Home » Eclipse Projects » Subversive » Merging branches
Merging branches [message #13154] Thu, 07 February 2008 20:09 Go to next message
I'm confused at how to merge. I created a branch to work on some new
stuff. I created it by copying a project from my trunk. So now I want to
merge my changes back into the trunk. What is the exact procedure to do
this, assuming people have been actively working on the trunk and their
changes to exist in my branch.
Re: Merging branches [message #13295 is a reply to message #13154] Sat, 09 February 2008 05:13 Go to previous message
Subversive supports merge view similar to CVS one. So, you can chek if it
is enabled in plug-in preferences (Window->Preferences->Team->SVN->SVN
Client->Use SVN Merge View) then simply call Team->Merge action on
required projects, select a resource merging with required, select start
and stop revisions, press "Ok" and check in Merge View what changes you
want to merge into your working copy.
More about the merge process in SVN please read at:
http://svnbook.red-bean.com/index.en.html
Previous Topic:how to avoid accidental commits to tags
Next Topic:Errors Creating Tags
Current Time: Sat Oct 25 03:33:34 EDT 2025
Powered by FUDForum. Page generated in 0.05132 seconds
