Home » Modeling » GMF (Graphical Modeling Framework) » cannot reopen diagram in the editor after executing SetBoundsCommand or setLayoutConstraint(cannot reopen diagram in the editor after executing SetBoundsCommand or setLayoutConstraint)
cannot reopen diagram in the editor after executing SetBoundsCommand or setLayoutConstraint [message #983688] |
Wed, 14 November 2012 04:32 |
I tried to generate diagram nodes and link programatically using EMF command and it worked fine, except node locations
I tired to relocated node using SetBoundsCommand
GraphicalEditPart gEditpart = (GraphicalEditPart)editpart;
Rectangle rect = gEditpart.getFigure().getClientArea().getCopy();
rect.setLocation(location.x, location.y);
SetBoundsCommand sbc = new SetBoundsCommand(editpart.getEditingDomain(), "change location", new EObjectAdapter((View) editpart.getModel()), rect);
editpart.getDiagramEditDomain().getDiagramCommandStack().execute(new ICommandProxy(sbc));
after executing above command, it looked fine as expected
but when reopening diagram in the editor, I am getting this error
IRJS0007E Semantic refresh failed
!ENTRY org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1 2012-11-14 09:37:52.157
!MESSAGE Unresolved reference '_xVpzkC4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 33, 201)
!MESSAGE Unresolved reference '_xV_KwC4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 33, 201)
!ENTRY org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1 2012-11-14 09:37:52.158
!MESSAGE Unresolved reference '_xV_x0C4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 38, 201)
!MESSAGE Unresolved reference '_xWUh8C4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 38, 201)
!MESSAGE Unresolved reference '_xWVwEC4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 43, 201)
!ENTRY org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1 2012-11-14 09:37:52.159
!MESSAGE Unresolved reference '_xWsVYC4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 43, 201)
!MESSAGE Unresolved reference '_xXHzMC4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 48, 201)
!MESSAGE Unresolved reference '_xVqaoC4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 48, 201)
!ENTRY org.eclipse.gmf.runtime.diagram.ui.resources.editor 4 1 2012-11-14 09:37:52.160
!MESSAGE Unresolved reference '_xWtjgC4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 53, 201)
!MESSAGE Unresolved reference '_xXHMIC4QEeKAObqZ4Gv3Bg'. (platform:/resource/myproject/src/myfile.test_diagram, 53, 201)
!ENTRY org.eclipse.gmf.runtime.diagram.ui 4 2 2012-11-14 09:37:57.396
!MESSAGE IRJS0007E Semantic refresh failed.
!STACK 0
at org.test.myeditor.diagram.edit.policies.TestDiagramCanonicalEditPolicy.refreshConnections(TestDiagramCanonicalEditPolicy.java:201)
at org.test.myeditor.diagram.edit.policies.TestDiagramCanonicalEditPolicy.refreshSemantic(TestDiagramCanonicalEditPolicy.java:167)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEditPolicy.refresh(CanonicalEditPolicy.java:961)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEditPolicy.refreshOnActivate(CanonicalEditPolicy.java:638)
at org.test.myeditor.diagram.edit.policies.TestDiagramCanonicalEditPolicy.refreshOnActivate(TestDiagramCanonicalEditPolicy.java:52)
at org.eclipse.gmf.runtime.diagram.ui.editpolicies.CanonicalEditPolicy.activate(CanonicalEditPolicy.java:628)
at org.eclipse.gef.editparts.AbstractEditPart.activateEditPolicies(AbstractEditPart.java:173)
at org.eclipse.gef.editparts.AbstractEditPart.activate(AbstractEditPart.java:155)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.activate(AbstractGraphicalEditPart.java:195)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$0(GraphicalEditPart.java:1)
at org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.activate(GraphicalEditPart.java:205)
at org.eclipse.gmf.runtime.diagram.ui.editparts.DiagramEditPart.activate(DiagramEditPart.java:349)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:214)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramGraphicalViewer.setContents(DiagramGraphicalViewer.java:378)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initializeGraphicalViewerContents(DiagramEditor.java:872)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.initializeGraphicalViewer(DiagramEditor.java:865)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.initializeGraphicalViewer(DiagramEditorWithFlyOutPalette.java:116)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.initializeGraphicalViewer(DiagramDocumentEditor.java:174)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.createGraphicalViewer(DiagramEditor.java:807)
at org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(GraphicalEditor.java:171)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditor.createPartControl(DiagramEditor.java:1580)
at org.eclipse.gmf.runtime.diagram.ui.parts.DiagramEditorWithFlyOutPalette.createPartControl(DiagramEditorWithFlyOutPalette.java:328)
at org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.DiagramDocumentEditor.createPartControl(DiagramDocumentEditor.java:1510)
at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:241)
at org.test.myeditor.diagram.part.MyMultiPageEditor.createPage0(MyMultiPageEditor.java:154)
at org.test.myeditor.diagram.part.MyMultiPageEditor.createPages(MyMultiPageEditor.java:311)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:348)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1254)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1207)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1606)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:497)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:483)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2860)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2674)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:683)
at org.wso2.developerstudio.eclipse.esb.project.provider.NavigatorActionProvider$OpenEditorAction.run(NavigatorActionProvider.java:114)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:845)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:843)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1131)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1235)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Is there any way to get rid of error?
