/org.eclipse.debug.ui.Debu gPerspective_persp= <?xml
version\="1.0" encoding\="UTF-8"?>\n<perspective editorAreaVisible\="1"
fixed\="0" version\="0.016">\n<descriptor
class\="org.eclipse.debug.internal.ui.DebugPerspectiveFactory "
id\="org.eclipse.debug.ui.DebugPerspective" label\="Debug"/>\n<window
height\="764" width\="1680" x\="0" y\="286"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.actionSet.keyBindings"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.WorkingSetActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.update.ui.softwareUpdates"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.externaltools.ExternalToolsSet"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.openExternalFile"/ >\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.annotationNavigation "/>\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.navigation"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo "/>\n<alwaysOnActionSet
id\="org.eclipse.search.searchActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.cheatsheets.actionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.wst.server.ui.internal.webbrowser.actionSet "/>\n<alwaysOnActionSet
id\="org.springframework.ide.eclipse.beans.ui.actionSet"/>\n <alwaysOnActionSet
id\="org.springframework.ide.eclipse.beans.search.actionSet "/>\n<alwaysOnActionSet
id\="viPlugin.actionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.mylar.ui.mylar.actionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.mylar.tasks.navigation"/>\n<alwaysOnActionSet
id\="org.eclipse.mylar.doc.actionSet"/>\n<alwaysOnActionSet
id\="org.rubypeople.rdt.debug.ui.RDTDebugActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.launchActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.ui.NavigateActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.breakpointActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.jdt.debug.ui.JDTDebugActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.jdt.ui.JavaActionSet"/>\n<alwaysOnActionSet
id\="org.eclipse.debug.ui.debugActionSet"/>\n<show_view_action
id\="org.eclipse.debug.ui.DebugView"/>\n<show_view_action
id\="org.eclipse.debug.ui.VariableView"/>\n<show_view_action
id\="org.eclipse.debug.ui.BreakpointView"/>\n<show_view_action
id\="org.eclipse.debug.ui.ExpressionView"/>\n<show_view_action
id\="org.eclipse.ui.views.ContentOutline"/>\n<show_view_action
id\="org.eclipse.ui.console.ConsoleView"/>\n<show_view_action
id\="org.eclipse.ui.views.TaskList"/>\n<show_view_action
id\="org.eclipse.ant.ui.views.AntView"/>\n<show_view_action
id\="org.eclipse.jdt.debug.ui.DisplayView"/>\n<show_view_action
id\="org.eclipse.pde.runtime.LogView"/>\n<perspective_action
id\="org.eclipse.jdt.ui.JavaPerspective"/>\n<perspective_action
id\="org.eclipse.jdt.ui.JavaBrowsingPerspective"/>\n<perspective_action
id\="org.rubypeople.rdt.ui.PerspectiveRuby"/>\n<perspective_action
id\="org.rubypeople.rdt.ui.RubyBrowsingPerspective"/>\n<view
id\="org.eclipse.ui.console.ConsoleView"/>\n<view
id\="org.eclipse.ui.views.TaskList"/>\n<view
id\="org.eclipse.debug.ui.DebugView"/>\n<view
id\="org.eclipse.wst.server.ui.ServersView"/>\n<view
id\="org.eclipse.debug.ui.VariableView"/>\n<view
id\="org.eclipse.debug.ui.BreakpointView"/>\n<layout>\n <mainWindow>\n<info
folder\="true"
part\="org.eclipse.debug.internal.ui.NavigatorFolderView">\n <folder
activePageID\="org.eclipse.debug.ui.DebugView" appearance\="2"
expanded\="2">\n<page content\="org.eclipse.debug.ui.DebugView"
label\="Debug"/>\n<page content\="org.eclipse.ui.views.ResourceNavigator"
label\="LabelNotFound"/>\n<page
content\="org.eclipse.jdt.ui.PackageExplorer"
label\="LabelNotFound"/>\n<page content\="org.eclipse.jdt.ui.TypeHierarchy"
content\="org.eclipse.wst.server.ui.ServersView"
label\="Servers"/>\n<presentation
id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory ">\n<part
