Home » Archived » Tigerstripe » Using attributes for relations
Using attributes for relations [message #13134] Tue, 27 January 2009 10:59 Go to next message
I have a model where some attributes are in fact relations (the old OSS/J
way of doing).
However, using Tigerstripe 0.4, the relations do not show in the diagram.
I tried to modify my profile, chcking "Artifact attributes can be used as
references" and "Implements relationship" but the realtionships were still
not showing up in the diagram.
Any idea how to get those?
Marc
Re: Using attributes for relations [message #13240 is a reply to message #13134] Tue, 27 January 2009 11:36 Go to previous messageGo to next message
Hi Mark,
Just tried that with 0.4.5, and got the relations without problem with a
profile that has them "turned on".
Could you confirm the version of Tigerstripe you're using. We just released
0.4.5 on Friday.
If so, we need to have a look at the logs to figure what is going on.
Eric
On 1/27/09 7:59 AM, in article
6e718f1ba002aa3ada11953f64ec991a$1@www.eclipse.org, "Marc FLAUW"
<marc.flauw@hp.com> wrote:
> Hello,
> way of doing).
> Marc
Re: Using attributes for relations [message #13265 is a reply to message #13240] Tue, 27 January 2009 11:54 Go to previous messageGo to next message
Eric,
I have not upgraded to 0.4.5. Still on the initial 0.4.
I will make another try later with the latest version.
Marc
Re: Using attributes for relations [message #13293 is a reply to message #13265] Tue, 27 January 2009 12:36 Go to previous messageGo to next message
Thanks for the update Marc.
We did fix quite a long list of annoying bugs that we didn't catch on the
initial release of 0.4.
Eric
On 1/27/09 8:54 AM, in article
16e808f1b29f7f851230f6fedea1cead$1@www.eclipse.org, "Marc FLAUW"
> Eric,
> Best regards,
> Marc
Re: Using attributes for relations [message #13321 is a reply to message #13293] Wed, 28 January 2009 05:23 Go to previous message
Eric,
I did install 0.4.5. The old diagrams didn't work. They created an
exception.
I had to redo them, but the attributes were correctly translated as
relations.
best regards,
Marc
Re: Using attributes for relations [message #564049 is a reply to message #13134] Tue, 27 January 2009 11:36 Go to previous message
Hi Mark,
0.4.5 on Friday.
Eric
> Hello,
> way of doing).
> Marc
Re: Using attributes for relations [message #564068 is a reply to message #13240] Tue, 27 January 2009 11:54 Go to previous message
Eric,
Marc
Re: Using attributes for relations [message #564086 is a reply to message #13265] Tue, 27 January 2009 12:36 Go to previous message
Eric
> Eric,
> Best regards,
> Marc
Re: Using attributes for relations [message #564107 is a reply to message #13293] Wed, 28 January 2009 05:23 Go to previous message
Eric,
exception.
relations.
best regards,
Marc
Previous Topic:Adding a relationship
Next Topic:UML Import
Current Time: Mon Sep 01 06:58:25 EDT 2025
Powered by FUDForum. Page generated in 0.05721 seconds