Melan
Re: cannot reopen diagram in the editor after executing SetBoundsCommand or setLayoutConstraint [message #985227 is a reply to message #985183] |
Thu, 15 November 2012 08:50 |
Thanks for the quick reply, getSource() and getTarget() of DiagramLink getting null, I am not familiar with this code
EObject diagramLinkSrc = nextDiagramLink.getSource().getElement();
EObject diagramLinkDst = nextDiagramLink.getTarget().getElement();
refreshConnections() of CanonicalEditPolicy as below
* @generated
private Collection<IAdaptable> refreshConnections() {
Map<EObject, View> domain2NotationMap = new HashMap<EObject, View>();
Collection<EsbLinkDescriptor> linkDescriptors = collectAllLinks(
getDiagram(), domain2NotationMap);
Collection existingLinks = new LinkedList(getDiagram().getEdges());
for (Iterator linksIterator = existingLinks.iterator(); linksIterator
.hasNext();) {
Edge nextDiagramLink = (Edge) linksIterator.next();
int diagramLinkVisualID = EsbVisualIDRegistry
.getVisualID(nextDiagramLink);
if (diagramLinkVisualID == -1) {
if (nextDiagramLink.getSource() != null
&& nextDiagramLink.getTarget() != null) {
linksIterator.remove();
continue;
EObject diagramLinkObject = nextDiagramLink.getElement();
for (Iterator<EsbLinkDescriptor> linkDescriptorsIterator = linkDescriptors
.iterator(); linkDescriptorsIterator.hasNext();) {
EsbLinkDescriptor nextLinkDescriptor = linkDescriptorsIterator
.next();
if (diagramLinkObject == nextLinkDescriptor.getModelElement()
&& diagramLinkSrc == nextLinkDescriptor.getSource()
&& diagramLinkDst == nextLinkDescriptor
.getDestination()
&& diagramLinkVisualID == nextLinkDescriptor
.getVisualID()) {
linkDescriptorsIterator.remove();
break;
deleteViews(existingLinks.iterator());
return createConnections(linkDescriptors, domain2NotationMap);
Melan
Re: cannot reopen diagram in the editor after executing SetBoundsCommand or setLayoutConstraint [message #985918 is a reply to message #985812] |
Fri, 16 November 2012 16:51 |
Yes, I was wrong. I noticed it just did not happen when setting the bounds. I was able to get rid of it by calling my code async way via ProgressMonitorDialog, I don't understand why this is working!
my code as follows
try {
Shell activeShell = PlatformUI.getWorkbench().getDisplay().getActiveShell();
ProgressMonitorDialog progressMonitorDialog = new ProgressMonitorDialog(activeShell);
progressMonitorDialog.setOpenOnRun(true);
progressMonitorDialog.run(true, false, new IRunnableWithProgress() {
public void run(IProgressMonitor monitor) throws InvocationTargetException,
InterruptedException {
try {
monitor.setTaskName("Generating diagram from source");
Deserializer.getInstance().updateDesign(xml, graphicalEditor);
setSourceDirty(false);
} catch (Exception e) {
new InvocationTargetException(e);
} catch (InvocationTargetException e) {
log.error("Error while generating diagram from source",e.getTargetException());
} catch (InterruptedException e) {
log.warn("The operation was canceled by the user", e);
} finally{
firePropertyChange(PROP_DIRTY);
Melan
[Updated on: Fri, 16 November 2012 16:52] Report message to a moderator
Current Time: Sat Apr 27 08:24:42 GMT 2024
Powered by FUDForum. Page generated in 0.04154 seconds
