Home » Archived » Test and Performance Tools Platform (TPTP) » Profiling Web Application on JBOSS using integreated TPTP with Eclipse.
Profiling Web Application on JBOSS using integreated TPTP with Eclipse. [message #142858] Thu, 25 June 2009 09:37 Go to next message
I have successfully profiled a java application on Eclipse 3.3.2, JRE 1.6
using TPTP 4.4.1.
Now I want to profile a web application deployed on JBOSS 3.2.
I have configured all the required plugins TPTP-WTP integration that
includes
# Eclipse Web Tools Platform (WTP) 2.0.2
# Graphics Editor Framework (GEF) 3.3.2
# Data Tools Platform (DTP) 1.5.2
Apart from this i am using All TPTP plugins [ Runtime] which says it
contains TPTP-WTP (required for Profile on Server) and TPTP-BIRT (required
for BIRT Reporting) integration features.
Still I am not able to get profile option enabled for jboss server.Profile
option comes disable in the servers view as well as on right clicking the
server.
Are there are some extra plugin required to configure for enabling
profiling for JBOSS 3.2 in Eclipse 3.3.2?
Re: Profiling Web Application on JBOSS using integreated TPTP with Eclipse. [message #142868 is a reply to message #142858] Thu, 25 June 2009 10:55 Go to previous messageGo to next message
Hi Surbhigl,
JBOSS is not an supported server for profiling on server feature.
You can however follow the link below to insert the necessary JVM argument
to JBOSS startup script to have an profiling agent associated with the
server process and attach to the Java process under profiled from a Eclipse
workbench to monitor the JBOSS process.
For Window, see >
http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platform.agentcontroller/src-native-new/packaging_md/ windows/getting_started.html?root=TPTP_Project&view=co#J ava_15
For Linux, see >
http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platform.agentcontroller/src-native-new/packaging_md/ linux/getting_started.html?root=TPTP_Project&view=co#Jav a_15
Eugene
"surbhigl " <surbhi.mittal@globallogic.com> wrote in message
news:b5567d31e23ced0df6ff5daaa5be5e9a$1@www.eclipse.org...
> using TPTP 4.4.1.
> includes
> server.
Re: Profiling Web Application on JBOSS using integreated TPTP with Eclipse. [message #142877 is a reply to message #142868] Fri, 26 June 2009 05:47 Go to previous messageGo to next message
I am trying to profile jboss using the approach you told in the previous
reply.I followed following steps.
1. I downloaded the AgentController 4.4.1 for windows-32.
2. I set all the required paths variables
# Set TPTP_AC_HOME=<<Agent Controller Home>>
# Set
JAVA_PROFILER_HOME=%TPTP_AC_HOME%\plugins\org.eclipse.tptp.j avaprofiler
# Set PATH=%JAVA_PROFILER_HOME%;%TPTP_AC_HOME%\bin;%PATH%
3. I modified the run script for JBOSS AS 3.2 to include
set JAVA_OPTS=-agentlib:JPIBootLoader=JPIAgent:server=enabled %JAVA_OPTS%
Then I started JBoss server. Jboss server was not able to read the
environment variables set in the system so i added all the dlls in
JAVA_PROFILER_HOME and %TPTP_AC_HOME%\bin in jdk\bin to make it run.
It started getting the required dlls but still not able to start the agent
successfully. This is the error on command prompt.
Error occurred during initialization of VM
agent library failed to init: JPIBootLoader
This is the servicelog.log
<CommonBaseEvent creationTime="2009-06-26T09:20:51.064000Z"
globalInstanceId="A63DF9DF50804F5D97E677AD68A572E2" msg="Received command
for unrecognized interface: iid=org.eclipse.tptp.eventProvider,
cmd=listenerAccepted" severity="50" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent"
executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\TPTPClientCompTL\Connect2AC.c,
line 2238" instanceId="1004" location="D-19187.synapse.com"
locationType="IPV4" processId="2900" subComponent="Client Compatibility
TL" threadId="2400" componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-06-26T09:20:51.345000Z"
globalInstanceId="ADBC2DF964CA4BE98425F8D018468D5B" msg="File server
started listening on port 10005" severity="10" version="1.0.1">
executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\transport\TPTPClientCompTL\fileServer.c,
line 177" instanceId="1004" location="D-19187.synapse.com"
TL" threadId="2592" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-06-26T09:21:13.299000Z"
globalInstanceId="AC6AA3DB3F894C59B8FDBE0A95710BCE" msg="PC
handleProcessEvents: Process has exited with status 0." severity="50"
version="1.0.1">
<sourceComponentId component="ProcessController"
componentIdType="TPTPComponent" componentType="Eclipse_TPTP"
executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.1\TPTP-4.4.1-200802230953\agnt ctrl\src\agents\tptpProcessController\ProcessController_md.c pp,
line 284" instanceId="101" location="D-19187.synapse.com"
locationType="IPV4" processId="1652" subComponent="ProcessController"
threadId="3352"/>
<situationType reasoningScope="INTERNAL" reportCategory="LOG"
xsi:type="ReportSituation"/>
</situation>
</CommonBaseEvent>
I also tried running the jboss after launching ACServer.exe. But it didnt
work either.
Re: Profiling Web Application on JBOSS using integreated TPTP with Eclipse. [message #142887 is a reply to message #142868] Fri, 26 June 2009 07:08 Go to previous messageGo to next message
I have also tried to add
set MARTINI_LOGGER_DIRECTORY =
C:\downloads\agntctrl.win_ia32-TPTP-4.4.1\plugins\org.eclips e.tptp.javaprofiler\log
set MARTINI_LOGGER_LOG_LEVEL = 5 or 0 (tried with both)
But no log file is creating in the log directory i have specified.
Re: Profiling Web Application on JBOSS using integreated TPTP with Eclipse. [message #142896 is a reply to message #142868] Fri, 26 June 2009 08:40 Go to previous messageGo to next message
I have been trying more on this and found that I was not specifying the
name of the Profiler which was giving that error. I have been able to
launch the JBOSS server, now i will try attaching agents from the eclipse.
Sorry for the previous posts, you can ignore them as of now.
Re: Profiling Web Application on JBOSS using integreated TPTP with Eclipse. [message #142966 is a reply to message #142896] Tue, 30 June 2009 17:09 Go to previous message
Hi Surbhigl,
Good to know that it's working for you now. I would like to point out what
you missed here for future reference in the newsgroup.
JAVA_OPTS=-agentlib:JPIBootLoader=JPIAgent:server=enabled;CG prof
CGProf , HeapProf or TheradProf is needed in the JVM argument
see here for detail > Invocation of the Java Profiler from the Command Line
Eugene
news:d030418852b47f247531394da2197598$1@www.eclipse.org...
Previous Topic:Unable to get profiler data in eclipse
Next Topic:Application Hang while profile
Current Time: Mon Jul 14 20:47:02 EDT 2025
Powered by FUDForum. Page generated in 0.04587 seconds
