Home » Language IDEs » ServerTools (WTP) » Tomcat failed to start
Tomcat failed to start [message #143007] Mon, 10 October 2005 04:31 Go to next message
Originally posted by: giuseppe_italiano.hotmail.com
Hi guys,
I've installed Eclipse 3.1, Tomcat 5.5 and Java 1.5.0 on Linux Red Hat 9.
My application works fine when I run Tomcat in standalone.
Instead when I run in embedded mode I receive the message in object and I can't find any log.
Any help will be appreciated because I'm getting crazy
Thanks bye
Giuseppe
Re: Tomcat failed to start [message #143109 is a reply to message #143007] Tue, 11 October 2005 10:41 Go to previous message
OKay, firs tyou need log4j.properties in your log folder for Tomcat..
Tomcat 5.5 does not install this log configuration by default..
See manual for details..
Once this is done you should be able to trakc your error from the log..
Previous Topic:JBoss 4.0.3 definitions
Next Topic:XML editor fails after using ANT editor on file
Current Time: Sun Aug 10 23:14:31 EDT 2025
Powered by FUDForum. Page generated in 0.04417 seconds
