Home » Archived » Test and Performance Tools Platform (TPTP) » monitor config options; checkboxes work like radio buttons
monitor config options; checkboxes work like radio buttons [message #142346] Fri, 29 May 2009 07:09 Go to next message
I am trying TPTP for the first time.
(following article
http://www.eclipse.org/tptp/home/documents/tutorials/profili ngtool/profilingexample_32.html)
After creating my standard java project, I opened up the "Profile
Configurations" dialog and set the standard 'Main', 'Arguments' (and
'classpath' tabs)
Facing an issue with the 'Monitor' tab;
In the Monitor tab, there are items organized as a tree; with each item
having a check box against it.
With a checkbox I guess, multiple items can be selected. (but in the
Profile-Configuarations dialog, they work like radio buttons, only 1 item
can be selected.)
for instance; under, Java Profiling JRE 1.5 or newer
we have 4 items;
)Execution Time analysis
)Memory analysis
)Thread analysis
)Probe insertion
All have a checkbox against them, but only one of them can be selected.
If I select 'Java Profiling JRE 1.5 or newer' (the top level tree node)
only 'Execution Time analysis' gets selected.
I do not know, if this is intended behaviour or is something wrong in my
installation.
thx
jeevan
PS:
)Probe insertion item if selected, an error is displayed ...'No probes
are selected for probe insertion'
Re: monitor config options; checkboxes work like radio buttons [message #142358 is a reply to message #142346] Fri, 29 May 2009 07:15 Go to previous messageGo to next message
PS: using
Eclipse Platform
Version: 3.4.1
Build id: M20080911-1700
and TPTP Platform 4.5.2
Re: monitor config options; checkboxes work like radio buttons [message #142424 is a reply to message #142346] Mon, 01 June 2009 16:46 Go to previous message
Hi Jeevan,
They are intended behaviour. The analysis types available in JVM 1.5+
profiler are mutually exclusive and hence the behavior of radio button.
For probekit, you will have to 'Edit Option' of the analysis type to select
a probe file for the instrumentation.
Eugene
"Jeevan Sunkersett" <jnsunkersett@yahoo.com> wrote in message
news:f63a08a643b9254c6abbed4644959683$1@www.eclipse.org...
> (following article
> 'classpath' tabs)
> can be selected.)
> we have 4 items; )Execution Time analysis
> )Memory analysis
> )Thread analysis
> )Probe insertion
> installation.
> thx
> jeevan
> PS: )Probe insertion item if selected, an error is displayed ...'No probes
Previous Topic:tptp 4.5.2 and jboss 5
Next Topic:Problem installing tptp
Current Time: Thu Aug 07 02:12:22 EDT 2025
Powered by FUDForum. Page generated in 0.03846 seconds