id\="0"/>\n<part id\="1"/>\n</presentation>\n</folder>\n</info>\n<info
folder\="true" part\="stickyFolderRight" ratio\="0.75" ratioLeft\="1245"
ratioRight\="415" relationship\="2"
relative\="org.eclipse.debug.internal.ui.NavigatorFolderView ">\n<folder
appearance\="2" expanded\="2">\n<page
content\="org.eclipse.help.ui.HelpView" label\="LabelNotFound"/>\n<page
content\="org.eclipse.ui.internal.introview" label\="LabelNotFound"/>\n<page
content\="org.eclipse.ui.cheatsheets.views.CheatSheetView"
label\="LabelNotFound"/>\n</folder>\n</info>\n<info folder\="true"
part\="org.eclipse.debug.internal.ui.ConsoleFolderView" ratio\="0.7503852"
ratioLeft\="487" ratioRight\="162" relationship\="4"
activePageID\="org.eclipse.ui.console.ConsoleView" appearance\="2"
expanded\="2">\n<page content\="org.eclipse.ui.console.ConsoleView"
label\="Console"/>\n<page content\="org.eclipse.ui.views.TaskList"
label\="Tasks"/>\n<page content\="org.eclipse.ui.views.BookmarkView"
content\="org.eclipse.ui.views.PropertySheet"
content\="org.eclipse.jdt.debug.ui.DisplayView"
content\="org.eclipse.search.SearchResultView"
label\="LabelNotFound"/>\n<presentation
part\="org.eclipse.ui.editorss" ratio\="0.5382775" ratioLeft\="225"
ratioRight\="193" relationship\="4"
relative\="org.eclipse.debug.internal.ui.NavigatorFolderView "/>\n<info
folder\="true" part\="org.eclipse.debug.internal.ui.OutlineFolderView"
ratio\="0.75" ratioLeft\="1245" ratioRight\="415" relationship\="2"
relative\="org.eclipse.ui.editorss">\n<folder appearance\="2"
expanded\="2">\n<page content\="org.eclipse.ui.views.ContentOutline"
label\="LabelNotFound"/>\n<page content\="org.eclipse.ant.ui.views.AntView"
id\="org.eclipse.ui.presentations.WorkbenchPresentationFactory "/>\n</folder>\n</info>\n<info
folder\="true" part\="org.eclipse.debug.internal.ui.ToolsFolderView"
ratio\="0.5" ratioLeft\="830" ratioRight\="830" relationship\="2"
activePageID\="org.eclipse.debug.ui.VariableView" appearance\="2"
expanded\="2">\n<page content\="org.eclipse.debug.ui.VariableView"
label\="Variables"/>\n<page content\="org.eclipse.debug.ui.BreakpointView"
label\="Breakpoints"/>\n<page content\="org.eclipse.debug.ui.ExpressionView"
label\="LabelNotFound"/>\n<page content\="org.eclipse.debug.ui.RegisterView"
id\="0"/>\n<part
id\="1"/>\n</presentation>\n</folder>\n</info>\n</mainWindow >\n</layout>\n</perspective>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.M2_REPO=/home/dacc/.m2/repository
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=/opt/eclipse/plugins/org.junit_3.8.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_binary_operator=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_method_invocation_arguments=in sert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_prefix_operator=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_if=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_comma_in_type_arguments=insert
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_method_declaration_throws=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_enum_constants=0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_brace_in_annotation_type_decla ration=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_bracket_in_array_allocation_exp ression=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.5
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.indent_switchstatements_compare_to_cases=true
/instance/org.eclipse.ui.browser/internalWebBrowserHistory= http\://dev.exaptic.com/trac/metacycle/browser/metacycle/tru nk/build.xml|*|http\://dev.exaptic.com/trac/metacycle/browse r/metacycle/trunk|*|http\://dev.exaptic.com/trac/metacycle/b rowser/metacycle|*|http\://dev.exaptic.com/trac/metacycle/br owser|*|http\://dev.exaptic.com/trac/metacycle/wiki|*|http\: //dev.exaptic.com/trac/metacycle/timeline|*|http\://dev.exap tic.com/trac/metacycle/ticket/1\#comment\:2|*|http\://dev.ex aptic.com/trac/metacycle/ticket/1|*|http\://dev.exaptic.com/ trac/metacycle/query?status\=new&status\=assigned&st atus\=reopened&milestone\=Manual+Route+Conflation+Packag e|*|http\://dev.exaptic.com/trac/metacycle/roadmap|*|http\:/ /dev.exaptic.com/trac/metacycle/report|*|http\://dev.exaptic .com/trac/metacycle/settings|*|http\://dev.exaptic.com/trac/ metacycle/ticket/1\#comment\:1|*|http\://dev.exaptic.com/tra c/metacycle/ticket/1\#preview|*|http\://dev.exaptic.com/trac /metacycle/newticket|*|http\://dev.exaptic.com/trac/metacycl e/milestone/Manual%20Route%20Conflation%20Package|*|http\:// dev.exaptic.com/trac/metacycle/milestone?action\=new|*|http\ ://dev.exaptic.com/trac/metacycle/milestone|*|http\://dev.ex aptic.com/trac/metacycle/wiki/WikiFormatting|*|http\://dev.e xaptic.com/trac/metacycle/milestone/milestone4?action\=delet e|*|http\://dev.exaptic.com/trac/metacycle/milestone/milesto ne4|*|http\://dev.exaptic.com/trac/metacycle/milestone/miles tone3?action\=delete|*|http\://dev.exaptic.com/trac/metacycl e/milestone/milestone3|*|http\://dev.exaptic.com/trac/metacy cle/milestone/milestone2?action\=delete|*|http\://dev.exapti c.com/trac/metacycle/milestone/milestone2|*|http\://dev.exap tic.com/trac/metacycle/milestone/milestone1?action\=delete|* |http\://dev.exaptic.com/trac/metacycle/milestone/milestone1 |*|
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_paren_in_synchronized=do
not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.overrideanno tation=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_question_in_conditional=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.keep_else_statement_on_same_line=false
/instance/org.eclipse.ui.editors/printMargin=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_after_opening_paren_in_parenthesized_expressi on=do
not insert
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_for_increments=do
not insert
/instance/org.eclipse.ui.ide/quickStart=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_closing_angle_bracket_in_parameterized _type_reference=do
not insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_comma_in_multiple_field_declarations=d o
not insert
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Mo nospace|10|0|GTK|1|;
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.clear_blank_lines=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_constructor_declarati on=do
not insert
/instance/org.eclipse.debug.ui/pref_state_memento.org.eclips e.debug.ui.ExpressionView= <?xml
version\="1.0" encoding\="UTF-8"?>\n<VariablesViewMemento
org.eclipse.debug.ui.SASH_DETAILS_PART\="271"
org.eclipse.debug.ui.SASH_VIEW_PART\="716"/>
/project/metacycle/org.eclipse.jet/org.eclipse.jet.projectPr efs=true
/instance/org.eclipse.jdt.ui/formatter_profile=_Exaptic
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.alignment_for_conditional_expression=80
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.comment.format_header=false
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplo rer.LibraryFilter=true
/instance/org.eclipse.debug.ui/Expressions.detail.orientatio n=Variables.detail.orientation.underneath
/instance/org.eclipse.ant.ui/problem_classpath=warning
/instance/org.eclipse.core.reso
Re: Freshly Created JET2 Transformation Failure [message #13310 is a reply to message #13279] Wed, 25 April 2007 03:36 Go to previous message
Originally posted by: daniel.carleton.pobox.com
Paul,
> this.
I didn't even think to try my own templates, but they are indeed working
fine.
Thanks for your response. I'm getting some good use out of JET2 now.
- Daniel
Previous Topic:jets transformation
Next Topic:xml namespace parsing
Current Time: Sun Aug 31 14:38:41 EDT 2025
Powered by FUDForum. Page generated in 0.04831 seconds
